Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 09-06-2009, 03:22   #16 (permalink)
Member: 575851
hello ptt here my problem
Started box selftests procedure
USB Voltage 5.16v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.84v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 5.12v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
Old 09-06-2009, 03:26   #17 (permalink)
ptt
ptt's Avatar
Member: 348680
There is no problem with your box, all is ok
this error is because you have not conected the ext VPP power supply ( read the first post of this thread )
The Following User Says Thank You to ptt For This Useful Post:
Old 09-09-2009, 13:44   #18 (permalink)
Member: 87188
I obtained it today the box (LM3526H)
But no external VPP!
This with external stable 5V:
Card Firmware Revision: 0109
Card is activated
Box is activated
USB Voltage 4.99v PASSED
Core Voltage 1.77v PASSED
VBAT Voltage 4.96v PASSED
Box VPP disabled
VPP Voltage 0.47v PASSED
VPP Voltage 4.92v PASSED
Box VPP disabled
VPP Voltage 1.43v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
This without external power:
Card is activated
Box is activated
USB Voltage 4.98v PASSED
MCU Voltage 3.28v PASSED
Box VPP disabled
VPP Voltage 4.90v PASSED
Box VPP disabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
What shall I do now?
Old 09-09-2009, 16:55   #19 (permalink)
Member: 87188
Hy.
Without externaé power write:
With 5V external power:
With 9V external power:
VPP Voltage 1.52v FAILED - IGNORED - Probably power supply is not connected.
Help someone who has it.
A completely new box!
Old 09-09-2009, 22:46   #20 (permalink)
ptt
ptt's Avatar
Member: 348680
@ Pufi164
Did you read this stiky thread ?
Attention! Not connect power supply with more than 5.5V to the EXT VPP Socket !!
If you conect 9V Power Supply to your box ( New HW Rev. with LM3526H ) you KILL your VPP Switch IC ( LM3526H )
You ONLY can use 9V in old HW Rev, that use LM1950T or CS8240
Now you only can use INT VPP ( this is not a problem with new HW Rev. Box as with EXT VPP you can use only 5V and this is the same VPP voltage that INT VPP use ).
Maybe you can exchange the box with your reseller, and nex time dont play with VPP....
Old 09-10-2009, 14:21   #21 (permalink)
Member: 87188
THX.
Now I have already read.
Unfortunately, my new HW with LM3526H.
But work fine wihout external VPP.
rather buy 2 pieces LM3526H, nd exchange on (if it helps)
Ip-mart since it was purchased, it would be easy to send from Europe to China....
It would be the question of whether it makes sense to fix?
Is there any downside?
Old 09-10-2009, 21:49   #22 (permalink)
ptt
ptt's Avatar
Member: 348680
@ Pufi164
If your Box works properly, and you can flash.... ( try some model that can use VPP some DCT-4 ) i dont see any reason to touch anything...
here an easy way to check VPP
Product supporter, please see this error.
Old 09-12-2009, 11:35   #23 (permalink)
senkron24's Avatar
Member: 15880
Sonork: 100.1612155
Originally Posted by ptt View Post
I think there is at least 3 diferent HW versions, the first with LM1950T ( i have this ), the second with CS8240, and the third with LM3526H.... i cant say which is better as i only have 1....
If you dont have the skill to do the tests posted, then better contact reseller, or Mr. Cyclonebox ( see this post )
in my devacie is lm3940is
is other hw
Old 09-12-2009, 11:58   #24 (permalink)
adnanali's Avatar
Member: 207308
check this just registration complete and i face this my 1st cyclone is ok on same pc & cable
Old 09-12-2009, 12:15   #25 (permalink)
ptt
ptt's Avatar
Member: 348680
@ senkron24
Yes, your Cyclone and all other uses LM3940, it is an 1A Low Dropout Regulator for 5V to 3.3V Conversion, for MCU power supply... and LM1950T, CS8240, and LM3526H are used for VBAT an VPP voltage switch, those IC are the cause of most Selftest Fail warnings...
Old 09-12-2009, 12:19   #26 (permalink)
ptt
ptt's Avatar
Member: 348680
@ adnanali
you get "VBAT Voltage fail" ?
read the first post of this thread, where say: " 3- VBAT Supply test fail "
Old 09-12-2009, 13:37   #27 (permalink)
senkron24's Avatar
Member: 15880
Sonork: 100.1612155
@ senkron24
i have samtimes problem with pic adanali
Box Selftests Failed -> VPP Supply Voltage test failed, 0,60v is out of valid range
and same times work great
Card is activated
Box is activated
USB Voltage 5,03v PASSED
MCU Voltage 3,27v PASSED
Core Voltage 1,76v PASSED
VBAT Voltage 0,01v PASSED
VBAT Voltage 4,92v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
VPP Voltage 4,88v PASSED
Box VPP disabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Super DCT4 Activation: TRUE
muss i change lm3940 ???
b.r
senkron24
Old 09-12-2009, 13:48   #28 (permalink)
ptt
ptt's Avatar
Member: 348680
Resolder VBAT switch IC ( LM1950T, CS8240 or LM3526H ) if your box have LM1950T the VBAT IC is the ones located behind diagnostioc port (RJ-48)
If LM3940 fail, yor box dont work at all (dead box)
Old 09-12-2009, 21:08   #29 (permalink)
hackgsm's Avatar
Member: 64014
Sonork: 100.1603152
is other hw
lm3940is is regulator 3.3v for atmel chip......old and new cyclone box
The Following User Says Thank You to hackgsm For This Useful Post:
Old 09-14-2009, 10:59   #30 (permalink)
Member: 760908
USB Voltage 5.02v PASSED
MCU Voltage 3.30v PASSED
Core Voltage 1.76v PASSED
Box Selftests Failed -> VBAT Supply Voltage test failed, 3.01v is out of valid range
Super DCT4 Activation: FALSE
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range kosta25 Cyclonebox 2 11-04-2009 12:40
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range azad4u Cyclonebox 7 07-08-2009 14:48
just got box, dont know what to do masterunlocking VygisToolbox 2 11-11-2007 16:36
6280 flashing failed! what to do? rakhpai Universalbox 2 08-10-2006 18:33
Page generated in 0.41842 seconds with 12 queries
