Old 09-09-2012, 08:50   #17026 (permalink)
amc_khan's Avatar
Member: 638447
Sonork: 100.1609504
Thanks Meter: 186
card found: S/N 252D:0118
registered to: amc_khan
Connect phone on selected interface...
Core : v1.51 , FlashEngine : v1.8
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
-> Flash Files are NOT selected!
You can Select:
S40 : Any, but MCU need present in filelist
S60 : Any, but CORE/MCU need present in filelist
S60 APE : MCU+PPM, MCU+PPM+CNT
Files Set for Flashing :
MCU : C5F02102_rm495__07.97.mcusw
PPM : rm495__07.90.ppm_mena_b
CNT : E24393CE_rm495__07.97.image_mena_a1_red
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Getting product info...
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
Connection opened successfully
Waiting for communication response.
ASIC ID: 000000010000022600010006030C192101033000
CPU ID : RAP3Gv3 , Features : No any extended features
RAP_PUB: 14900209F3137E5692767136ABA557EB3FABD71D
CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
TIME : Boot time : 00:00:06
Reopening the connection...
Waiting for response: 30
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : Check data
ADL : Data accepted
ADL : ASIC CMT select Ok
===Flashing [MCU]===
Erase : Processing C5F02102_rm495__07.97.mcusw
Found 6 areas to erase
Erasing area 0x00000000 - 0x000006BF, NOR, CMT
Result: 0000
Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT
Result: 0000
Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:41
Write : Processing C5F02102_rm495__07.97.mcusw
Total 1178 [1178/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
TIME : Write time : 00:01:02
MCU Write done
===Flashing [PPM]===
Erase : Processing rm495__07.90.ppm_mena_b
Found 1 areas to erase
Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:04
Write : Processing rm495__07.90.ppm_mena_b
Total 404 [404/0/0] blocks to write, writing...
TIME : Write time : 00:00:20
PPM Write done
===Flashing [CNT]===
Erase : Processing E24393CE_rm495__07.97.image_mena_a1_red
Found 2 areas to erase
Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT
Result: 0000
Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:05:39
Checking content info...
Check Image : Content size is 128k, use direct write mode
Write : Processing E24393CE_rm495__07.97.image_mena_a1_red
Total 656 [656/0/0] blocks to write, writing...
TIME : Write time : 00:00:38
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:11:27
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia 5130c-2
Software Info: V 07.97 13-09-10 RM-495 (c) Nokia
IMEI: 354223032720203
PPM version : V 07.90 23-09-09 RM-495 (c) Nokia MEN
Product code: 0581455
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
===== WARNING =====
Battery voltage is can be not enough for start
===== WARNING =====
AfterFlash operations done ;D
Done!
Elapsed: 00:12:42
Phone found!
Series 40 Device detected!
read info... - Ok
Old 09-09-2012, 08:50   #17027 (permalink)
amc_khan's Avatar
Member: 638447
Sonork: 100.1609504
Thanks Meter: 186
You can Select:
Check files done...
ADL : Check data
ADL : Data accepted
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
MCU Write done
Result: 0000
PPM Write done
Result: 0000
Result: 0000
CNT Write done
ADL : End flashing
Flashing done!
Reboot phone now...
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
===== WARNING =====
===== WARNING =====
Done!
Elapsed: 00:12:42
Phone found!
read info... - Ok
Old 09-09-2012, 08:51   #17028 (permalink)
amc_khan's Avatar
Member: 638447
Sonork: 100.1609504
Thanks Meter: 186
MCU : RM-484_30.009_prd.core.fpsx
PPM : RM-484_30.009_022_prd.language.fpsx
PPM2 : RM-484_30.009_54.1_prd.customer.fpsx
CNT : RM-484_30.009_003_U001.uda.fpsx
APE : rm484_ENO_x_2009wk42v0.a004
Check files done...
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID: 000000010000022600010006400C192101051103
CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 035001132195005208128E354B980D18EBCCFD9E
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
Processing RAP3NAND ...
Processing PASUBTOC ...
Processing PAPUBKEYS...
Processing UPDAPP ...
Boot Done!
TIME : Boot time : 00:00:03
Waiting for response: 29
ADL : Auth done...
Erase : Processing RM-484_30.009_prd.core.fpsx
Found 4 areas to erase
Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
Result: 0000
Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT
Result: 0000
Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT
Result: 0000
Erasing area 0x00D60000 - 0x0A27FFFF, NAND, CMT
Result: 0000
Erase partition 0x0A
Partition erase Ok
Partitioning : Ok [5]
TIME : Erase time : 00:00:00
Write : Processing RM-484_30.009_prd.core.fpsx
Total 494 [494/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ADA]
CMT : Writing Hash CERT [RAP3NAND]
CMT : Writing Hash CERT [SOS*UPDAPP]
CMT : Writing Hash CERT [SOS*DSP0]
CMT : Writing Hash CERT [SOS*ISASW]
CMT : Writing Hash CERT [SOS+CORE]
CMT : Writing Hash CERT [SOS+ROFS1]
TIME : Write time : 00:01:13
MCU Write done
Erase : Processing RM-484_30.009_022_prd.language.fpsx
Erasing area 0x07A20000 - 0x0957FFFF, NAND, CMT
Result: 0000
Write : Processing RM-484_30.009_022_prd.language.fpsx
Total 70 [70/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFS2]
TIME : Write time : 00:00:11
PPM Write done
===Flashing [PPM2]===
Erase : Processing RM-484_30.009_54.1_prd.customer.fpsx
Erasing area 0x09580000 - 0x0A27FFFF, NAND, CMT
Result: 0000
Write : Processing RM-484_30.009_54.1_prd.customer.fpsx
Total 6 [6/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFS3]
TIME : Write time : 00:00:00
PPM Write done
Erase : Processing RM-484_30.009_003_U001.uda.fpsx
Erasing area 0x0A280000 - 0x0F47FFFF, NAND, CMT
Result: 0000
Write : Processing RM-484_30.009_003_U001.uda.fpsx
Total 2 [2/0/0] blocks to write, writing...
CNT Write done
===Flashing [APE]===
Erase : Processing rm484_ENO_x_2009wk42v0.a004
Write : Processing rm484_ENO_x_2009wk42v0.a004
Total 18 [18/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS*ENO]
TIME : Write time : 00:00:02
APE Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:01:29
Reboot phone now...
Connected phone - Nokia N86 8MP
Software Info: V ICPR72_09w36.25 18-02-10 RM-484 (c) Nokia
IMEI: 358270039915050
Ape Version: 30.009
Product code: 0580494
Checking...
Read Info Done!
SwUpgradeSet...OK!
Battery voltage is enough for start
Done!
Elapsed: 00:02:43
Phone found!
Series 60 Device detected!
read info... - Ok
Backup Certificates now...
Backup CRT308 data...
CRT308 Backup Created
SLx Simlock Data read ... ok
SL3 Simlock Sign read ... ok
WMDRM read ... ok
Check communication with phone....
Reboot....
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0
2nd boot not accepted... Alive Request not done
Boot error...
Looks like ASIC not supported, or HW failure
Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO
If RAPIDO - use dead mode for read rpl/force local
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : D:\BEST\Backup\Cert\358270039915050_SIM.rpl
Phone disconected!
Old 09-09-2012, 08:51   #17029 (permalink)
amc_khan's Avatar
Member: 638447
Sonork: 100.1609504
Thanks Meter: 186
Check files done...
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Boot Done!
ADL : Auth done...
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Partition erase Ok
MCU Write done
Result: 0000
PPM Write done
Result: 0000
PPM Write done
Result: 0000
CNT Write done
APE Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Reboot phone now...
Ape Version: 30.009
Checking...
