08-07-2013, 11:36 | #91 (permalink) |
Freak Poster Join Date: Jan 2008 Location: RO-HD
Member: 668010 Status: Offline Thanks Meter: 117 | Buy cyclone credits? Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B00007B7 HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 5.07v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.03v PASSED VBAT Voltage 5.05v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.04v PASSED Box VPP disabled VPP Voltage 0.04v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) |
08-07-2013, 11:38 | #92 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
Regards | |
08-07-2013, 11:43 | #93 (permalink) |
Insane Poster Join Date: Jan 2010 Location: center of the earth <hell>
Member: 1219358 Status: Offline Sonork: misu Thanks Meter: 27 | i'm new to cyclone ... by rooting the phone it will be sim unlocked and nothing more..or just the emmc drive... i'm kinda confused ( mabey a full tutorial with the full unlock procesure on lumia 800 will help more ) ty in advance |
08-07-2013, 13:49 | #94 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000461E HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 / 2010, wk01 Initializing security card... Card Serial Number: D0030004 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 4.90v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.76v PASSED VBAT Voltage 0.00v PASSED VBAT Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 1.112GB Avaiable Virtual Memory: 1.911GB Avaiable Pagefile: 3.42GB Initializing FBUS... All initialized - Ready to work |
08-07-2013, 14:30 | #95 (permalink) |
No Life Poster Join Date: Nov 2006 Location: poland krakow
Member: 389207 Status: Offline Thanks Meter: 61 | hahhaha Write Root Data Failed -> Box is NOT ACTIVATED for Lumia NO TP! Failed to Root Phone -> Rooting Failed like always BIG NEWS BOMB from karwos again dont work |
08-07-2013, 14:35 | #96 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Haha yes you right doesnt work! Because You didnt activate It?! So what You except? That karwos should come and activate u Himself? First Pls read Manual and all info, obviously make update and activations after that comment because on this moment is totally unused comment. |
08-07-2013, 14:36 | #97 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Polaczek chcialby za darmo, a jeszcze lepiej z doplata tak sie nie da, następnym razem zanim cos napiszesz to sprawdz bo bede kasowal kazdego twojego posta. |
08-07-2013, 14:43 | #98 (permalink) | |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
08-07-2013, 15:31 | #99 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Hungary, near Miskolc Age: 48
Member: 19327 Status: Offline Thanks Meter: 45 | How does the activation take ? It is not instant ? I paid it already ( but not much time ago ) ... Could you see it pls ... ? SN : C0000CF6 |
08-07-2013, 15:42 | #100 (permalink) |
Member: 19327 Status: Offline Thanks Meter: 45 | Thanks, now its ok Code: [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Details Protocol: v1.1 Version: v257.6 Build: 12 Timestamp: 2012.02.17. 14:40:05 OSBL Bootloader Ready USB&UART Tracing set RSA Signature Calculated for QCB Boot, Writing... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031573 Signer Timestamp: 2011.09.28. 15:52:12 Signer S/N: 23 Signer User ID: 10046114 Auth Level: Care Data Encryption: 0 Image Index: 0 Asic Index: 0 Type: Image Write Hashtable Parsed OK Certificate Accepted [ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200 Write taken 1.107s (Average speed: 6294,14kBits/s) Restoring Modem from BACKUP_RAMFS_IMAGE... Restore OK Restarting MCU... Rooting Finished! Code: Looking for NAND disk...Done. Trying to parse partition tables...Done. ---------------------------------------------------- FAT16 absolute address: 0x001F4200 FAT16 partition size: 0x0927C000 ---------------------------------------------------- Reading FAT16 raw...Done. Searching locations...Done. Found 1 locations to modify, processing: Reading sector 0...Done. Modify sector...Done. Updating sector...Done. Modification written. Please follow those steps: 1. Disconnect USB cable and remove the battery 2. Insert not supported simcard and power on the phone 3. If asked for PIN code, enter 00000000 4. If asked for PUK code, enter 0000000000 5. After unlock success, connect to USB, enter OSBL mode 6. Press Unlock again to restore the phone to original Last edited by clone; 08-07-2013 at 15:49. |
08-07-2013, 16:11 | #101 (permalink) | |
08-07-2013, 16:38 | #103 (permalink) | |
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Quote:
For Key users- is totally free. Classic comes with 100 credits on account. Only Reloaded was empty, but long time LG, Iphone and sl3 were OFF, so credits were unuseless. Navifirm was for free. Also its only threshold- We dont eat any credits, everything stay on account. | |
The Following User Says Thank You to kaisak For This Useful Post: |
08-07-2013, 16:41 | #104 (permalink) | |
Member: 19327 Status: Offline Thanks Meter: 45 | Quote:
Yes. I never made it via TP | |
08-07-2013, 16:57 | #105 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 92326 Status: Offline Thanks Meter: 205 | what i need to do ? Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B0000B8F HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 4,99v PASSED MCU Voltage 3,26v PASSED Core Voltage 1,82v PASSED VBAT Voltage 0,03v PASSED VBAT Voltage 4,98v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 4,92v PASSED Box VPP disabled VPP Voltage 0,04v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 1.473GB Avaiable Virtual Memory: 1.928GB Avaiable Pagefile: 2.623GB Initializing FBUS... All initialized - Ready to work |
