04-15-2011, 12:58 | #377 (permalink) |
Insane Poster Join Date: Jan 2010
Member: 1199921 Status: Offline Thanks Meter: 36 | Please help can not open Olchashcat-lite v0.03 Hello Support , First time using Olchashcat-lite v0.03 for SL3 LBF. This is newPC wni pro7 64bit ,AMD HD 6990 4gb card. set up and run Advance-Box ok .down load and set up Olchashcat-lite v0.03 . but can not open soft . Please help Thanks |
04-15-2011, 13:12 | #378 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | You need to use command terminal not to open it direct in windows, check forum how to create bat file. B.R. Alkapone |
The Following User Says Thank You to Alkapone For This Useful Post: |
04-15-2011, 16:26 | #380 (permalink) |
Insane Poster Join Date: Feb 2005 Location: Ukraine Age: 43
Member: 119202 Status: Offline Thanks Meter: 14 | oclHashcat-lite32 1D0BE6FB377F8F47139DBEC230F4D418A327F368:003515140 479811600 -1 00010203040506070809 -2 00010203 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=351514047981167_COD.txt oclHashcat-lite32 1D0BE6FB377F8F47139DBEC230F4D418A327F368:003515140 479811600 -1 00010203040506070809 -2 040506 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=351514047981167_COD.txt oclHashcat-lite32 1D0BE6FB377F8F47139DBEC230F4D418A327F368:003515140 479811600 -1 00010203040506070809 -2 070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=351514047981167_COD.txt It is correct for 3 pc? (win xp, hd5870) |
04-15-2011, 23:38 | #382 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Egypt Age: 46
Member: 4263 Status: Offline Sonork: 100.1582330 Thanks Meter: 49 | Quote:
each computer will do 33% of the caculation? or each pc will do some parts from the master passowrd? | |
04-16-2011, 03:42 | #384 (permalink) |
No Life Poster Join Date: May 2002 Location: dont ask!
Member: 12411 Status: Offline Sonork: 100.113572 Thanks Meter: 813 | @Z3X-HelpeR use the 32 exe not the 64 as you can see on your sreenshot your system is 32bit not 64 so better use the 32bit executable.. br freddy gsmph |
04-16-2011, 05:55 | #389 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | Quote:
assuming power supply is rated at 800w and assuming too that system load uses 700-900w then crashes may occur when system is starved of power... regarding your power consumption of 4.8kw/h before and after is not related to what i mean... | |
04-16-2011, 06:06 | #390 (permalink) | |
hello idol must be in a hurry..you can use this for the mean time http://forum.gsmhosting.com/vbb/f609...force-1233832/ | |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