Read Info Done!
SwUpgradeSet...OK!
Done!
Elapsed: 00:02:43
Phone found!
read info... - Ok
WMDRM read ... ok
Reboot....
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Boot error...
Phone disconected!
The Following User Says Thank You to amc_khan For This Useful Post:
Old 09-09-2012, 08:52   #17030 (permalink)
amc_khan's Avatar
Member: 638447
Sonork: 100.1609504
Thanks Meter: 186
--- Insert cable and charger or press phone's power button! ---
ASIC ID: 000000000000000022000509200C0000
CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB
EM0 ID: 00005361
PUBLIC ID: 0000000000450844DF68791EAE9C93A26F1E53C9
ASIC MODE ID: 00
ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
ROM ID: DE56D582BDDE7A3A
Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0
FLIC : 003000EC
Req : XSR 1.6
Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:02
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09
ADL: Reading certificates...
Reading NPC certificate...
IMEI : 354843041130035
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
Cert Read done!
ADL: Reading certificates done!
ADL: Close_Session
Content: 000300000000020000000200000000
ADL: Reboot
Wait, reconneting...
WMDRM read ... ok
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : D:\BEST\Backup\Cert\354843041130035.rpl
All done, Disconnecting
Elapsed: 00:00:28
Phone found!
read info... - Ok
Phone found!
read info... - Ok
Using F-bus count...
Sending code #pw+12534874924 Level : 7 to SimLock Server...
Simlock Server Answer: Error
Done!
Sending code #pw+58835762198 Level : 7 to SimLock Server...
Done!
Sending code #pw+76175812918 Level : 7 to SimLock Server...
Done!
Phone disconected!
Old 09-09-2012, 08:53   #17031 (permalink)
amc_khan's Avatar
Member: 638447
Sonork: 100.1609504
Thanks Meter: 186
UFS S/N 102641 boot - Ok
Phone found!
read info... - Ok
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Settings Software Upgrade Defaults...
Set OK!
Settings Service Centre Defaults...
Set OK!
Settings Production Tune Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Settings Leave Factory defaults...
Set OK!
Elapsed: 00:00:11
Phone disconected!
Error open UFS #102641
MCU : rm411__07.23.mcusw
PPM : rm411__07.23.ppm_mb
CNT : rm411__07.23.image_mb_b_blue
Check files done...
RAP_PUB: 25300210BBE75550CDDC25B1B2EC4A6CBCE0406F
ADL : Check data
ADL : Data accepted
Erase : Processing rm411__07.23.mcusw
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
TIME : Erase time : 00:02:27
Write : Processing rm411__07.23.mcusw
Total 1289 [1289/0/0] blocks to write, writing...
MCU Write done
Erase : Processing rm411__07.23.ppm_mb
Result: 0000
TIME : Erase time : 00:00:58
Write : Processing rm411__07.23.ppm_mb
Total 394 [394/0/0] blocks to write, writing...
TIME : Write time : 00:00:19
PPM Write done
Erase : Processing rm411__07.23.image_mb_b_blue
Result: 0000
Result: 0000
TIME : Erase time : 00:05:14
Write : Processing rm411__07.23.image_mb_b_blue
Total 520 [520/0/0] blocks to write, writing...
TIME : Write time : 00:00:26
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:10:29
Reboot phone now...
Connected phone - Nokia 5220 XpressMusic
Software Info: V 07.23 17-07-09 RM-411 (c) Nokia
IMEI: 353662013261391
PPM version : V 07.23 17-07-09 RM-411 (c) Nokia MB
Product code:
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:11:48
Phone found!
read info... - Ok
Phone disconected!
MCU : rm607__06.07.mcusw
PPM : rm607__06.07.ppm_l
CNT : rm607__06.07.image_l_059B160
Check files done...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_2.5_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI : 357401043122778
PCcode : 059G897
RPL saved : D:\BEST\Backup\Cert\357401043122778_XG213_CRT.rpl
File : rm607__06.07.mcusw
Image : rm607__06.07.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00040000
Erasing, wait ...
Erase done, time : 00:00:01
Write , Start : 0x40040000 , Len : 0x00040000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40080000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40080000 , Len : 0x00020000
Flashing , wait ...
Processing Region 4/5
Erase , Start : 0x400A0000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x400A0000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 5/5
Erase , Start : 0x40400000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:01:58
Write , Start : 0x40400000 , Len : 0x01780000
Flashing , wait ...
Region flash done, time : 00:00:33
File : rm607__06.07.ppm_l
Image : package_l.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41C00000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:15
Write , Start : 0x41C00000 , Len : 0x00337044
Flashing , wait ...
Region flash done, time : 00:00:03
File : rm607__06.07.image_l_059B160
Image : package_l_059B160.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42200000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:04:12
Write , Start : 0x42200000 , Len : 0x00B00000
Flashing , wait ...
Region flash done, time : 00:00:19
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:07
No write data, skip
Flashing done!
Total flash time : 00:07:41
Reboot phone now...
Connected phone - C1-01
Software Info: V 06.07 13-10-11 RM-607 (c) Nokia
IMEI: 357401043122778
PPM version : V 06.07 13-10-11 RM-607 (c) Nokia L
Product code: 059G897
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 39 certs
Data exist, skip certificate repair...
Done!
Elapsed: 00:08:22
Phone found!
read info... - Ok
Old 09-09-2012, 11:48   #17032 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
X2-02 flashing Done
Phone found!
read info... - Ok
Connected phone - X2-02
Software ver : V 11.57 31-03-12 RM-694 (c) Nokia
IMEI 1 : 352440055303244
IMEI 2 : 352440055303251
PPM : V 11.57 31-03-12 RM-694 (c) Nokia M_A
CNT : Content: ctv PK v1 V 10.91 08-02-12 RM-694 (c) Nokia
Product SN : 9346D3BAH
Product code : 059P1X1
Base Prd.code: 059C943
Module code : 0204922
Long Prod.SN : 0
Hardware info=======
HWID : 1000
Batery: 3979 mV
CMT BT: 19e2-47026
LCDVer: TPO
Lock info ===========
IMEI : 352440055303244
IMEI spNet : 3A 25 44 00 55 03 23 04
IMEI svNet : 33 25 44 00 55 03 23 04 F5
Sl Conf : 001-01-00000000000
Sl Prof : 800000000003000-B
Sl Aux : 000B0000
Hw Sig : A5762C19C4B49B0E
Country : Test SIM (Open)
Operator : NOKIA (Open)
Lock info:
Block 1
L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
INFINEON : SuperDongle not exist (It is Ok)
CMLA Key status : Not Present
SimLock status : Ok
Security status : Ok
PA_SL3 phone , SP_CODE_LEN : 15
User Code : 22222
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Phone disconected!
GSM007
Old 09-09-2012, 12:37   #17033 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
6300 unlock Done with infinity best tool thanks
UFS S/N 73225 boot - Ok
Phone found!
read info... - Ok
Connected phone - Nokia 6300
Software ver : V 05.00 27-04-07 RM-217 (c) Nokia.
IMEI : 358648015296704
DSP Ver : pb06w14v51
PPM : V 05.00
27-04-07
RM-217
(c) Nokia.
O
CNT : Content: ora_uk2
V 05.00
27-04-07
RM-217
(c) Nokia.
Product SN : KEQ856460
Product code : 0554371
Base Prd.code: 0537040
Module code : 0203166
HWID : 3007
Retu : 32
Tahvo : 53
Batery: 4870 mV
CMT BT: Error
APE BT: 06cc-P9.1
LCDVer: Error
RF ic : Error
IMEI spNet :
IMEI svNet :
Conf key : 8000000000000006
Provider key : 2343300000000000
Country : United Kingdom
Operator : Orange
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
LOCKS : Closed
User Code : 12345
Done!
