Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-08-2013, 10:25   #121 (permalink)
clone's Avatar
Member: 19327
Thanks Meter: 45
Originally Posted by swechacnu View Post
Hi,
if i rooted unlocked with this update, then again i can update latest version firmware with cyclone or care suite is it possible? and one more thing again is it locked device?
BR,
Srinivas Reddy.
You can't unlock with cyclone - only can do root it. After that , when the eMMC will be available for 3.part tools , you can patch the amss area. So it is now only patch,and after sw update you need to patch again.
Old 08-08-2013, 11:35   #122 (permalink)
Registered User
Member: 246072
Thanks Meter: 96
Hi,
BR,
Srinivas Reddy.
If you flash amss to your phone then it will relock and you need to patch it again.
Old 08-08-2013, 13:41   #123 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,433
Yes exacly right now after patch unlock can't flash phone without relock phone but this is not a problem becsoue after flash phone can again unlock without TP then just few minutes work.
Old 08-08-2013, 16:04   #124 (permalink)
Crazy Poster
Member: 1435802
Thanks Meter: 7
i have 60 credits but it says lumia 800 no tp not actiavated.
Started credits checking procedure at 4:06:27 PM
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Service Tag: 1F6DB2691A6F1C0BC7C7EC9351F0A104
Cyclone Server (2.0.0.117), Cyclone Box Team 2008-2013 - Ready.
Credits: 60
please check
Establishing Connection with Box in Main Mode...
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B0001BF3
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
Started box selftests procedure
USB Voltage 4.89v PASSED
MCU Voltage 3.27v PASSED
Core Voltage 1.81v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.83v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.83v PASSED
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is NOT ACTIVATED! (1)
Avaiable Physical Memory: 1.1023GB
Avaiable Virtual Memory: 1.893GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Old 08-08-2013, 16:07   #125 (permalink)
clone's Avatar
Member: 19327
Thanks Meter: 45
Credits: 60
please check
Initializing box...
Box is activated
Box VPP disabled
Box VPP disabled
You have to use "box wizard" to activate the root option.
The Following 2 Users Say Thank You to clone For This Useful Post:
Old 08-08-2013, 20:42   #126 (permalink)
Member: 1750919
Hope to see support for Lumia 900 soon.
Old 08-09-2013, 00:03   #127 (permalink)
daryl007's Avatar
Member: 980307
Sonork: 100.1649165
Thanks Meter: 173
help me karwos i sent private message>>> please help.
Old 08-09-2013, 08:48   #128 (permalink)
Member: 1022380
Thanks Meter: 5
Originally Posted by karwos View Post
Maybe your phone is already rooted, and OSBL is not detected.... or drivers problem... or baterry....
many phones are with hw failure....top fail is the soldering of usb connector. Try to resolder it
Old 08-09-2013, 09:38   #129 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Wrong! After unlock with NSS, you can restore original baseband image,
and phone will be still in unlocked state. That's what the Restore button in Simlocks
do anyway.
The unlock method of NSS is not patch, it is proper code unlock. To further
educate yourself, please buy a brand new Lumia, get an operator code, enter
it, then flash with NCS and see what happens
The Following 3 Users Say Thank You to Bph&co For This Useful Post:
Old 08-09-2013, 09:41   #130 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
do anyway.
Next confirmation about poor qualcomm security. Seems same situation as in sl1 or sl2. After accept code, SFS are reencrypted by AMSS and simlock unlock flag is triggered.
Old 08-09-2013, 16:47   #131 (permalink)
<<::GS|\/|SAGA::>>'s Avatar
Member: 194936
Sonork: 100.1616223
Thanks Meter: 484
Need sulotion for lunia 610 plz
Sent from my GT-I9505 using Tapatalk 2
Old 08-09-2013, 18:16   #132 (permalink)
Registered User
Member: 246072
Thanks Meter: 96
Hi,
BR,
Srinivas Reddy.
do anyway.
where did you read the user talking about the unlock method of NSS?! or about operator code´s?!
You should read properly what he asked and what i wrote, because he was talking about patching solution, not operator codes.
Or after root with cyclone and using NSS to unlock it will Use/Read original NCK from phone???
best regards
The Following User Says Thank You to SpoOnx For This Useful Post:
Old 08-09-2013, 20:16   #133 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
It seems you are the one that didn't read my post. Even if you read the
original NCK and enter it, the phone will re-lock after flash. So there is nothing
to do with AMSS, patching or the weather in the Arctic. It is the way the
security works in WP7.
Clicking Unlock in NSS and then entering zeros is the same as putting the
original NCK. You can put whatever AMSS, the phone will stay unlocked.
The Following User Says Thank You to Bph&co For This Useful Post:
Old 08-10-2013, 05:59   #134 (permalink)
Member: 1945782
Thanks Meter: 7
Started credits checking procedure at 11:58:36 AM
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Service Tag: 84AF253D79FC2970797DCBCAFD5C49B3
Failed to Check Credits -> Failed to connect to Cyclone Server
upgrade firmware cyclone box 2.20 failed...
help me sir
Old 08-10-2013, 06:26   #135 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 472
Nobody force u to buy anythinf
U can still mess with TP
yes nobody force to me its my fault why i trust on mr.Vahid Shahabi project
Page generated in 0.21414 seconds with 8 queries
