12-28-2011, 10:01 | #15076 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 61
Member: 4813 Status: Offline Thanks Meter: 401 | Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_21.1.004_prd.core.C00 PPM : RM-625_21.1.004_prd.rofs2.V05 PPM2 : RM-625_21.1.004_C01_prd.rofs3.fpsx CNT : RM-625_21.1.004_001_000_U001.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 21.1.004 Phone version : V 21.1.004 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\352715045665616_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3796 mV -> Batery voltage less, than 3,8V (3796mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0BF00007EF9E00523EED09641F05A8C28C2AD0FF ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-625_21.1.004_prd.core.C00 Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.004_prd.core.C00 Total 387 [387/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:27 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-625_21.1.004_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x06CE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.004_prd.rofs2.V05 Total 110 [110/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-625_21.1.004_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.004_C01_prd.rofs3.fpsx Total 28 [28/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-625_21.1.004_001_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.004_001_000_U001.uda.fpsx Total 23 [23/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5228 Software Info: V ICPR72_10w21 26-05-10 RM-625 (c) Nokia IMEI: 352715045665616 Ape Version: V 21.1.004 Product code: 059C6J4 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:11 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following User Says Thank You to raychevski For This Useful Post: |
12-28-2011, 12:55 | #15077 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1635037 Status: Offline Sonork: 1590479 Thanks Meter: 41 | Vodafone-547 unlock done by Infinity .with testpinout COM3 [VCP0] selected module v4.12 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-547 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: VF_GER_DE_P107A4V1.2.0B05 Version: 09AZTENJ35_09A 83 byte(s) read imei: 35962103xxxxxxx connection Ok 189 byte(s) read reading data... reading data #2... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 17 sec Remove/Install battery now ! |
The Following User Says Thank You to USMAN KUNJAH For This Useful Post: |
12-28-2011, 15:25 | #15078 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Tanzania Age: 62
Member: 22542 Status: Offline Sonork: 100.1660285 Thanks Meter: 102 | FLASHED OK NOKIA E72 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core version : 1.33 Rev : 1.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm530_081.003_prd.core.fpsx PPM : rm530_081.003_40.01_APAC_QW1_prd.rofs2.fpsx CNT : rm530_081.003_U007.000_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 29E000132DD903447D4F5A397038D4D8772A5856 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.40.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.40.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 660D81A4455F6F7F9B81D5D10F5336B14B50635E ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357895045662667 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357895045662667_2n d.rpl ===Flashing [MCU]=== Erase : Processing rm530_081.003_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm530_081.003_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 454 blocks TIME : Write time : 00:00:19 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm530_081.003_40.01_APAC_QW1_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm530_081.003_40.01_APAC_QW1_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 271 blocks TIME : Write time : 00:00:12 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm530_081.003_U007.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm530_081.003_U007.000_prd.uda.fpsx Total writen 55 blocks TIME : Write time : 00:00:04 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:40 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E72-1 Software Info: V ICPR82_11w16.3.4 17-08-11 RM-530 (c) Nokia IMEI: 357895045662667 Ape Version: 081.003 Product code: 0587265 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:01 Connect phone on selected interface... |
The Following User Says Thank You to benny Haraba For This Useful Post: |
12-28-2011, 17:21 | #15079 (permalink) |
No Life Poster Join Date: Oct 2011 Location: gsmsection
Member: 1678945 Status: Offline Sonork: 100.1620753 Thanks Meter: 107 | COM4 [VCP0] selected module v1.34 Device: Sony-Ericsson-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 208814FFFFFFFF:20881400000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb software version: 102A-000 software version: MLD-5- Check hardware done Read data ... reading Sony-Ericsson-J110i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J110i_eeprom_calibration-1_20111228-161929.6AE.bin Read data done Check data ... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user error: not locked or unknown eeprom Check data done Write ... .........data prepared Ok flash: 208814FFFFFFFF:20881400000000 Write: eeprom Write done Finished, time used: 53 sec Remove/Install battery now ! |
The Following User Says Thank You to unlock_allgsm For This Useful Post: |