Unlock procedure started...
Phone Imei: 358648015296704
Checking locks...
Operator : Orange
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
LOCKS : Closed
PA_SL phone detected...
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006010C192101001101
CMT EM0 ID : 00000232
CMT EM1 ID : 00000353
CMT PUB ID : 2EE0010591416D5613A49110283C3203CDB63F3B
CMT MODE ID : 00
CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID : 191EC665DFAAF68F
CMT : Sending 2nd loader...
CMT Loader sent, Boot Ok
rap= 2EE0010591416D5613A49110283C3203CDB63F3B
hash= BAF3A9C3DBFA8454937DB77F2B8852B1
key= E418356815F8549C5DDFF5FB6084987B98C8E082
Init Service mode... Wait...
Key file updated...
Sending code 353442205771192 Level : 7 to SimLock Server...
Simlock Server Answer: Unlock code Accepted!
Unlock Done!
PPM : V 05.00
27-04-07
RM-217
(c) Nokia.
O
V 05.00
27-04-07
RM-217
(c) Nokia.
HWID : 3007
Retu : 32
Tahvo : 53
Batery: 4778 mV
CMT BT: Error
APE BT: Error
APE HW: Error
RF ic : 17211721
IMEI spNet :
IMEI svNet :
Operator : Orange
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Open
BLK : 2
Lock1:Open
LOCKS : All Open
User Code : 12345
Done!
Phone disconected!
GSM007
Old 09-09-2012, 12:52   #17034 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
X2-02 user lock done
Phone found!
read info... - Ok
SW ver : V 05.29 10-06-11 RM-713 (c) Nokia
IMEI : V 05.29
10-06-11
RM-713
(c) Nokia
PPM :
CNT : V 05.29
10-06-11
RM-713
(c) Nokia
IC
DSP Ver : 9G439
PCode : 358290040926409
BPCode :
HWID : 0204758
LCDVer : 3051
IMEI : V 05.29
10-06-11
RM-713
(c) Nokia
Sl Conf : 424-15-241434F4176
Sl Prof : 38300A4E5433393-1
Sl Aux : 32310000
Hw Sig :
Country : United Arab Emirates
Operator : Unknown
Lock info:
Done!
Check phone mode...
Phone in Local mode
Test mode set
Set OK!
Elapsed: 00:00:11
Phone disconected!
GSM007
Old 09-09-2012, 14:44   #17035 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
X2-02 flashing done
Phone found!
read info... - Ok
SW ver : V 05.44 21-09-11 RM-713 (c) Nokia
IMEI : 359732042684162
PPM : V 05.44
21-09-11
RM-713
(c) Nokia
IJ
PCode : 059G444
BPCode : 059L8X6
HWID : 1000
LCDVer : UNKWN: IDs:
ff:ff:ff
Sl Prof : 000000000003000-2
Sl Aux : 000B0000
Hw Sig : 1735489FAAF28E7A
Lock info:
Block 1
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
Done!
Selected FlashSettings : FullFlash
MCU : rm713_007.510
PPM : rm713_007.51ba
CNT : rm7130_nai07.51ba_mdl
Infineon flashing...
-> Infineon XG110 : IMEI Backup Created
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
PBL : Dynamic
Boot Ok , 01AB
SBL : Dynamic
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH ID : 00EC000000042400
FLASH ID : UNKNOW [Not In Base]
Boot Done!
File : rm713_007.510
Image : hw_b1_rm713_r07.510.fls
Cert sent
Found 3 region(s)
Processing Region 1/3
Erase , Start : 0x00000000 , Len : 0x00020000
Erasing, wait ...
Erase done
Write , Start : 0x00000000 , Len : 0x00006000
Flashing , wait ...
Region flash done
Processing Region 2/3
Erase , Start : 0x00800000 , Len : 0x00400000
Erasing, wait ...
Erase done
Write , Start : 0x00800000 , Len : 0x003F0000
Flashing , wait ...
Region flash done
Processing Region 3/3
Erase , Start : 0x00C5D000 , Len : 0x00203000
Erasing, wait ...
Erase done
Write , Start : 0x00C5D000 , Len : 0x0019E700
Flashing , wait ...
Region flash done
Check : 6AB2
File : rm713_007.51ba
Image : hw_b1_rm713_007.51ba.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00100000 , Len : 0x00700000
Erasing, wait ...
Erase done
Write , Start : 0x00100000 , Len : 0x004A8B80
Flashing , wait ...
Region flash done
Check : E7BA
File : rm7130_nai07.51ba_mdl
Image : hw_b1_rm7130_nai07.51ba_mdl.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00E60000 , Len : 0x00100000
Erasing, wait ...
Erase done
Write , Start : 0x00E60000 , Len : 0x000E65C0
Flashing , wait ...
Region flash done
Check : 722D
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
Error open UFS #73225
Afterflash settings...
SW ver : V 07.51
12-12-11
RM-713
(c) Nokia
PCode : 059G444
FullFactorySet...OK!
SwUpgradeSet...OK!
All done!
GSM007
Old 09-09-2012, 15:15   #17036 (permalink)
dey mobiles's Avatar
Member: 799558
Thanks Meter: 430
E63 RM-437 flashing done
Core : v1.51 , FlashEngine : v1.8Core : v1.51 , FlashEngine : v1.8
MCU : rm437_510.21.010_prd.c00
PPM : rm437_510.21.010_prd.v328_30
CNT : rm437_510.21.010_30.328U
APE : RM437_ENO_008.07.45_100.71.920.a01.fpsx
CNT3 : sofie_erase_y_drive.fpsx
Check files done...
-> SWversion check skipped : Manual mode selected
WMDRM read ... ok
RPL saved : c:\InfinityBox\BEST\Backup\Cert\351502048820187_SI M_2nd.rpl
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
Reboot....
ASIC ID: 000000010000022600010006400C192101031103
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1C10010C8AFD8D52115AFC2517950C24721E1811
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
Boot Done!
TIME : Boot time : 00:00:04
Erase : Processing rm437_510.21.010_prd.c00
Found 3 areas to erase
Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT
Result: 0000
Erasing area 0x00A00000 - 0x0759FFFF, NAND, CMT
Result: 0000
Erasing area 0x0F1C0000 - 0x0F8BFFFF, NAND, CMT
Result: 0000
Partition erase not allowed by loader
Partitioning : Ok [7]
Write : Processing rm437_510.21.010_prd.c00
Total 533 [533/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS*CORE]
CMT : Writing Hash CERT [SOS+ROFS]
TIME : Write time : 00:01:33
MCU Write done
Erase : Processing rm437_510.21.010_prd.v328_30
Erasing area 0x05420000 - 0x0759FFFF, NAND, CMT
Result: 0000
Write : Processing rm437_510.21.010_prd.v328_30
Total 196 [196/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFX]
TIME : Write time : 00:00:36
PPM Write done
Erase : Processing rm437_510.21.010_30.328U
Write : Processing rm437_510.21.010_30.328U
Total 162 [162/0/0] blocks to write, writing...
TIME : Write time : 00:00:31
CNT Write done
Erase : Processing RM437_ENO_008.07.45_100.71.920.a01.fpsx
Write : Processing RM437_ENO_008.07.45_100.71.920.a01.fpsx
Total 16 [16/0/0] blocks to write, writing...
APE Write done
===Flashing [CNT3]===
Erase : Processing sofie_erase_y_drive.fpsx
Erasing area 0x0F020000 - 0x0F1BFFFF, NAND, CMT
Result: 0000
Write : Processing sofie_erase_y_drive.fpsx
No any data for write, skip write
CNT Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:02:44
Reboot phone now...
