![]() | #1936 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: private
Member: 1043909 Status: Offline Thanks Meter: 61,027 | Quote:
What is your Support Validity Date ? How to check - http://www.infinity-box.com/doc/?r=17 If support is expired - please contact to any seller and renew support. | |
![]() | #1937 (permalink) | |
![]() | #1938 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2007 Location: Indonesia
Member: 527975 Status: Offline Thanks Meter: 101 | Quote:
Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0109917224881292 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D2429172 Firmware version: 0134.02 === Process started: 7/23/2017 12:54:29 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 | |
![]() | #1939 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: May 2005 Location: uae
Member: 148515 Status: Offline Thanks Meter: 19,540 | Quote:
Have you checked the instruction ? What was your steps ? | |
![]() | #1940 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Oct 2006 Location: india
Member: 378148 Status: Offline Thanks Meter: 12 | === DongleManager [Infinity] v1.70 [7/23/2017 20:23:40] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0104676824881292 === Process started: 7/23/2017 20:23:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 plz help |
![]() | #1941 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2008 Location: Indonesia
Member: 919549 Status: Offline Thanks Meter: 132 | please help dongle has not found after interupt with unstable usb port with update firmware === DongleManager [Infinity] v1.70 [7/23/2017 23:57:20] === Searching... Card-Reader: FT SCR2000 0 HWID: 0102937014D11292 Box/Dongle is not found SN : 79289370 |
![]() | #1942 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
Member: 183976 Status: Offline Thanks Meter: 134 | Im trying to activate SM module , ihad read username and password with Dongle manager but when i login in services page it says : Wrong Username or Password . and when i update dongle firmware i got this : Quote:
![]() | #1943 (permalink) | |
![]() | #1944 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
![]() | #1945 (permalink) | |
To reset password click here - http://www.infinity-box.com/support/?r=16&help=1 | |
![]() | #1946 (permalink) | |
Member: 919549 Status: Offline Thanks Meter: 132 | Quote:
Code: === DongleManager [Infinity] v1.70 [7/24/2017 10:54:07] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0102937014D11292 === Process started: 7/24/2017 10:54:07 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 | |
![]() | #1947 (permalink) | |
- Uninstall any kind of usb trace/spy/sharing software and do not use it in future * i dont use any sharing sw - Kill in your PC Device Manager all processes with name like usb3monitor * allready disable usb3monitor but result are same - Find in folder with CM2 or [BEST] software file fault.bin * i dont find file with that name in my cm2mtk folder - Post here your dongle details (Copy/paste text) and attach here fault.bin file (if you have it in folder with software). * DongleManager [Infinity-Box] v1.66 [7/24/2017 12:23:50 PM] PC HWID: A5A99BA04F08AD5D9B98B132F4F78B64 Scanning... Box/Dongle found: Main Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0109917224881292 Box/Dongle Serial No (S/N): D2429172 Firmware version: 0134.02 Box/Dongle misconfiguration Diagnostic code: 57 "UK edition" status: Off Last launched Application: 0034 v.0100 => Activations: - 00: Main Infinity-Box/Dongle v.0134 Diagnostic Key: 7FA8F353430CB474 | |
![]() | #1948 (permalink) | |
![]() | #1949 (permalink) | |
![]() | #1950 (permalink) |
Member: 919549 Status: Offline Thanks Meter: 132 | here Code: === DongleManager [Infinity] v1.70 [7/24/2017 15:55:35] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0102937014D11292 === Process started: 7/24/2017 15:55:35 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
