Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-15-2011, 12:43   #376 (permalink)
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
I think is better to keep GPU under 90, better under 70 degrees, cooler the better.
Old 04-15-2011, 12:58   #377 (permalink)
Member: 1199921
Thanks Meter: 36
Please help can not open Olchashcat-lite v0.03
Hello Support ,
First time using Olchashcat-lite v0.03 for SL3 LBF.
This is newPC wni pro7 64bit ,AMD HD 6990 4gb card.
set up and run Advance-Box ok .down load and set up Olchashcat-lite v0.03 . but can not open soft .
Please help
Thanks
Old 04-15-2011, 13:12   #378 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
You need to use command terminal not to open it direct in windows, check forum how to create bat file.
B.R.
Alkapone
The Following User Says Thank You to Alkapone For This Useful Post:
Old 04-15-2011, 16:10   #379 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
Originally Posted by ChavaL View Post
when tem. get 90 the program closed, i want upload limited temperature.
chepear why if you cant afford aircon for your gpu
attach an industrial fan beside it works for me gpu temp always 78 to 80
i can say oclhascat is the best for sl3 BF
Old 04-15-2011, 16:26   #380 (permalink)
Member: 119202
Thanks Meter: 14
oclHashcat-lite32 1D0BE6FB377F8F47139DBEC230F4D418A327F368:003515140 479811600 -1 00010203040506070809 -2 00010203 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=351514047981167_COD.txt
oclHashcat-lite32 1D0BE6FB377F8F47139DBEC230F4D418A327F368:003515140 479811600 -1 00010203040506070809 -2 040506 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=351514047981167_COD.txt
oclHashcat-lite32 1D0BE6FB377F8F47139DBEC230F4D418A327F368:003515140 479811600 -1 00010203040506070809 -2 070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=351514047981167_COD.txt
It is correct for 3 pc? (win xp, hd5870)
Old 04-15-2011, 16:32   #381 (permalink)
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
Yes, it is. .
Old 04-15-2011, 23:38   #382 (permalink)
Member: 4263
Sonork: 100.1582330
Thanks Meter: 49
is that means:
each computer will do 33% of the caculation?
or each pc will do some parts from the master passowrd?
Old 04-16-2011, 03:07   #383 (permalink)
GmmalGSM's Avatar
Member: 1092395
Sonork: 100.1582829
Thanks Meter: 591
where is my problem??
Old 04-16-2011, 03:42   #384 (permalink)
fred's Avatar
Member: 12411
Sonork: 100.113572
Thanks Meter: 813
@Z3X-HelpeR
use the 32 exe not the 64
as you can see on your sreenshot your system is 32bit not 64 so better use the 32bit executable..
br
freddy
gsmph
Old 04-16-2011, 04:19   #385 (permalink)
Cheater -Don't Deal with him-
Member: 1528074
Sonork: 100.99955
Thanks Meter: 184
Originally Posted by MAK_US1977 View Post
is that means:
2 are doing each 30%
1 are doing 40%
Only one will find the masterpass in correct salt.
Regards
Easy Client
Old 04-16-2011, 04:21   #386 (permalink)
Member: 1528074
Sonork: 100.99955
Thanks Meter: 184
Originally Posted by benguetcowboy1 View Post
yes no problem at all if you use ******* power supply uses maybe 40-50% more power compared to ighash gpu
Hmmm, my 10 PC uses same as before 4,8 kw each hour.
Regards
Easy Client
Old 04-16-2011, 04:38   #387 (permalink)
Member: 211780
Thanks Meter: 4
Help me creat file resumn begin 65%
Imei : 359339037528345
Hash :50CF0948C7AB0BA7B71338A1BD6FA7E965DB7AFA
Thanks!
Old 04-16-2011, 05:43   #388 (permalink)
livewirecebu's Avatar
Member: 15652
Thanks Meter: 344
@advance box.
I notice that you cannot compute the psw codes without the fone on hand. Please add this feature.
Old 04-16-2011, 05:55   #389 (permalink)
benguetcowboy1's Avatar
Member: 51716
Sonork: 100.1594676
Thanks Meter: 217
Regards
Easy Client
yes because you have a stable system what i mean here is that most causes of unstable system ....crashes, gpu not responding etc...etc is because system load is higher than psu can supply to the system...
assuming power supply is rated at 800w and assuming too that system load uses 700-900w then crashes may occur when system is starved of power...
regarding your power consumption of 4.8kw/h before and after is not related to what i mean...
Old 04-16-2011, 06:06   #390 (permalink)
Member: 51716
Sonork: 100.1594676
Thanks Meter: 217
Originally Posted by livewirecebu View Post
@advance box.
hello idol must be in a hurry..you can use this for the mean time
http://forum.gsmhosting.com/vbb/f609...force-1233832/
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/
Posted By For Type Date
LBF computer configuration This thread Trackback: 07-04-2011 20:15
Page generated in 0.28883 seconds with 9 queries