Connected phone - Nokia E63
Software Info: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia
IMEI: 351xxxxxxxxxxx
Ape Version: 510.21.010
Product code: 0598025
Checking...
Read Info Done!
SwUpgradeSet...OK!
Done!
Elapsed: 00:03:07
Phone found!
read info... - Ok
Old 09-09-2012, 15:18   #17037 (permalink)
Azhar Nazeer's Avatar
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Nokia C5-00 user code
card found: S/N ---------
registered to:--------
Connected phone -    Nokia C5-00
Software ver : V ICPR82_11w16.3.10 13-03-12 RM-745 (c) Nokia
IMEI    :      35-------------
Ape Ver :      091.002
APE Var :      091.002091.002.11.01091.002.C00.01
APE ADSP:      256
DSP Ver :       11w52
APE Test:      rm745_APE_ONLY_ENO_11wk02v0
PPM     :
CNT     :
Product SN   :     3CA337BAA
Product code :     059G750
Base Prd.code:     059F026
Module code  :     0204821
Long Prod.SN :     0
HWID  : 6000
Retu  : 35
Tahvo : 00
Batery: 3916 mV
Camera:
CMT BT:
APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.
APE HW: 256
LCDVer:
RF ic :
IMEI spNet : 3A 15 86 05 35 51 38 06
IMEI svNet : 33 15 86 05 35 51 38 16 F9
Conf key     : 0000000000000000
Provider key : 2440700000000000
Provider    : AT&T;U.S.A. (3650)
Blocks      : 7
LOCK STATUS :
BLK : 1
 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS :  All Open
SDD key status : Ok
SimLock status : Ok
User code : Crypted
UserDataExLevel : Low [Gallery] , FullFlash method
Done!
registered to: -------
Phone found!
read info...  - Ok
IMEI    :      351-------------
Ape Ver :      091.002
APE ADSP:      256
DSP Ver :       11w52
PPM     :
CNT     :
Long Prod.SN :     0
HWID  : 6000
Retu  : 35
Tahvo : 00
Batery: 3905 mV
Camera:
CMT BT:
APE HW: 256
LCDVer:
RF ic :
Blocks      : 7
LOCK STATUS :
BLK : 1
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS :  All Open
SDD key status : Ok
SimLock status : Ok
User code : Crypted
Done!
Searching for MMC pwd...
Generation : [S60]
Check phone mode...
Phone in RfInactive mode
Test mode set
SmartPhone algo initialise...
Setup data...
StartUp FileSystem...
FS run fail, please, remove SD card first
Change phone mode manualy to local/test and try again
If still no luck - phone have damaged FS/SD-MMC part..
Done with major error... :(
Generation : [S60]
Operating mode is OK, no need change...
Setup data...
Phone disconected!
Old 09-09-2012, 15:23   #17038 (permalink)
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Nokia 5233 Read Key
card found: S/N ------------
registered to: --------
Phone found!
read info...  - Ok
Connected phone -    Nokia 5233
Software ver : V ICPR72_10w21.2.1 06-07-10 RM-684 (c) Nokia
IMEI    :      35--------------
Ape Ver :      V 10.0.011
APE Var :      V 10.0.011???10.0.011.218.01
APE ADSP:      256
DSP Ver :       fox_ICPR72_10w16_p2
APE Test:      eno_version
PPM     :
CNT     :
Product SN   :     07210F8AA
Product code :     059D078
Base Prd.code:     0595902
Module code  :     0204597
Long Prod.SN :     0
HWID  : 1000
Retu  : 16
Tahvo : 22
Batery: 3753 mV
Camera:
CMT BT:
APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
APE HW: 256
LCDVer:
RF ic :
IMEI spNet : 3A 35 77 02 54 14 87 07
IMEI svNet : 33 35 77 02 54 14 87 07 F1
Conf key     : 8000000000000000
Provider key : 2680300000000000
Provider    : Optimus;Portugal
Counters   : Key 0  [3] , Fbus 2  [10]
Blocks      : 1
LOCK STATUS :
BLK : 1
 Lock1:Close
LOCKS :  Closed
SDD key status : Ok
SimLock status : Ok
User code : Crypted
Done!
Phone Imei: 35--------------
Checking locks...
Blocks      : 1
LOCK STATUS :
BLK : 1
 Lock1:Close
LOCKS :  Closed
PA_SL3 (15 digit) phone detected...
 - >  Power Off phone, dissconnect it and connect
ASIC ID:       000000010000022600010006400C192101051105
CPU ID :       RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB
PUBLIC ID:     1850001586A00052127D85685B5838546B2C226D
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
Fetching data, wait...
 - > Reinsert cable and battery, press powerOn button again
 - > For X7, E7 - just waiting, near 1 minute
 - > When BEST start Search Phone - Press PowerOn if needed
EM0 ID:        00000296
EM1 ID:        00000B22
ASIC MODE ID:  00
Use URAPIDOv11_2nd.fg  ,  Rev : 2.0  Ver : 11.50.0
FLIC : 004000EC
Req : XSR 1.6
Use URAPIDOv11_XSR17_alg.fg  ,  Rev : 2.0  Ver : 11.50.0
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:00
CFL: Wait for Loader take control  ...
CFL: Check mode
Phone ready, boot Ok
TransReq set Ok
PAPUBkeys : CA158EAEE7D8D7A5B2E4907CB6BD0A9C2794D992
CFL: Close_Session
Content: 000300000000030000000300000000
CFL: Reboot
rap= 1850001586A00052127D85685B5838546B2C226D
hash= B8C3ADECFC997FCD8081D3DEAF870B8C
key= A54437C8966BA7226E64E29D0335F9FD3CC981ED
Key file updated...
Check RSA started...
Check RSA skiped, unknown hash or keys...
Create Log file for local calculation...
File c:\InfinityBox\BEST\Local_calc\35------------7.bcl created - Ok
File c:\InfinityBox\BEST\Local_calc\ighashgpu_35-------------.bat created - Ok
File c:\InfinityBox\BEST\Local_calc\oclHashcat_353---------------_32.bat created - Ok
File c:\InfinityBox\BEST\Local_calc\oclHashcat_35--------------_64.bat created - Ok
Done!
Phone found!
read info...  - Ok
Phone disconected!
Old 09-09-2012, 15:25   #17039 (permalink)
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Nokia 6300 Use code
registered to: ---------
UFS S/N ------------ boot - Ok
Phone found!
read info...  - Ok
Check phone mode...
Phone in Local mode
Test mode set
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Elapsed: 00:00:12
Phone disconected!
Old 09-09-2012, 15:31   #17040 (permalink)
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Nokia 6303i Reading PM
Sending code 538820669242757 Level : 7 to SimLock Server...
Simlock Server Answer: Unlock code Accepted! :)
Done!
