05-30-2021, 22:30 | #6587 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2474430 Status: Offline Thanks Meter: 3 | Forget DFU. Recovery mode should be plenty good enough. Turn off, then plug into computer while holding home button. If you don't get detect at the computer in recovery mode & you've tried a new charge port then it's a board problem. Most likely Tristar, but not necessarily. If it doesn't go into recovery at all, maybe you have a home button problem? |
05-31-2021, 09:51 | #6588 (permalink) |
Major Poster Join Date: Aug 2010 Location: USA
Member: 1371477 Status: Offline Thanks Meter: 6 | HELP I recently bypassed my iPad Pro 2 Cellular with iKeytools and it lost the imei but was still working as Wifi only. Then i decided to flash it to get back the imei so i could do Bypass with sim card under Meid option and it failed at 80% flashing on #u tools 14.5.1 and it got stuck in recovery mode then I clicked on exit recovery and it went black and never woke up. Now it won't even show on iTunes on Mac. Tried holding the Home and Power key still no boot battery is measuring 4.24v. Any help on how to boot again? |
06-02-2021, 09:10 | #6589 (permalink) | |
Freak Poster Join Date: Nov 2012 Location: Philippines
Member: 1837922 Status: Offline Thanks Meter: 15 | Quote:
so this leaves to to your last cause which is tristar. is it possible also that this could be a nand chip, sir? kindly advice. thank you | |
06-17-2021, 12:37 | #6590 (permalink) | |
Junior Member Join Date: May 2021 Location: Universe
Member: 2989148 Status: Offline Thanks Meter: 0 | Quote:
hello there is less chance of getting dead by bypass and software. hold all keys for 5 to 10 minute. also make sure it has plenty of change. also connect your ipad to pc , if sounds come then there is no need to worry. | |
07-03-2021, 22:35 | #6593 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1696369 Status: Offline Sonork: 91000 Thanks Meter: 8 | I have iphone 7. Strange problem. Boot normal. But after sleep or auto lock. Phone dead. Need to unplug battery and turn on again. Sent from my MHA-L29 using Tapatalk |
08-04-2021, 00:25 | #6595 (permalink) |
Junior Member Join Date: Jan 2019
Member: 2887904 Status: Offline Thanks Meter: 0 | iPhone XS No Power Got an XS not charging or booting. 5.12v at charger with 0a current draw. When power and vol button pressed I get 0.39a momentarily then back to 0. Battery measures 0.9v and battery connector measures 0.2v when plugged in. It worked previously fine, was on charge overnight then never turned on again. Not sure where to look or what to assume. Tried new cable and new charging port, no avail. Other option is new battery but I suspect tristar ic has died or a cap has ****n. Any help would be great, cheers. |
11-18-2021, 16:50 | #6599 (permalink) |
No Life Poster Join Date: Aug 2007 Location: jinja,uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 249 | iphone A1530 sensor problem Iphone A1530 sensor problem. Any solution? I have two of the same model phones I tried change do exchange the screen but still one does not sence any thing,any one with solution for this problem? |
11-18-2021, 16:58 | #6600 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Brazil Age: 41
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | Quote:
which sensor do you refer to? proximity sensor or touch screen? If it is touch screen Meson and Cumulus, if you also have a 5v1 voltage coming from chestnuit (the screen needs to be turned on to find this voltage) if it is the proximity sensor check the camera flex and the Fpc on the board! | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