12-29-2011, 02:07 | #15080 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | COM3 [VCP1] selected module v4.12 Device: Alcatel-363X, 363A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:A0EC:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Boxes\InfinityBox\MModule\backup_security\id.20 27D161.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_B83E3364].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 2027D161 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, 64333EB8 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 26G provider: 363X-2AVDES1 customization: CI26DH35 customization: XI26DH35 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI26DH35 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Boxes\InfinityBox\MModule\backup_security\Alcat el-363X,363A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__system_log_2027D161_B83E3364_2011 1228-122139.B0X.bin Finished, time used: 2 min 42 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to hvalero2001 For This Useful Post: |
12-29-2011, 04:05 | #15081 (permalink) |
Freak Poster Join Date: Oct 2006 Location: United States
Member: 376302 Status: Offline Thanks Meter: 30 | Blu Q210 user code reset Removed user code OK select, Blu Q200 and make format secured FFS COM133 [VCP0] selected module v4.01 Action: reset settings ("format ffs") Model: Blu-Q200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot Off chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: X221_6B_DB_CV2_V210_101028 Version: HEXING53_09A_GEMINI_HW ==================== New firmware found (v.4.01, database date: 19.08.2011): X221_6B_DB_CV2_V210_101028 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: 35488204777329 connection Ok warning: wrong packet cs building list... done items to clear: 192 warning: wrong packet cs items cleared: 126 of 192 items remains: 0 Finished, time used: 5 min 30 sec Remove/Install battery now ! |
The Following User Says Thank You to ramon9622 For This Useful Post: |
12-29-2011, 08:32 | #15082 (permalink) |
No Life Poster Join Date: Jun 2007 Location: INDIA
Member: 530721 Status: Offline Thanks Meter: 157 | COM12 [QCUSB_COM12_1] selected module v1.71 Device: ZTE-S1602 operation: SP-unlock Phone should be Switched ON ! connecting... Nov 26 2010 Nov 26 2010 your phone version not supported yet or try again.. trying using nv unlock for 1602... conecting... ESN(hex) : 802F9C5A ESN(hex) : 802F9C5A disabling minlock... done... Phones should be restarting now... Finished, time used: 4 sec |
12-29-2011, 09:00 | #15083 (permalink) |
Member: 4813 Status: Offline Thanks Meter: 401 | Core version : 1.33 Rev : 1.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm243_07.02_prd_core.fpsx PPM : rm243_07.02_prd_vB05_01_russian.fpsx CNT : rm243_ENO_A_2009wk15v0.100.fpsx APE : rm243_07.02_prd_UDA_Nokia_Noir.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 07.02 Phone version : 06.51 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok SimLock Data saved... SimLock Key saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\355201037048100_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1880000745108B52F674792FD8912CBBF7591673 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm243_07.02_prd_core.fpsx Found 3 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT Result: 0000 Erasing area 0x00B80000 - 0x04DFFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing rm243_07.02_prd_core.fpsx Total 404 [404/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:10 MCU Write done ===Flashing [PPM]=== Erase : Processing rm243_07.02_prd_vB05_01_russian.fpsx Found 1 areas to erase Erasing area 0x03300000 - 0x04DFFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.02_prd_vB05_01_russian.fpsx Total 199 [199/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:41 PPM Write done ===Flashing [CNT]=== Erase : Processing rm243_ENO_A_2009wk15v0.100.fpsx Found 1 areas to erase Erasing area 0x00880000 - 0x00B7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_ENO_A_2009wk15v0.100.fpsx Total 18 [18/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 CNT Write done ===Flashing [APE]=== Erase : Processing rm243_07.02_prd_UDA_Nokia_Noir.fpsx Found 1 areas to erase Erasing area 0x04E00000 - 0x07B3FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.02_prd_UDA_Nokia_Noir.fpsx Total 1 [1/0/0] blocks to write, writing... TIME : Write time : 00:00:00 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:55 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6120 Software Info: V 07.02 18-05-09 RM-243 (c) Nokia IMEI: 355201037048100 Ape Version: 07.02 Product code: 0550022 Checking... SimLock status : Can't get status Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:02:22 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
12-29-2011, 15:36 | #15084 (permalink) |
Member: 530721 Status: Offline Thanks Meter: 157 | COM5 [sacumdm0] selected module v1.71 Device: Samsung-SCH-B159 operation: DE-26 (red) boot unlock (Force mode) Phone should be Switched ON ! connecting... dm mode... erasing... patching... patching done... Finished, time used: 7 sec |
The Following User Says Thank You to Sandeep Mobiles For This Useful Post: |
12-29-2011, 15:43 | #15085 (permalink) |