Reading PM from field 0 to 400
Field [1]    12 Record(s)
   Record 0: 48 byte(s) readed - Ok
   Record 2: 86 byte(s) readed - Ok
   Record 4: 48 byte(s) readed - Ok
   Record 6: 86 byte(s) readed - Ok
   Record 8: 48 byte(s) readed - Ok
   Record 11: 12 byte(s) readed - Ok
   Record 12: 24 byte(s) readed - Ok
   Record 13: 86 byte(s) readed - Ok
   Record 16: 24 byte(s) readed - Ok
   Record 18: 24 byte(s) readed - Ok
   Record 21: 24 byte(s) readed - Ok
   Record 29: 4 byte(s) readed - Ok
Field [2]    1 Record(s)
   Record 0: 764 byte(s) readed - Ok
Field [3]    1 Record(s)
   Record 0: 2 byte(s) readed - Ok
Field [4]    9 Record(s)
   Record 1: 800 byte(s) readed - Ok
   Record 3: 10 byte(s) readed - Ok
   Record 4: 8 byte(s) readed - Ok
   Record 5: 8 byte(s) readed - Ok
   Record 6: 8 byte(s) readed - Ok
   Record 9: 5 byte(s) readed - Ok
   Record 18: 80 byte(s) readed - Ok
   Record 19: 4 byte(s) readed - Ok
   Record 28: 2 byte(s) readed - Ok
Field [8]    9 Record(s)
   Record 1: 16 byte(s) readed - Ok
   Record 2: 16 byte(s) readed - Ok
   Record 3: 128 byte(s) readed - Ok
   Record 4: 128 byte(s) readed - Ok
   Record 7: 4 byte(s) readed - Ok
   Record 8: 8 byte(s) readed - Ok
   Record 9: 8 byte(s) readed - Ok
   Record 10: 24 byte(s) readed - Ok
Field [11]    70 Record(s)
   Record 0: 4 byte(s) readed - Ok
   Record 1: 4 byte(s) readed - Ok
   Record 2: 4 byte(s) readed - Ok
   Record 3: 4 byte(s) readed - Ok
   Record 4: 1 byte(s) readed - Ok
   Record 5: 6 byte(s) readed - Ok
   Record 6: 2 byte(s) readed - Ok
   Record 7: 1 byte(s) readed - Ok
   Record 8: 1 byte(s) readed - Ok
   Record 9: 1 byte(s) readed - Ok
   Record 10: 2 byte(s) readed - Ok
   Record 11: 2 byte(s) readed - Ok
   Record 12: 2 byte(s) readed - Ok
   Record 13: 2 byte(s) readed - Ok
   Record 14: 16 byte(s) readed - Ok
   Record 15: 32 byte(s) readed - Ok
   Record 16: 32 byte(s) readed - Ok
   Record 17: 2 byte(s) readed - Ok
   Record 18: 2 byte(s) readed - Ok
   Record 19: 2 byte(s) readed - Ok
   Record 20: 2 byte(s) readed - Ok
   Record 21: 2 byte(s) readed - Ok
   Record 22: 2 byte(s) readed - Ok
   Record 23: 2 byte(s) readed - Ok
   Record 24: 2 byte(s) readed - Ok
   Record 25: 2 byte(s) readed - Ok
   Record 26: 2 byte(s) readed - Ok
   Record 27: 2 byte(s) readed - Ok
   Record 29: 2 byte(s) readed - Ok
   Record 30: 2 byte(s) readed - Ok
   Record 31: 2 byte(s) readed - Ok
   Record 32: 2 byte(s) readed - Ok
   Record 33: 2 byte(s) readed - Ok
   Record 34: 2 byte(s) readed - Ok
   Record 35: 2 byte(s) readed - Ok
   Record 36: 2 byte(s) readed - Ok
   Record 37: 2 byte(s) readed - Ok
   Record 38: 2 byte(s) readed - Ok
   Record 39: 2 byte(s) readed - Ok
   Record 40: 2 byte(s) readed - Ok
   Record 41: 2 byte(s) readed - Ok
   Record 42: 2 byte(s) readed - Ok
   Record 43: 2 byte(s) readed - Ok
   Record 44: 2 byte(s) readed - Ok
   Record 45: 2 byte(s) readed - Ok
   Record 46: 2 byte(s) readed - Ok
   Record 47: 2 byte(s) readed - Ok
   Record 48: 2 byte(s) readed - Ok
   Record 49: 2 byte(s) readed - Ok
   Record 50: 2 byte(s) readed - Ok
   Record 51: 2 byte(s) readed - Ok
   Record 52: 2 byte(s) readed - Ok
   Record 53: 2 byte(s) readed - Ok
   Record 54: 2 byte(s) readed - Ok
   Record 55: 2 byte(s) readed - Ok
   Record 56: 2 byte(s) readed - Ok
   Record 57: 2 byte(s) readed - Ok
   Record 58: 2 byte(s) readed - Ok
   Record 59: 2 byte(s) readed - Ok
   Record 60: 2 byte(s) readed - Ok
   Record 61: 2 byte(s) readed - Ok
   Record 62: 4 byte(s) readed - Ok
   Record 63: 4 byte(s) readed - Ok
   Record 64: 4 byte(s) readed - Ok
   Record 65: 4 byte(s) readed - Ok
   Record 66: 16 byte(s) readed - Ok
   Record 67: 4 byte(s) readed - Ok
   Record 68: 2 byte(s) readed - Ok
   Record 69: 242 byte(s) readed - Ok
Field [12]    1 Record(s)
   Record 0: 102 byte(s) readed - Ok
Field [13]    197 Record(s)
   Record 0: 1 byte(s) readed - Ok
   Record 1: 2 byte(s) readed - Ok
   Record 2: 1 byte(s) readed - Ok
   Record 3: 2 byte(s) readed - Ok
   Record 5: 1 byte(s) readed - Ok
   Record 6: 1 byte(s) readed - Ok
   Record 8: 2 byte(s) readed - Ok
   Record 10: 1 byte(s) readed - Ok
   Record 11: 48 byte(s) readed - Ok
   Record 12: 4 byte(s) readed - Ok
   Record 13: 1 byte(s) readed - Ok
   Record 14: 1 byte(s) readed - Ok
   Record 15: 886 byte(s) readed - Ok
   Record 16: 2 byte(s) readed - Ok
   Record 17: 1 byte(s) readed - Ok
   Record 18: 1 byte(s) readed - Ok
   Record 19: 8 byte(s) readed - Ok
   Record 20: 1 byte(s) readed - Ok
   Record 21: 1 byte(s) readed - Ok
   Record 22: 1 byte(s) readed - Ok
   Record 23: 1 byte(s) readed - Ok
   Record 24: 1 byte(s) readed - Ok
   Record 26: 1 byte(s) readed - Ok
   Record 27: 1 byte(s) readed - Ok
   Record 28: 1 byte(s) readed - Ok
   Record 29: 1 byte(s) readed - Ok
   Record 30: 1 byte(s) readed - Ok
   Record 31: 1 byte(s) readed - Ok
   Record 32: 1 byte(s) readed - Ok
   Record 33: 1 byte(s) readed - Ok
   Record 34: 1 byte(s) readed - Ok
   Record 35: 1 byte(s) readed - Ok
   Record 36: 1 byte(s) readed - Ok
   Record 37: 4 byte(s) readed - Ok
   Record 38: 1 byte(s) readed - Ok
   Record 39: 1 byte(s) readed - Ok
   Record 40: 1 byte(s) readed - Ok
   Record 41: 1 byte(s) readed - Ok
   Record 42: 4 byte(s) readed - Ok
   Record 43: 4 byte(s) readed - Ok
   Record 44: 1 byte(s) readed - Ok
   Record 45: 4 byte(s) readed - Ok
   Record 46: 4 byte(s) readed - Ok
   Record 47: 1 byte(s) readed - Ok
   Record 48: 4 byte(s) readed - Ok
   Record 49: 1 byte(s) readed - Ok
