Off Topic Zone Here all other messages... |
05-27-2003, 10:48 | #2 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Gran Canaria
Member: 10087 Status: Offline Thanks Meter: 2 | Hi, I don't know how to proceed in that specific model, but in general, if you open the computer, remove the internal battery (a small circular battery) and then plug it again, you have cleared CMOS values. So the bios would not ask you for password anymore, but also the values stored on bios will reset to factory default, so check them carefully. I know that some models have master codes or some other tricks to bring down the bios passwords, but for that specific subject just search the www, looking for that subject in users forums. What I told you works in all computers, but you must know the configuration of the computer and the hardware devices available in order to set properly the bios once it is reseted to factory defaults. Regards, Nylus. |
05-27-2003, 13:41 | #4 (permalink) |
Member: 10087 Status: Offline Thanks Meter: 2 | This method also works for notebooks. I did it successfully in two Acer, one HP and two "no-name" notebooks (withour brand, just oem). But the problem with this method is that you must disassemble de computer, by removing the keyboard, and depending on the model, some pieces more. So, search first, 'cos maybe you can find a way to do it without opening. Regards, Nylus. |
05-27-2003, 21:35 | #6 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Be Age: 48
Member: 3081 Status: Offline Thanks Meter: 8 | Ok here is what you have to do Open the PC find the eeprom, it must be an 24CXX, desolder the eeprom read it and make backup and then reprogram the eeprom only with FFFFFFFFFF inside, full of FFFF's. Solder the eeprom back, but before doing that be shure you removed the backup batery also, othewise all this trouble vas made for nothing. Power on the pc and you will get some errors, just ignore them, and at one certain point the computer will say, Default values res tored, accept or ignore, hit Accept and that's it. Regards Fludor |
06-01-2003, 15:24 | #7 (permalink) |
Junior Member Join Date: May 2003 Location: France Age: 54
Member: 30168 Status: Offline Thanks Meter: 0 | Hello Guys, i've a toshiba Portege3490 and i 've the same problem. But when you remove the battery backup inside, it's not be cleared.$ Do you know a method for remove the password? |
06-01-2003, 23:37 | #8 (permalink) | |
No Life Poster Join Date: Aug 2000 Location: anywhere
Member: 1879 Status: Offline Sonork: 100.28016 Thanks Meter: 941 | Re: Compaq Armada E500 bios password help Quote:
desolder eeprom(should be 24cxx or similar), read it and modify ONE BYTE of the ee content(but DO NOT change the service tag id!!), save it and write it back. this will cause a checksum error and you will be able to reset the bios settings incl. the password. enjoy... regards, | |
06-02-2003, 12:54 | #9 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | There is software called password recovery....It can help but not in all cases... If this fails, then use "brute force" methods from above... For software, just search net for it, it's free... BR Vule |
06-02-2003, 15:56 | #10 (permalink) |
Freak Poster Join Date: Nov 2000 Location: Czech Republic
Member: 2558 Status: Offline Thanks Meter: 5 | danywilde: If you make a simple device that you connect to your parallel port, a lot of Toshiba computers remove the password when you boot it up. The device, named "loopback" by some, could be made out of any parallel wire with 25pins connectors. You should connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15 |
06-25-2003, 23:27 | #11 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Tunisia Age: 53
Member: 11254 Status: Offline Thanks Meter: 3 | check this very inter www.11a.nu for your compaq but can any one in this forum help me for my hp omnibook xe3 model thiks |
06-26-2003, 00:10 | #12 (permalink) |
No Life Poster Join Date: Apr 2001 Age: 41
Member: 4120 Status: Offline Thanks Meter: 70 | for compaq is easy remove bios batt from inside then remove laptop batt then leave for 10 mins and connect charger without both batts and reboot and whoops no pass this works for all compaq up to latest cheers )) TeSTeD bY sPUnlOcK |
Bios password on HP Compaq TC4400 | Burnt Cobba | Off Topic Zone | 6 | 02-01-2009 10:54 |
Bios Password for HP Compaq nx 9005 | gsm-decode | Off Topic Zone | 9 | 03-20-2004 07:32 |
bios password on compaq? | SilentKiller | Off Topic Zone | 3 | 10-06-2003 09:49 |
dct4 flasher hardlock ( dongle lpt + usb) not working on laptop Compaq Armada m700 :( | GYZMO | Nokia Digital Core Technology 4 ( DCT-4 ) | 13 | 08-18-2003 11:01 |
hp omnibook 510 bios password help | ejays | Off Topic Zone | 4 | 07-01-2003 01:55 |
