Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-07-2013, 11:36   #91 (permalink)
pichi_balea's Avatar
Member: 668010
Thanks Meter: 117
Buy cyclone credits?
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B00007B7
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
Started box selftests procedure
USB Voltage 5.07v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 0.03v PASSED
VBAT Voltage 5.05v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 5.04v PASSED
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is NOT ACTIVATED! (1)
Old 08-07-2013, 11:38   #92 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 67,515
Originally Posted by xerraco View Post
How much is the Lowest available Credits? Can I purchase 10 Credits?
Yes Friend! 8 usd. www.**********
Regards
Old 08-07-2013, 11:43   #93 (permalink)
Member: 1219358
Sonork: misu
Thanks Meter: 27
i'm new to cyclone ... by rooting the phone it will be sim unlocked and nothing more..or just the emmc drive... i'm kinda confused ( mabey a full tutorial with the full unlock procesure on lumia 800 will help more ) ty in advance
Old 08-07-2013, 13:49   #94 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 235
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C000461E
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 / 2010, wk01
Initializing security card...
Card Serial Number: D0030004
Card Firmware Revision: 010A
Card is activated
Box is activated
USB Voltage 4.90v PASSED
MCU Voltage 3.30v PASSED
Core Voltage 1.76v PASSED
VBAT Voltage 0.00v PASSED
VBAT Voltage 4.88v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
VPP Voltage 4.88v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Avaiable Physical Memory: 1.112GB
Avaiable Virtual Memory: 1.911GB
Avaiable Pagefile: 3.42GB
Initializing FBUS...
All initialized - Ready to work
Old 08-07-2013, 14:30   #95 (permalink)
Member: 389207
Thanks Meter: 61
hahhaha
Write Root Data Failed -> Box is NOT ACTIVATED for Lumia NO TP!
Failed to Root Phone -> Rooting Failed
like always BIG NEWS BOMB from karwos again dont work
Old 08-07-2013, 14:35   #96 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by newchief View Post
hahhaha
Haha yes you right doesnt work! Because You didnt activate It?! So what You except? That karwos should come and activate u Himself? First Pls read Manual and all info, obviously make update and activations after that comment because on this moment is totally unused comment.
Old 08-07-2013, 14:36   #97 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
hahhaha
Polaczek chcialby za darmo, a jeszcze lepiej z doplata tak sie nie da, następnym razem zanim cos napiszesz to sprawdz bo bede kasowal kazdego twojego posta.
Old 08-07-2013, 14:43   #98 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Leave him, he is from Poland. Mean wants all for free.
Old 08-07-2013, 15:31   #99 (permalink)
clone's Avatar
Member: 19327
Thanks Meter: 45
How does the activation take ? It is not instant ? I paid it already ( but not much time ago ) ... Could you see it pls ... ? SN : C0000CF6
Old 08-07-2013, 15:42   #100 (permalink)
clone's Avatar
Member: 19327
Thanks Meter: 45
Thanks, now its ok
[Nokia USB Connectivity]: WinUSB Port opened OK!
OSBL Details
Protocol: v1.1
Version: v257.6
Build: 12
Timestamp: 2012.02.17. 14:40:05
OSBL Bootloader Ready
USB&UART Tracing set
RSA Signature Calculated for QCB Boot, Writing...
OSBL Certificate Details
Magic:		WP70
Version:		0
Signer Server ID:	0x98031573
Signer Timestamp:	2011.09.28. 15:52:12
Signer S/N:	23
Signer User ID:	10046114
Auth Level:	Care
Data Encryption:	0
Image Index:	0
Asic Index:	0
Type:		Image Write
Hashtable Parsed OK
Certificate Accepted
[ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200
Write taken 1.107s (Average speed: 6294,14kBits/s)
Restoring Modem from BACKUP_RAMFS_IMAGE...
Restore OK
Restarting MCU...
Rooting Finished!
Looking for NAND disk...Done.
Trying to parse partition tables...Done.
FAT16 absolute address:	0x001F4200
FAT16 partition size:  	0x0927C000
Reading FAT16 raw...Done.
Searching locations...Done.
Found 1 locations to modify, processing:
Reading sector 0...Done.
Modify sector...Done.
Updating sector...Done.
Modification written. Please follow those steps:
1. Disconnect USB cable and remove the battery
2. Insert not supported simcard and power on the phone
3. If asked for PIN code, enter 00000000
4. If asked for PUK code, enter 0000000000
5. After unlock success, connect to USB, enter OSBL mode
6. Press Unlock again to restore the phone to original
I think i earned the spent money with this one phone Thank you
Old 08-07-2013, 16:11   #101 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Originally Posted by clone View Post
Thanks, now its ok
OSBL Details
Protocol: v1.1
Version: v257.6
Build: 12
Magic:WP70
Version:0
Signer Server ID:0x98031573
Signer Timestamp:2011.09.28. 15:52:12
Signer S/N:23
Signer User ID:10046114
Auth Level:Care
Data Encryption:0
Image Index:0
Asic Index:0
Type:Image Write
Hashtable Parsed OK
Restore OK
Restarting MCU...
Rooting Finished!
FAT16 absolute address:0x001F4200
Most important uve saved lots of time and phone still have warranty
Old 08-07-2013, 16:32   #102 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
Originally Posted by parengBok View Post
but when You have Classic or Reloaded You need have on account 60 credits for activate Lumia No TP.
too bad for me.. i own Cyclone Box Classic.. and have 5 credits remaining..(
Credits: 5
pay agaian for use and pay every time when new update added its Truth
The Following User Says Thank You to adnanali For This Useful Post:
Old 08-07-2013, 16:38   #103 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
its not true, sorry.
For Key users- is totally free.
Classic comes with 100 credits on account.
Only Reloaded was empty, but long time LG, Iphone and sl3 were OFF, so credits were unuseless.
Navifirm was for free.
Also its only threshold- We dont eat any credits, everything stay on account.
The Following User Says Thank You to kaisak For This Useful Post:
Old 08-07-2013, 16:41   #104 (permalink)
clone's Avatar
Member: 19327
Thanks Meter: 45
8 USD OMG ! . Its a bottle of beer .. I earn more than 8 USD with the first operation
Yes. I never made it via TP
The Following 2 Users Say Thank You to clone For This Useful Post:
Old 08-07-2013, 16:57   #105 (permalink)
SM4RTBOY's Avatar
Member: 92326
Thanks Meter: 205
what i need to do ?
Initializing box...
Box Serial Number: B0000B8F
Box is activated
USB Voltage 4,99v PASSED
MCU Voltage 3,26v PASSED
Core Voltage 1,82v PASSED
VBAT Voltage 0,03v PASSED
VBAT Voltage 4,98v PASSED
Box VPP disabled
VPP Voltage 0,02v PASSED
VPP Voltage 4,92v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Avaiable Physical Memory: 1.473GB
Avaiable Virtual Memory: 1.928GB
Avaiable Pagefile: 2.623GB
Page generated in 0.32249 seconds with 8 queries