   Record 50: 1 byte(s) readed - Ok
   Record 51: 1 byte(s) readed - Ok
   Record 53: 4 byte(s) readed - Ok
   Record 54: 4 byte(s) readed - Ok
   Record 55: 1 byte(s) readed - Ok
   Record 56: 1 byte(s) readed - Ok
   Record 57: 1 byte(s) readed - Ok
   Record 59: 1 byte(s) readed - Ok
   Record 60: 4 byte(s) readed - Ok
   Record 61: 4 byte(s) readed - Ok
   Record 62: 1 byte(s) readed - Ok
   Record 65: 1 byte(s) readed - Ok
   Record 66: 4 byte(s) readed - Ok
   Record 68: 1 byte(s) readed - Ok
   Record 69: 1 byte(s) readed - Ok
   Record 70: 1 byte(s) readed - Ok
   Record 71: 4 byte(s) readed - Ok
   Record 72: 4 byte(s) readed - Ok
   Record 73: 1 byte(s) readed - Ok
   Record 74: 4 byte(s) readed - Ok
   Record 75: 2 byte(s) readed - Ok
   Record 76: 2 byte(s) readed - Ok
   Record 77: 2 byte(s) readed - Ok
   Record 78: 1 byte(s) readed - Ok
   Record 79: 1 byte(s) readed - Ok
   Record 80: 1 byte(s) readed - Ok
   Record 81: 1 byte(s) readed - Ok
   Record 82: 1 byte(s) readed - Ok
   Record 83: 2 byte(s) readed - Ok
   Record 84: 1 byte(s) readed - Ok
   Record 85: 4 byte(s) readed - Ok
   Record 86: 4 byte(s) readed - Ok
   Record 87: 2 byte(s) readed - Ok
   Record 88: 1 byte(s) readed - Ok
   Record 89: 4 byte(s) readed - Ok
   Record 90: 4 byte(s) readed - Ok
   Record 91: 2 byte(s) readed - Ok
   Record 92: 1 byte(s) readed - Ok
   Record 93: 4 byte(s) readed - Ok
   Record 94: 4 byte(s) readed - Ok
   Record 95: 2 byte(s) readed - Ok
   Record 96: 1 byte(s) readed - Ok
   Record 97: 4 byte(s) readed - Ok
   Record 98: 4 byte(s) readed - Ok
   Record 99: 2 byte(s) readed - Ok
   Record 100: 4 byte(s) readed - Ok
   Record 101: 2 byte(s) readed - Ok
   Record 102: 1 byte(s) readed - Ok
   Record 103: 4 byte(s) readed - Ok
   Record 104: 4 byte(s) readed - Ok
   Record 105: 4 byte(s) readed - Ok
   Record 106: 4 byte(s) readed - Ok
   Record 107: 4 byte(s) readed - Ok
   Record 108: 2 byte(s) readed - Ok
   Record 109: 4 byte(s) readed - Ok
   Record 110: 4 byte(s) readed - Ok
   Record 111: 4 byte(s) readed - Ok
   Record 112: 2 byte(s) readed - Ok
   Record 113: 4 byte(s) readed - Ok
   Record 114: 4 byte(s) readed - Ok
   Record 115: 1 byte(s) readed - Ok
   Record 116: 1 byte(s) readed - Ok
   Record 117: 1 byte(s) readed - Ok
   Record 118: 4 byte(s) readed - Ok
   Record 119: 4 byte(s) readed - Ok
   Record 120: 1 byte(s) readed - Ok
   Record 121: 1 byte(s) readed - Ok
   Record 122: 1 byte(s) readed - Ok
   Record 123: 8 byte(s) readed - Ok
   Record 124: 1 byte(s) readed - Ok
   Record 125: 1 byte(s) readed - Ok
   Record 126: 1 byte(s) readed - Ok
   Record 127: 1 byte(s) readed - Ok
   Record 128: 1 byte(s) readed - Ok
   Record 129: 4 byte(s) readed - Ok
   Record 130: 4 byte(s) readed - Ok
   Record 131: 1 byte(s) readed - Ok
   Record 132: 1 byte(s) readed - Ok
   Record 133: 2 byte(s) readed - Ok
   Record 134: 1 byte(s) readed - Ok
   Record 135: 2 byte(s) readed - Ok
   Record 136: 1 byte(s) readed - Ok
   Record 137: 1 byte(s) readed - Ok
   Record 138: 4 byte(s) readed - Ok
   Record 139: 4 byte(s) readed - Ok
   Record 140: 1 byte(s) readed - Ok
   Record 141: 1 byte(s) readed - Ok
   Record 142: 1 byte(s) readed - Ok
   Record 143: 1 byte(s) readed - Ok
   Record 144: 4 byte(s) readed - Ok
   Record 145: 8 byte(s) readed - Ok
   Record 146: 4 byte(s) readed - Ok
   Record 147: 4 byte(s) readed - Ok
   Record 148: 1 byte(s) readed - Ok
   Record 149: 1 byte(s) readed - Ok
   Record 150: 1 byte(s) readed - Ok
   Record 151: 1 byte(s) readed - Ok
   Record 152: 1 byte(s) readed - Ok
   Record 153: 1 byte(s) readed - Ok
   Record 154: 1 byte(s) readed - Ok
   Record 155: 1 byte(s) readed - Ok
   Record 156: 1 byte(s) readed - Ok
   Record 157: 1 byte(s) readed - Ok
   Record 158: 1 byte(s) readed - Ok
   Record 159: 2 byte(s) readed - Ok
   Record 160: 2 byte(s) readed - Ok
   Record 161: 1 byte(s) readed - Ok
   Record 162: 1 byte(s) readed - Ok
   Record 163: 1 byte(s) readed - Ok
   Record 164: 1 byte(s) readed - Ok
   Record 165: 1 byte(s) readed - Ok
   Record 166: 1 byte(s) readed - Ok
   Record 167: 8 byte(s) readed - Ok
   Record 168: 4 byte(s) readed - Ok
   Record 169: 1 byte(s) readed - Ok
   Record 170: 1 byte(s) readed - Ok
   Record 171: 1 byte(s) readed - Ok
   Record 172: 1 byte(s) readed - Ok
   Record 173: 1 byte(s) readed - Ok
   Record 174: 1 byte(s) readed - Ok
   Record 175: 1 byte(s) readed - Ok
   Record 176: 1 byte(s) readed - Ok
   Record 177: 4 byte(s) readed - Ok
   Record 178: 2 byte(s) readed - Ok
   Record 179: 1 byte(s) readed - Ok
   Record 180: 1 byte(s) readed - Ok
   Record 181: 1 byte(s) readed - Ok
   Record 182: 1 byte(s) readed - Ok
   Record 183: 1 byte(s) readed - Ok
   Record 184: 1 byte(s) readed - Ok
   Record 185: 1 byte(s) readed - Ok
   Record 186: 1 byte(s) readed - Ok
   Record 187: 1 byte(s) readed - Ok
   Record 188: 1 byte(s) readed - Ok
   Record 189: 1 byte(s) readed - Ok
   Record 190: 4 byte(s) readed - Ok
   Record 191: 2 byte(s) readed - Ok
   Record 192: 1 byte(s) readed - Ok
   Record 193: 4 byte(s) readed - Ok
   Record 194: 1 byte(s) readed - Ok
   Record 195: 1 byte(s) readed - Ok
   Record 196: 10 byte(s) readed - Ok
Field [24]    1 Record(s)
Field [31]    1 Record(s)
   Record 4: 18 byte(s) readed - Ok
Field [42]    27 Record(s)
   Record 1: 12 byte(s) readed - Ok
   Record 2: 36 byte(s) readed - Ok
   Record 3: 36 byte(s) readed - Ok
   Record 4: 36 byte(s) readed - Ok
   Record 5: 36 byte(s) readed - Ok
   Record 6: 36 byte(s) readed - Ok
