09-02-2020, 09:36 | #286 (permalink) |
Junior Member Join Date: Aug 2016 Location: Zimbabwe
Member: 2607480 Status: Offline Sonork: http://sonork.com/eng/cli Thanks Meter: 1 | sn Card-Reader: Alcor Micro USB Smart Card Reader 0 ATR: 3B7F96000080318065B0850201F312FFFE829000 Card Manager: A000000018434D00 SerialNumber: 00013A2B ROM: Integrated Circuit Fabricator: 4790 Integrated Circuit Type: 5081 OS: Identifier: 1291 Release Date: 1102 Release Level: 0201 EEPROM: Fabrication Date: 5091 Serial Number: 00013A2B Batch Identifier: 7CEA Module Fabricator: 4082 Module Packaging Date: 6047 IC Card Manufacturer: 1293 IC Em******* Date: 6047 Pre Personalizer: 5004 Pre Personalization Date: 6047 Pre Personalization Equipment Identifier: 00000014 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 00013A2B7CEA4082 GP Version: 2.1.1 SCP Version: 1, Option: 5 |
09-02-2020, 09:59 | #287 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
09-02-2020, 10:01 | #288 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 File with Drivers: CardReader_Fetian_FT2K.7z File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Run DongleManager 3. Update Dongle firmware OR 1. Insert Smart-Card into another Card-Reader. Good result for today gives Alcor Card-Reader. 2. Run DongleManager - https://www.infinity-box.com/support/?r=5 3. Update Dongle firmware Only ONE update try is allowed. In case of problem DO NOT update card again but contact to support ! | |
09-02-2020, 10:02 | #289 (permalink) | |
Update it once again now. | |
09-04-2020, 13:35 | #290 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Uzbekistan
Member: 1791708 Status: Offline Thanks Meter: 21 | === DongleManager [Infinity] v1.80 [04.09.2020 17:34:19] === Searching... Card-Reader: FT SCR2000 0 HWID: 0106A16208B51292 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 0000A162 Firmware version: 0118.00 "UK Edition" status: Off Last launched Application: 0000 v.0000 => Activations: - 0A: #10 => Box/Dongle misconfiguration. Contact to support ! => Options: - Infinity-Box/Dongle - Infinity SM Please help |
09-04-2020, 17:06 | #291 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 File with Drivers: CardReader_Fetian_FT2K.7z File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Run DongleManager 3. Update Dongle firmware ONCE OR 1. Insert Smart-Card into another Card-Reader. Good result for today gives Alcor Card-Reader. 2. Run DongleManager - https://www.infinity-box.com/support/?r=5 3. Update Dongle firmware ONCE In case of problem DO NOT update card again but contact to support ! | |
09-05-2020, 18:15 | #292 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Iran
Member: 192198 Status: Offline Sonork: 100.1609528 Thanks Meter: 234 | cant update fw my sim card suspended!! other version work new version need update fw update card === DongleManager [Infinity] v1.80 [9/5/2020 10:11:29] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0002A71CFF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 3404A71C Firmware version: 0144.02 === Process started: 9/5/2020 10:11:33 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0006] Your account is temporary suspended. See problem reason in log file Contact to http://www.infinity-box.com/support/?r=2 |
09-05-2020, 18:56 | #294 (permalink) | |
09-06-2020, 10:56 | #298 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You was registrd here in year 2005 this means you are not 16 years old girl. So let me ask you - why do you write that ? you know very well that your FIRST update attempt was with other reader and that FIRST try gives a problem. Server do not allow to kill cards, it has protection against stupidity (oh.. really let's acll it IQ). That's why only first try matter. btw, everybody can check their IQ (but probably it's better to call it stupidity level) just by looking how many times somebody try to repeat dongle update attempt after first fault. Yours is really good (only two tries day ago) in compare with many others. Amd my congratulations, finally wih Alcor card-reader card was updated well. |
09-06-2020, 10:57 | #299 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, There is a software conflict with the next application(s): C:\program files (x86)\intel\bluetooth\devmonsrv.exe C:\program files (x86)\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe C:\program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe C:\program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe C:\program files\via xhci uasp utility\usb3monitor.exe What to do: 1. Delete or rename files (see above) 2. Reboot PC 3. Delete fault.bn file 4. Update dongle firmware with DongleManager now 5. Run Infinity software. |
09-06-2020, 18:49 | #300 (permalink) |
Junior Member Join Date: Jan 2013 Location: Addis Ababa, Ethiopia
Member: 1876822 Status: Offline Thanks Meter: 4 | I tried it for 2 days, Please help here is the log === DongleManager [Infinity] v1.80 [9/6/2020 20:43:03] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: GsmEasy S-Reader 0 HWID: 0000E4A521344082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 2ECEE4A5 Firmware version: 0118.02 === Process started: 9/6/2020 20:43:04 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0005] Authentication failed! Dongle is not Registered yet ? Disconnected You should "Register" before you start update ! Click to "Yes" to start Registration process. If you are already registered click to "No" 2ECEE4A5: Too many attempts (8) today. Please try again tomorrow ! Contact to http://www.infinity-box.com/support/?r=2 |
