Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 06-14-2009, 21:57   #1 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
★★★ PolarBox : FAQS & HELP ★★★
Download and Install Area (for new users)
> How to install PolarBox2 Suite (in 3 easy steps) <
STEP 1)
First of all, download and install this software (Last PolarBox2 software)
Be sure you not have connected box, because at this step is not necesary
PolarBox2 Installer for METAL VERSION (all drivers inside)
PolarBox2 Installer for PLASTIC VERSION (all drivers inside)
STEP 2)
After software has been properly installed, please plug your PolarBox2 in your computer and wait till windows request drivers (start detection). When your system start to ask you for drivers, select correct path in your computer.
Example (english windows) : C:\Program Files\Polar Box\Drivers
Example (spanish windows) : C:\Archivos de programa\Polar Box\Drivers
Windows will finish detection and installing of drivers, and will confirm you in few seconds, now your box is installed.
STEP 3)
At this step, box and drivers are properly installed but in order to use server services you need make a last step.
This process is the "Box Registration" and not takes excesive time (only few seconds)
Now run POLAR-SAT software (already installed) and go to
SETUP Fill this form with all your details and confirm it. After this, your PolarBox2 is registered, process is in real time and you not will receive any mail of confirmation.
VERY IMPORTANT !!!
Please, try to have always installed our last update version
Server only works properly with last versions of software, then keep you informed and install it every update
For last versions execute POLAR-SAT and press SUPPORT FILE SERVER button (you will access to download area)
Now, enjoy your PolarBox2 :-)
Thanks in advance for your attention,
With best regards,
[ Polar Team ]
[ Http://www.polarbox2.net ]
[ Http://www.nano-box.eu ]
[ Http://www.bb-box.net ]
[ Http://www.polarteam.net ]
[ Http://www.auto-polar.com ]
HOW TO MAKE A SCREEN CAPTURE
1: use ur keyboard button
2: open windows paint and paste ur image
3: save ur image
4: final step
br
<= The_Gorr =>
The Following 11 Users Say Thank You to The_Gorr For This Useful Post:
Old 06-14-2009, 22:08   #2 (permalink)
The_Gorr's Avatar
Member: 145648
How to upload image on forum
HOW TO UPLOAD IMAGE ON FORUM
1: go to http://photobucket.com and make registration
2: after registration, login to ur account and enter to my albums
3: clic on choose file and select ur image
4: wait until image will be uploaded to web site
5: after success upload, clic on return to album
6: now copy ur image link (direct link)
7: make a new post in forum and insert ur image direct link
8: final step, now ur post is ok with ur image
The Following 13 Users Say Thank You to The_Gorr For This Useful Post:
Old 06-14-2009, 22:16   #3 (permalink)
The_Gorr's Avatar
Member: 145648
HOW TO MAKE UNSUPPORTED PHONE, SUPPORTED BY POLAR BOX
1- GIVE US PHONE MODEL
2- GIVE US PHONE INFOS
3- READ FULL FLASH AND UPLOAD TO RAPID SHARE
4- POST UR RAPID SHARE LINK
EXEMPLE
The Following 8 Users Say Thank You to The_Gorr For This Useful Post:
Old 06-14-2009, 22:20   #4 (permalink)
The_Gorr's Avatar
Member: 145648
U CAN'T ENTER TO SUPPORT USING POLAR SUITE !! THEN HOW TO ENTER !!
1- RUN SAT
2- SELECT SUPPORT - FORUMS
3- CLIC SOFTWARE, UPDATES ... TO ENTER DIRECTLY TO SUPPORT
The Following 10 Users Say Thank You to The_Gorr For This Useful Post:
Old 06-14-2009, 22:23   #5 (permalink)
The_Gorr's Avatar
Member: 145648
U HAVE ERROR File System Not Found WHEN U INSTALL LAST UPDATE ?
1- GO TO THIS LINK HERE
2- DOWNLOAD AND INSTALL LAST INSTALLER V17
3- DOWNLOAD AND INSTALL LAST UPDATE
4- ALL IS OK NOW
The Following 7 Users Say Thank You to The_Gorr For This Useful Post:
Old 06-14-2009, 22:34   #6 (permalink)
The_Gorr's Avatar
Member: 145648
★★★ How to register PolarBox2 / Download Last Update/Download and Install Area
ALL DOWNLOAD SUPPORT LINK
HERE:http://www.fileserve.com/list/qkhv22x
The Following 29 Users Say Thank You to The_Gorr For This Useful Post:
Old 06-14-2009, 22:39   #7 (permalink)
The_Gorr's Avatar
Member: 145648
HOW TO ENTER UNLOCK CODE IN SAMSUNG I900 OMNIA
> 1. Insert an unaccepted SIM card
> 2. Enter the pin code to simcard
> 3. At the top of screen an "exclamation mark" icon will appear
> 4. Click on "exclamation mark" icon
> 5. There will appear link "settings" - click on it
> 6. Virtual keyboard appears on screen with Enter PIN prompt.