Member: 4813 Status: Offline Thanks Meter: 401 | Core version : 1.35 Rev : 1.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm243_07.02_prd_core.fpsx PPM : rm243_07.02_prd_vB05_01_russian.fpsx CNT : rm243_ENO_A_2009wk15v0.100.fpsx APE : rm243_07.02_prd_UDA_Nokia_Noir.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 07.02 Phone version : 06.01 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok SimLock Data saved... SimLock Key saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\356252019778957_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101021103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1B000206116E00585A96017B9E4FCD95E3DCCE7D ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm243_07.02_prd_core.fpsx Found 3 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT Result: 0000 Erasing area 0x00B80000 - 0x04DFFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing rm243_07.02_prd_core.fpsx Total 404 [404/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:00:58 MCU Write done ===Flashing [PPM]=== Erase : Processing rm243_07.02_prd_vB05_01_russian.fpsx Found 1 areas to erase Erasing area 0x03300000 - 0x04DFFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.02_prd_vB05_01_russian.fpsx Total 199 [199/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:34 PPM Write done ===Flashing [CNT]=== Erase : Processing rm243_ENO_A_2009wk15v0.100.fpsx Found 1 areas to erase Erasing area 0x00880000 - 0x00B7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_ENO_A_2009wk15v0.100.fpsx Total 18 [18/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 CNT Write done ===Flashing [APE]=== Erase : Processing rm243_07.02_prd_UDA_Nokia_Noir.fpsx Found 1 areas to erase Erasing area 0x04E00000 - 0x07B3FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.02_prd_UDA_Nokia_Noir.fpsx Total 1 [1/0/0] blocks to write, writing... TIME : Write time : 00:00:00 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:36 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6120 Software Info: V 07.02 18-05-09 RM-243 (c) Nokia IMEI: 356252019778957 Ape Version: 07.02 Product code: 0554046 Checking... SimLock status : Can't get status Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:02:01 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
12-29-2011, 17:20 | #15086 (permalink) |
Junior Member Join Date: Oct 2005 Location: Poland,Wloclawek
Member: 194290 Status: Offline Thanks Meter: 10 | COM9 selected module v4.13 Action: read unlock codes unlock method: read codes Model: Huawei-G6603 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8C00:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235C,E00 Date: 2000.00.00 Version: 1.0 Version: E5.2EU01V01.04 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 3535370416xxxx connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 177 byte(s) read reading data... 972 byte(s) read lock[1] code: + 59340403 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 13 sec Remove/Install battery now ! |
The Following User Says Thank You to grzyb_26 For This Useful Post: |
12-30-2011, 08:16 | #15087 (permalink) |
Crazy Poster Join Date: Nov 2010 Location: City Centre
Member: 1451726 Status: Offline Thanks Meter: 13 | LG RD3510 unlock LG RD3510 unlock OFFLINE... sending boot... sending command... patching in progress... patching in progress 30%... patching in progress 60%... patching in progress 99%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
The Following User Says Thank You to 7seas For This Useful Post: |
12-30-2011, 10:39 | #15088 (permalink) |
No Life Poster Join Date: May 2007 Location: india
Member: 500302 Status: Offline Thanks Meter: 157 | nokia c7 flash ok with best........... card found: S/N 01F9**** registered to: wasim007 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C7-00 Software ver : V 92_11w29 20-07-11 RM-675 (c) Nokia IMEI : 3553790***** Ape Ver : 024.001 APE Var : 024.001024.001.02.01024.001.220.01 APE ADSP: 256 DSP Ver : 92_11w29 APE Test: rm675_ENO_v_0.0491 PPM : CNT : Product SN : CJP309330 Product code : 059D335 Base Prd.code: 0591401 Module code : 0204505 Long Prod.SN : 0 Hardware info======= HWID : 6010 Retu : 40 Tahvo : 00 Batery: 4073 mV Camera: CMT BT: APE BT: HCI Version 20 (rev. 64). LMP Version 44 (rev. 64). Manufacturer 2016. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 355379042***** IMEI spNet : 3A 55 73 09 24 36 25 04 IMEI svNet : 33 55 73 09 24 36 25 14 F9 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Core version : 1.35 Rev : 1.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-675_024.001_79.92_prd.core.fpsx PPM : RM-675_024.001_02.01_Euro2_79.92_prd.rofs2.fpsx PPM2 : RM-675_024.001_220.01_default_79.92.2011.30_prd.rofs3 .fpsx CNT : RM-675_024.001_220.01_default_79.92.2011.30.uda.fpsx APE : rm675_ENO_v_0.0491_APEONLY.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 024.001 Phone version : 024.001 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 0B7000160FA70344FCB63726BD9A14884E372BA7 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 006800EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 355379042635242 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\35537904*****.rpl ===Flashing [MCU]=== Erase : Processing RM-675_024.001_79.92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing RM-675_024.001_79.92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 516 blocks TIME : Write time : 00:04:16 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-675_024.001_02.01_Euro2_79.92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-675_024.001_02.01_Euro2_79.92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 201 blocks TIME : Write time : 00:01:36 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-675_024.001_220.01_default_79.92.2011.30_prd.rofs3 .fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-675_024.001_220.01_default_79.92.2011.30_prd.rofs3 .fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-675_024.001_220.01_default_79.92.2011.30.