   Record 7: 40 byte(s) readed - Ok
   Record 8: 40 byte(s) readed - Ok
   Record 9: 40 byte(s) readed - Ok
   Record 10: 40 byte(s) readed - Ok
   Record 11: 40 byte(s) readed - Ok
   Record 12: 40 byte(s) readed - Ok
   Record 13: 40 byte(s) readed - Ok
   Record 14: 40 byte(s) readed - Ok
   Record 15: 40 byte(s) readed - Ok
   Record 16: 40 byte(s) readed - Ok
   Record 17: 40 byte(s) readed - Ok
   Record 18: 40 byte(s) readed - Ok
   Record 19: 40 byte(s) readed - Ok
   Record 20: 40 byte(s) readed - Ok
   Record 21: 40 byte(s) readed - Ok
   Record 22: 40 byte(s) readed - Ok
   Record 23: 40 byte(s) readed - Ok
   Record 24: 40 byte(s) readed - Ok
   Record 25: 40 byte(s) readed - Ok
   Record 26: 40 byte(s) readed - Ok
Field [44]    1 Record(s)
Field [49]    2 Record(s)
Field [50]    1 Record(s)
Field [54]    2 Record(s)
   Record 2: 24 byte(s) readed - Ok
Field [59]    20 Record(s)
   Record 0: 35 byte(s) readed - Ok
   Record 1: 61 byte(s) readed - Ok
   Record 2: 35 byte(s) readed - Ok
   Record 3: 119 byte(s) readed - Ok
   Record 4: 56 byte(s) readed - Ok
   Record 5: 35 byte(s) readed - Ok
   Record 6: 72 byte(s) readed - Ok
   Record 7: 35 byte(s) readed - Ok
   Record 8: 119 byte(s) readed - Ok
   Record 9: 35 byte(s) readed - Ok
   Record 10: 98 byte(s) readed - Ok
   Record 11: 77 byte(s) readed - Ok
   Record 12: 68 byte(s) readed - Ok
   Record 13: 51 byte(s) readed - Ok
   Record 14: 139 byte(s) readed - Ok
   Record 15: 56 byte(s) readed - Ok
   Record 16: 56 byte(s) readed - Ok
   Record 17: 78 byte(s) readed - Ok
   Record 18: 56 byte(s) readed - Ok
   Record 19: 98 byte(s) readed - Ok
Field [60]    20 Record(s)
   Record 0: 26 byte(s) readed - Ok
   Record 1: 94 byte(s) readed - Ok
   Record 2: 38 byte(s) readed - Ok
   Record 3: 26 byte(s) readed - Ok
   Record 4: 66 byte(s) readed - Ok
   Record 5: 13 byte(s) readed - Ok
   Record 6: 52 byte(s) readed - Ok
   Record 7: 26 byte(s) readed - Ok
   Record 8: 26 byte(s) readed - Ok
   Record 9: 51 byte(s) readed - Ok
   Record 10: 26 byte(s) readed - Ok
   Record 11: 99 byte(s) readed - Ok
   Record 12: 115 byte(s) readed - Ok
   Record 13: 26 byte(s) readed - Ok
   Record 14: 26 byte(s) readed - Ok
   Record 15: 38 byte(s) readed - Ok
   Record 16: 90 byte(s) readed - Ok
   Record 17: 26 byte(s) readed - Ok
   Record 18: 50 byte(s) readed - Ok
   Record 19: 26 byte(s) readed - Ok
Field [61]    20 Record(s)
   Record 1: 119 byte(s) readed - Ok
   Record 3: 35 byte(s) readed - Ok
   Record 4: 35 byte(s) readed - Ok
   Record 5: 77 byte(s) readed - Ok
   Record 6: 56 byte(s) readed - Ok
   Record 7: 144 byte(s) readed - Ok
   Record 8: 35 byte(s) readed - Ok
   Record 9: 135 byte(s) readed - Ok
   Record 10: 119 byte(s) readed - Ok
   Record 11: 35 byte(s) readed - Ok
   Record 12: 35 byte(s) readed - Ok
   Record 13: 35 byte(s) readed - Ok
   Record 14: 35 byte(s) readed - Ok
   Record 15: 35 byte(s) readed - Ok
   Record 16: 35 byte(s) readed - Ok
   Record 17: 76 byte(s) readed - Ok
   Record 18: 35 byte(s) readed - Ok
   Record 19: 35 byte(s) readed - Ok
Field [66]    83 Record(s)
   Record 0: 509 byte(s) readed - Ok
   Record 1: 240 byte(s) readed - Ok
   Record 2: 240 byte(s) readed - Ok
   Record 3: 1 byte(s) readed - Ok
   Record 5: 240 byte(s) readed - Ok
   Record 6: 4 byte(s) readed - Ok
   Record 8: 4 byte(s) readed - Ok
   Record 9: 4 byte(s) readed - Ok
   Record 10: 240 byte(s) readed - Ok
   Record 11: 240 byte(s) readed - Ok
   Record 12: 1 byte(s) readed - Ok
   Record 17: 4 byte(s) readed - Ok
   Record 21: 4 byte(s) readed - Ok
   Record 23: 4 byte(s) readed - Ok
   Record 25: 4 byte(s) readed - Ok
   Record 27: 4 byte(s) readed - Ok
   Record 31: 4 byte(s) readed - Ok
   Record 33: 4 byte(s) readed - Ok
   Record 40: 251 byte(s) readed - Ok
   Record 41: 4 byte(s) readed - Ok
   Record 55: 8 byte(s) readed - Ok
   Record 56: 8 byte(s) readed - Ok
   Record 57: 8 byte(s) readed - Ok
   Record 58: 52 byte(s) readed - Ok
   Record 59: 8 byte(s) readed - Ok
   Record 60: 8 byte(s) readed - Ok
   Record 61: 8 byte(s) readed - Ok
   Record 62: 8 byte(s) readed - Ok
   Record 63: 8 byte(s) readed - Ok
   Record 64: 8 byte(s) readed - Ok
   Record 65: 8 byte(s) readed - Ok
   Record 66: 8 byte(s) readed - Ok
   Record 67: 8 byte(s) readed - Ok
   Record 68: 8 byte(s) readed - Ok
   Record 69: 8 byte(s) readed - Ok
   Record 70: 8 byte(s) readed - Ok
   Record 72: 8 byte(s) readed - Ok
   Record 73: 8 byte(s) readed - Ok
   Record 74: 20016 byte(s) readed - Ok
   Record 75: 6144 byte(s) readed - Ok
   Record 76: 300 byte(s) readed - Ok
   Record 77: 60 byte(s) readed - Ok
   Record 80: 50000 byte(s) readed - Ok
   Record 81: 49 byte(s) readed - Ok
   Record 82: 3 byte(s) readed - Ok
   Record 83: 3 byte(s) readed - Ok
   Record 84: 3 byte(s) readed - Ok
   Record 86: 3 byte(s) readed - Ok
   Record 87: 3 byte(s) readed - Ok
   Record 88: 3 byte(s) readed - Ok
   Record 89: 2 byte(s) readed - Ok
   Record 95: 8 byte(s) readed - Ok
   Record 99: 4 byte(s) readed - Ok
   Record 101: 4 byte(s) readed - Ok
   Record 102: 4 byte(s) readed - Ok
   Record 103: 6 byte(s) readed - Ok
   Record 106: 379 byte(s) readed - Ok
   Record 107: 379 byte(s) readed - Ok
   Record 108: 379 byte(s) readed - Ok
   Record 110: 379 byte(s) readed - Ok
   Record 112: 120 byte(s) readed - Ok
   Record 113: 2 byte(s) readed - Ok
   Record 115: 30 byte(s) readed - Ok
   Record 117: 20 byte(s) readed - Ok
   Record 119: 8 byte(s) readed - Ok
   Record 120: 8 byte(s) readed - Ok
