![]() | #2101 (permalink) |
Junior Member ![]() ![]() Join Date: Nov 2009 Location: poland
Member: 1161780 Status: Offline Thanks Meter: 1 | Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0102908114D11292 === Process started: 2017-08-22 12:15:20 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
![]() | #2102 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: May 2005 Location: uae
Member: 148515 Status: Offline Thanks Meter: 19,540 | Quote:
Update it now ONE more time and DO NOT add more activations to it ! | |
![]() | #2103 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
![]() | #2104 (permalink) | |
Insane Poster ![]() ![]() ![]() Join Date: Mar 2005 Location: Backi Petrovac
Member: 129300 Status: Offline Thanks Meter: 20 | OK its done. Log: === DongleManager [Infinity] v1.70 [8/22/2017 15:33:26] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0001DFB0FF021982 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 0761DFB0 Firmware version: 0136.02 => Activations: - 00: Infinity-Box/Dongle v.0136 - 03: [BEST] v.0122 - 04: Pin-Finder Adapter - 05: Content Extractor v.0122 => External Activations: - SPT-Box - Micro-Box - GB-Key - GB-Key (Activation) - GPG-Workshop Quote:
Let's say GPG-Workshop. Thank you. | |
![]() | #2105 (permalink) | |
Are you sure you want to remove GPG-Workshop ? | |
![]() | #2107 (permalink) |
Member: 1161780 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.70 [2017-08-23 08:53:00] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0102908114D11292 === Process started: 2017-08-23 08:53:00 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Error upgrading applets: Card returned error - 0000 at 174/10053 Disconnected |
![]() | #2108 (permalink) |
Junior Member Join Date: Jul 2005 Location: earth
Member: 159022 Status: Offline Thanks Meter: 0 | trying to update for new samsung activation === DongleManager [Infinity] v1.70 [23.08.2017 12:15:40] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 1 HWID: 01038D6103EF1292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 64298D61 Firmware version: 0122.02 === Process started: 23.08.2017 12:15:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 7373/10053 Error upgrading applets: Card returned error - 0000 at 7373/10053 Disconnected === DongleManager [Infinity] v1.70 [23.08.2017 12:22:47] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 1 HWID: 01038D6103EF1292 === Process started: 23.08.2017 12:22:48 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to ...support |
![]() | #2110 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2013
Member: 1980910 Status: Offline Sonork: 100.1650130 Thanks Meter: 35 | Wanted to activate samsung module all done while update this error shows up.... ==== [23-08-2017 20:36:19] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.70 [23-08-2017 20:36:22] === Searching... Card-Reader: FT SCR2000 0 HWID: 0101968A20281292 Select Token Type: instead of Autodetect === DongleManager [Infinity] v1.70 [23-08-2017 20:36:26] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0101968A20281292 === Process started: 23-08-2017 20:36:26 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
![]() | #2111 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2004 Location: Poland Age: 44
Member: 87364 Status: Offline Thanks Meter: 65 | My Box (red box -Card Version)not detect. I instaling 3 computers and not detect. Yesterday working perfect but today is problem. SN: 000B49DE44 Please help me. |
![]() | #2112 (permalink) |
Junior Member Join Date: Sep 2012 Location: Peru
Member: 1813747 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.70 [23/08/2017 21:30:32] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000349A500001942 === Process started: 23/08/2017 21:30:32 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to ww infinity-box |
![]() | #2114 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 416 | I got error during update (wanted to activate samsung module) and now my dongle isn't working: === DongleManager [Infinity] v1.70 [8/25/2017 0:38:14] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 00079D7720281292 === Process started: 8/25/2017 0:38:14 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
![]() | #2115 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jan 2014
Member: 2116325 Status: Offline Thanks Meter: 15 | update error, please help--- === DongleManager [Infinity] v1.70 [25-08-2017 11:03:03] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0000939A0EFE4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): AE52939A Firmware version: 0136.02 === Process started: 25-08-2017 11:03:07 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