> 7. Enter your 8-digit unlock code
It does not show an exclamation mark, but a lock simbol with the
letters NET; this comes with the following notification:
Network lock", and the options: "OK"; "dismiss".
When I press OK, it gives me the virtual keyboard: then I insert the
code and it works.
Old 06-14-2009, 22:42   #8 (permalink)
The_Gorr's Avatar
Member: 145648
alcatel s920 / s920x can't be detected by polar and computer not ask for drivers
1- just remove ur memory card from phone
2- plug ur usb cable again
3- install drivers
Old 06-14-2009, 22:44   #9 (permalink)
The_Gorr's Avatar
Member: 145648
SOME PHONES CAN'T BE DETECTED BY POLAR USING USB CABLES
1- be sure only polar is connected to ur computer (no other dongle or box)
2- change phone port number to any number under 10
Old 06-14-2009, 22:48   #10 (permalink)
The_Gorr's Avatar
Member: 145648
I USED SOLDERING WIRES (RX, TX, GND) NOW MY BOX IS DAMAGED POLAR SOFTWARE CAN'T RUN / OR CAN'T CONNECT PHONES ANY MORE
I HAVE A BAD USB POWER / HUB NOW MY BOX IS DAMAGED POLAR SOFTWARE CAN'T RUN / OR CAN'T CONNECT PHONES ANY MORE
1- IF UR BOX IN UNDER WARRENTY THEN BETTER CONTACT UR RESELLER
2- IF UR BOX IS OUT OF WARRENTY THEN U CAN REPAIR IT IN FEW MINUTES JUST BY CHANGING FTDI
POLAR FTDI IS SAME AS UFS, TWISTER, NBOX .... OR ANY FTDI DEVICE
The Following 19 Users Say Thank You to The_Gorr For This Useful Post:
Old 06-14-2009, 23:01   #11 (permalink)
The_Gorr's Avatar
Member: 145648
I CAN'T USE POLAR SERVER, ALWAYS HAVE THIS ERROR A07 check account
1- UR BOX HAVE TO BE REGISTRED WITH SAT (U HAVE TO REGISTER)
2- U NOT SAVE UR LOGIN AND PASS IN SAT OR U PUT A WRONG LOGIN AND PASS IN SAT (PUT CORRECT INFOS)
3- U USING A ANTIVIRUS THAT BLOC UR CONNECTION (DESABLE IT)
4- U HAVE A FIRWELLED CONNEXION (DESABLE IT)
Old 06-14-2009, 23:05   #12 (permalink)
The_Gorr's Avatar
Member: 145648
I HAVE SAGEM LOGS, CAN I USE THEM ALSO TO UNLOCK MODEMS !!!!
Yes u can
now we can't talk about sagem logs, we talk about polar credits, with polar credits u can unlock any phone need credits
The Following 6 Users Say Thank You to The_Gorr For This Useful Post:
Old 06-14-2009, 23:12   #13 (permalink)
The_Gorr's Avatar
Member: 145648
I UNLOCKED SOME PHONES NOT EXIST IN SUPPORTED MODELS, BUT UNLOCKED OK USING POLAR BOX
congratulation, but we need some infos
1- post phone model
2- post what model u selected from polar phone list
3- post what cable u used to connect it
4- post a screen capture or paste log of unlock process
5- read full backup, upload it to rapidshare and post link (if possible)
Old 06-14-2009, 23:19   #14 (permalink)
The_Gorr's Avatar
Member: 145648
MY PHONE IS SUPPORTED BY POLAR, BUT I DON'T HAVE CABLE
1- U CAN BUY CABLE
2- CHECK SUPPORT FOR PINOUTS
3- CHECK THIS THREAD IT CAN HELP U ALSO link
Old 06-14-2009, 23:24   #15 (permalink)
The_Gorr's Avatar
Member: 145648
I DON'T HAVE CABLE, BUT HAVE PINOUT, HOW TO FIND RX, TX, GND IN POLAR RJ45 !!
POLAR HAVE UNIVERSAL PINOUT, SO ANY UNI CABLE CAN WORK PERFECTLY USING POLAR
ABOUT POLAR RJ45 PIN, U CAN REFER TO THIS IMAGE
The Following 12 Users Say Thank You to The_Gorr For This Useful Post:
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-24-1999 05:45
Page generated in 0.23797 seconds with 11 queries