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing RM-675_024.001_220.01_default_79.92.2011.30.uda.fpsx Total writen 595 blocks TIME : Write time : 00:05:00 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [APE]=== Erase : Processing rm675_ENO_v_0.0491_APEONLY.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm675_ENO_v_0.0491_APEONLY.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 19 blocks TIME : Write time : 00:00:08 APE Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:11:07 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C7-00 Software Info: V 92_11w29 20-07-11 RM-675 (c) Nokia IMEI: 355379042635242 Ape Version: 024.001 Product code: 059D335 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done ;D Done! |
The Following 2 Users Say Thank You to Wasim007 For This Useful Post: |
12-30-2011, 11:43 | #15089 (permalink) |
Member: 4813 Status: Offline Thanks Meter: 401 | Core version : 1.35 Rev : 1.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__09.10.mcusw PPM : rm443__09.10.ppm_i CNT : rm443__09.10.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> Check SW version... FlashFile version : 09.10 Phone version : 09.10 25-08-09 RM-443 (c) Nokia -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358256033108776_SI M_2nd.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 25000201648E8C560E417F5023145158952E3513 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm443__09.10.image_i_bg_ua_matt_black ConvertImage: Page Size is 128K, no need convert Loader len: 427648, CHK: D62E ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:09 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__09.10.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:08 Write : Processing rm443__09.10.mcusw Total 1594 [1594/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:00 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__09.10.ppm_i Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:09 Write : Processing rm443__09.10.ppm_i Total 424 [424/0/0] blocks to write, writing... TIME : Write time : 00:00:16 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__09.10.image_i_bg_ua_matt_black Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:48 Write : Processing rm443__09.10.image_i_bg_ua_matt_black Total 896 [896/0/0] blocks to write, writing... TIME : Write time : 00:00:34 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:58 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 09.10 25-08-09 RM-443 (c) Nokia IMEI: 358256033108776 PPM version : V 09.10 25-08-09 RM-443 (c) Nokia I Product code: 0589183 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:11:18 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
12-30-2011, 16:48 | #15090 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Core version : 1.33 Rev : 1.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-684_30.0.002_prd.core.C00 PPM : RM-684_30.0.002_prd.rofs2.V12 PPM2 : RM-684_30.0.002_C01_prd.rofs3.fpsx CNT : RM684_30.0.002_000_000_U001.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 22100117F6BD0052C628F44F67653704C23D5803 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-684_30.0.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0A55FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-684_30.0.002_prd.core.C00 Total 374 [374/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:27 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-684_30.0.002_prd.rofs2.V12 Found 1 areas to erase Erasing area 0x069A0000 - 0x0945FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-684_30.0.002_prd.rofs2.V12 Total 86 [86/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:06 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-684_30.0.002_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09460000 - 0x0A55FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-684_30.0.002_C01_prd.rofs3.fpsx Total 16 [16/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM684_30.0.002_000_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x0A560000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM684_30.0.002_000_000_U001.uda.fpsx Total 68 [68/0/0] blocks to write, writing... TIME : Write time : 00:00:07 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:44 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5250 Software Info: V ICPR72_11w10.1 15-03-11 RM-684 (c) Nokia IMEI: 358619041250445 Ape Version: V 30.0.002 Product code: 059B440 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:01:08 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 22100117F6BD0052C628F44F67653704C23D5803 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 11.40.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done Boot error... Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO If RAPIDO - use dead mode for read rpl/force local SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.34\Backup\Cert\3586 19041250445_SIM_2nd.rpl Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