   Record 121: 8 byte(s) readed - Ok
   Record 123: 7 byte(s) readed - Ok
   Record 127: 20246 byte(s) readed - Ok
   Record 129: 20206 byte(s) readed - Ok
   Record 131: 16246 byte(s) readed - Ok
   Record 139: 7 byte(s) readed - Ok
Field [88]    1 Record(s)
   Record 0: 36 byte(s) readed - Ok
Field [96]    2 Record(s)
   Record 1: 20 byte(s) readed - Ok
Field [107]    7 Record(s)
   Record 0: 21 byte(s) readed - Ok
   Record 1: 89 byte(s) readed - Ok
   Record 2: 69 byte(s) readed - Ok
   Record 3: 70 byte(s) readed - Ok
   Record 24: 88 byte(s) readed - Ok
   Record 25: 132 byte(s) readed - Ok
   Record 26: 12 byte(s) readed - Ok
Field [111]    1 Record(s)
Field [116]    17 Record(s)
Field [117]    10 Record(s)
   Record 1: 3 byte(s) readed - Ok
   Record 2: 6 byte(s) readed - Ok
   Record 5: 10 byte(s) readed - Ok
   Record 8: 42 byte(s) readed - Ok
   Record 13: 3 byte(s) readed - Ok
   Record 14: 3 byte(s) readed - Ok
Field [120]    4 Record(s)
   Record 0: 80 byte(s) readed - Ok
   Record 1: 160 byte(s) readed - Ok
   Record 2: 130 byte(s) readed - Ok
   Record 3: 112 byte(s) readed - Ok
Field [153]    6 Record(s)
   Record 0: 68 byte(s) readed - Ok
   Record 1: 68 byte(s) readed - Ok
   Record 2: 68 byte(s) readed - Ok
   Record 3: 68 byte(s) readed - Ok
   Record 4: 68 byte(s) readed - Ok
   Record 5: 68 byte(s) readed - Ok
Field [163]    1 Record(s)
   Record 0: 8 byte(s) readed - Ok
Field [193]    4 Record(s)
   Record 2: 8 byte(s) readed - Ok
   Record 3: 32 byte(s) readed - Ok
   Record 4: 32 byte(s) readed - Ok
   Record 9: 64 byte(s) readed - Ok
Field [202]    1 Record(s)
Field [217]    1 Record(s)
   Record 0: 32 byte(s) readed - Ok
Field [218]    1 Record(s)
Field [232]    3 Record(s)
   Record 0: 20 byte(s) readed - Ok
Field [238]    1 Record(s)
   Record 1: 1 byte(s) readed - Ok
Field [239]    10 Record(s)
   Record 1: 3072 byte(s) readed - Ok
   Record 2: 3072 byte(s) readed - Ok
   Record 3: 3072 byte(s) readed - Ok
   Record 4: 3072 byte(s) readed - Ok
   Record 5: 3072 byte(s) readed - Ok
   Record 6: 3072 byte(s) readed - Ok
   Record 7: 3072 byte(s) readed - Ok
   Record 8: 3072 byte(s) readed - Ok
   Record 9: 3072 byte(s) readed - Ok
Field [250]    4 Record(s)
   Record 1: 2172 byte(s) readed - Ok
   Record 2: 128 byte(s) readed - Ok
   Record 3: 742 byte(s) readed - Ok
   Record 4: 40 byte(s) readed - Ok
Field [301]    17 Record(s)
Field [308]    9 Record(s)
   Record 1: 8192 byte(s) readed - Ok
Field [309]    6 Record(s)
   Record 2: 12 byte(s) readed - Ok
   Record 4: 12 byte(s) readed - Ok
   Record 7: 12 byte(s) readed - Ok
   Record 17: 12 byte(s) readed - Ok
Field [320]    39 Record(s)
   Record 0: 148 byte(s) readed - Ok
   Record 1: 148 byte(s) readed - Ok
   Record 2: 148 byte(s) readed - Ok
   Record 3: 148 byte(s) readed - Ok
   Record 4: 148 byte(s) readed - Ok
   Record 5: 148 byte(s) readed - Ok
   Record 6: 148 byte(s) readed - Ok
   Record 7: 148 byte(s) readed - Ok
   Record 8: 148 byte(s) readed - Ok
   Record 9: 148 byte(s) readed - Ok
   Record 10: 148 byte(s) readed - Ok
   Record 11: 148 byte(s) readed - Ok
   Record 12: 148 byte(s) readed - Ok
   Record 13: 148 byte(s) readed - Ok
   Record 14: 148 byte(s) readed - Ok
   Record 15: 148 byte(s) readed - Ok
   Record 16: 148 byte(s) readed - Ok
   Record 17: 148 byte(s) readed - Ok
   Record 18: 148 byte(s) readed - Ok
   Record 19: 148 byte(s) readed - Ok
   Record 20: 148 byte(s) readed - Ok
   Record 21: 148 byte(s) readed - Ok
   Record 22: 148 byte(s) readed - Ok
   Record 23: 148 byte(s) readed - Ok
   Record 24: 148 byte(s) readed - Ok
   Record 25: 148 byte(s) readed - Ok
   Record 26: 148 byte(s) readed - Ok
   Record 27: 148 byte(s) readed - Ok
   Record 28: 148 byte(s) readed - Ok
   Record 29: 148 byte(s) readed - Ok
   Record 30: 148 byte(s) readed - Ok
   Record 31: 148 byte(s) readed - Ok
   Record 32: 148 byte(s) readed - Ok
   Record 33: 148 byte(s) readed - Ok
   Record 34: 148 byte(s) readed - Ok
   Record 35: 148 byte(s) readed - Ok
   Record 36: 148 byte(s) readed - Ok
   Record 37: 148 byte(s) readed - Ok
   Record 38: 148 byte(s) readed - Ok
Field [322]    1 Record(s)
Field [325]    20 Record(s)
   Record 0: 38 byte(s) readed - Ok
   Record 1: 26 byte(s) readed - Ok
   Record 2: 26 byte(s) readed - Ok
   Record 3: 39 byte(s) readed - Ok
   Record 4: 26 byte(s) readed - Ok
   Record 5: 27 byte(s) readed - Ok
   Record 6: 39 byte(s) readed - Ok
   Record 8: 67 byte(s) readed - Ok
   Record 9: 26 byte(s) readed - Ok
   Record 10: 125 byte(s) readed - Ok
   Record 11: 26 byte(s) readed - Ok
   Record 12: 112 byte(s) readed - Ok
   Record 13: 53 byte(s) readed - Ok
   Record 14: 25 byte(s) readed - Ok
   Record 15: 26 byte(s) readed - Ok
   Record 16: 26 byte(s) readed - Ok
   Record 17: 68 byte(s) readed - Ok
   Record 18: 46 byte(s) readed - Ok
Field [334]    1 Record(s)
Field [339]    2 Record(s)
   Record 0: 511 byte(s) readed - Ok
   Record 1: 511 byte(s) readed - Ok
Field [341]    3 Record(s)
   Record 4: 4408 byte(s) readed - Ok
Field [345]    1 Record(s)
   Record 0: 12 byte(s) readed - Ok
Field [354]    1 Record(s)
   Record 0: 3 byte(s) readed - Ok
Field [356]    2 Record(s)
   Record 1: 8 byte(s) readed - Ok
Field [362]    2 Record(s)
   Record 1: 120 byte(s) readed - Ok
Field [364]    27 Record(s)
Field [365]    17 Record(s)
Saved as C:\InfinityBox\BEST\Backup\RM-443 Nokia 6303 classic_35---------------_0_400.pm
Done!
Elapsed: 00:00:06
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.86533 seconds with 10 queries
