![]() | #31 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Quote:
ok my pc is fresh windows installed sir sorry for the trouble can you please tell me what to do final step ? | |
![]() | #32 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: private
Member: 1043909 Status: Offline Thanks Meter: 61,455 | Quote:
- Update dongle with Infinity DongleManager.exe - Run Infinity software | |
![]() | #34 (permalink) |
Major Poster ![]() ![]() Join Date: Jun 2020 Location: Malawi Age: 36
Member: 2959226 Status: Offline Thanks Meter: 1 | Dongle misconfiguration === DongleManager [Infinity] v1.80 [9/1/2021 8:08:11] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000BAA821F34082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 2F23BAA8 Firmware version: 0150.02 === Process started: 9/1/2021 8:08:13 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
![]() | #37 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: May 2005 Location: uae
Member: 148515 Status: Offline Thanks Meter: 19,544 | Quote:
Now Ok? | |
![]() | #38 (permalink) |
Junior Member ![]() ![]() Join Date: May 2014 Location: Turkey
Member: 2184561 Status: Offline Thanks Meter: 2 | === DongleManager [Infinity] v1.88 [8.09.2021 05:17:27] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000552718164082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 21C85527 Firmware version: 0150.02 === Started: 8.09.2021 05:17:29 === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 Do you want to report an issue to Support? No Report fix use Username: 0021C85527 ==> Scan C:\Users\SeCi\Downloads\Compressed\DongleManager for report.log ==> Scan c:\InfinityBox for report.log ==> Scan c:\Program Files for report.log ==> Scan c:\Program Files (x86) for report.log Found files: 0 ==> Scan C:\Users\SeCi\Downloads\Compressed\DongleManager for *.ibin.log ==> Scan c:\InfinityBox for *.ibin.log ==> Scan c:\Program Files for *.ibin.log ==> Scan c:\Program Files (x86) for *.ibin.log Found files: 0 ==> Scan C:\Users\SeCi\Downloads\Compressed\DongleManager for fault.bin ==> Scan c:\InfinityBox for fault.bin ==> Scan c:\Program Files for fault.bin ==> Scan c:\Program Files (x86) for fault.bin Found files: 0 No reports found |
![]() | #39 (permalink) |
![]() | #40 (permalink) | |
Thank you! | |
![]() | #41 (permalink) |
Junior Member ![]() Join Date: Jul 2011
Member: 1612006 Status: Offline Thanks Meter: 3 | Warning:Dongle misconfiguration Error Username: 003A2422DD ==> Scan O:\NOKIA FLASH FILE\AL BOX DONGEL TOOLS SETUP FILE\InfinityBox CM2\Dongle Manager\DongleManager for report.log ==> Scan c:\InfinityBox for report.log ==> Scan f:\InfinityBox for report.log ==> Scan c:\Program Files for report.log ==> Scan c:\Program Files (x86) for report.log Found files: 0 ==> Scan O:\NOKIA FLASH FILE\AL BOX DONGEL TOOLS SETUP FILE\InfinityBox CM2\Dongle Manager\DongleManager for *.ibin.log ==> Scan c:\InfinityBox for *.ibin.log ==> Scan f:\InfinityBox for *.ibin.log ==> Scan c:\Program Files for *.ibin.log ==> Scan c:\Program Files (x86) for *.ibin.log Found files: 0 ==> Scan O:\NOKIA FLASH FILE\AL BOX DONGEL TOOLS SETUP FILE\InfinityBox CM2\Dongle Manager\DongleManager for fault.bin ==> Scan c:\InfinityBox for fault.bin ==> Scan f:\InfinityBox for fault.bin ==> Scan c:\Program Files for fault.bin ==> Scan c:\Program Files (x86) for fault.bin Found files: 0 No reports found === DongleManager [Infinity] v1.88 [9/16/2021 6:20:00 PM] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000022DD21F34082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): 3A2422DD Firmware version: 0148.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0030 v.0148 => Activations: - 00: Infinity-Box/Dongle [CM2] v0148 => Options: - Infinity-Box/Dongle [CM2] |
![]() | #42 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2452055 Status: Offline Thanks Meter: 0 | cm2 problem azizullo Please help me, I used this prog (usb network gate) I temper never use this prog, please pamagaite mine === DongleManager [Infinity] v1.88 [16.09.2021 17:28:54] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 1 HWID: 00010C8B1CC74082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): E51D0C8B Firmware version: 0147.02 === Started: 16.09.2021 17:28:56 === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0031] Dongle identification data damaged. |
![]() | #43 (permalink) | |
- Read NOTE - https://infinity-box.com/support/?s=2 ![]() - Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. - Reboot PC Make the next steps ONLY after uninstall usb sharing tool otherwise YOU MAY DAMAGE your dongle - Update dongle with Infinity DongleManager.exe ![]() - Run Infinity software | |
![]() | #44 (permalink) | |
Now make this: - Read NOTE - https://infinity-box.com/support/?s=2 ![]() - Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. - Reboot PC Make the next steps ONLY after uninstall usb sharing tool otherwise YOU MAY DAMAGE your dongle - Update dongle with Infinity DongleManager.exe ![]() - Delete fault.bin file (if you have it in CM2 folder) ![]() - Run Infinity software | |
![]() | #45 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2014
Member: 2301015 Status: Offline Sonork: 100.1668279 Thanks Meter: 10 | Token - Type: Infinity [BEST] - Account Status: Active - Hardware Status: Ok Services - Activation #0: Infinity-Box/Dongle [CM2]; Firmware Version: 0147; Registered: 22-Jan-2020; Expired: 24-Mar-2021; Support: Expired - Activation #3: Infinity [BEST]; S/N: 8F5737E0; Firmware Version: 0123; Registered: 19-Mar-2019; Expired: 01-Jul-2021; Support: Expired More Services may be active but not listed this need activation but cant active i need cm2 activate 1 year. gsmfastest im submit but him tellalready active |
