04-16-2011, 17:51 | #406 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1287581 Status: Offline Thanks Meter: 2 | ram 12g motherboard ausu x58 os win7 64bit card driver 11.3 for win7 64 when run oclHashcat erro WARN:ADL_Overdriver5_temperature_get_<>:-100 WARN:ADL_Overdriver5_temperature_get_<>:-100 WARN:ADL_Overdriver5_temperature_get_<>:-100 tell me why?? |
04-16-2011, 18:39 | #408 (permalink) |
No Life Poster Join Date: Feb 2004
Member: 52597 Status: Offline Thanks Meter: 275 | Code: Motherboard Name ASRock 775i945GZ Motherboard Physical Info: CPU Sockets/Slots 1 LGA775 Expansion Slots 3 PCI, 1 AGI CPU Type DualCore Intel Pentium D 820, 2800 MHz (14 x 200) DIMM1: Kingston 2G-UDIMM 2 GB DDR2-800 DDR2 SDRAM DIMM3: Kingston 2G-UDIMM 2 GB DDR2-800 DDR2 SDRAM Video Adapter Intel(R) 82945G Express Chipset Family (224 MB) 3D Accelerator Intel GMA 950 Can I manage with existing cpu (dual core)? Which is better option - two HD 6970 or one HD 6990? What other modifications will be required to existing system (like power, cooling etc)? Thanks in advance |
04-16-2011, 19:23 | #409 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Subotica Age: 54
Member: 60687 Status: Offline Thanks Meter: 32 | please helo with mixed gpus card 1 5970 card 2 4870x2 speed only 1800 salt utiliztion for all cpu is ~50 % log: t --hex-salt --output-format=1 --output-file=356vxvxcvxc5_COD.txt oclHashcat-lite v0.3 starting... NOTE: gpu-loops auto-adjusted to: 256 Platform: AMD compatible platform found Watchdog: Temperature limit set to 90c Device #1: Cypress, 512MB, 0Mhz, 20MCU Device #2: Cypress, 512MB, 0Mhz, 20MCU Device #3: ATI RV770, 512MB, 0Mhz, 10MCU NOTE: When experiencing preformance loss due to mixed GPU types try using the -d option. Device #4: ATI RV770, 512MB, 0Mhz, 10MCU NOTE: When experiencing preformance loss due to mixed GPU types try using the -d option. [s]tatus [p]ause [r]esume [q]uit => s Status....: Running Current...: ********0000060705040200000000 Monitor1..: 39% GPU, 44c Temp Monitor2..: 64% GPU, 54c Temp Monitor3..: 39% GPU, 46c Temp Monitor4..: 39% GPU, 46c Temp Speed.GPU*: 1814.4M/s Progress..: 20162150400/1000000000000000 (0.00%) Running...: 11 secs Estimated.: 6 days, 9 hours |
04-16-2011, 21:01 | #410 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
Trow away hd4870 and only with hd5970 you wil got speed 3400Mhash/s | |
04-16-2011, 21:12 | #411 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | atf is best for me suporter please make sl3 bruteforcer in one exe with options to add some phones for sl3 bruteforce calculation and resume job pause stop and need all make it easy br. |
04-16-2011, 21:41 | #412 (permalink) |
Member: 60687 Status: Offline Thanks Meter: 32 | @wgmmmx1 ...ok im uderstand ..but im need power (speed) from 4870x2 card!!!!....cylone and mx-key calculator can use this power from all (mixed) gpu's!!! |
04-16-2011, 22:10 | #413 (permalink) |
Freak Poster Join Date: Jul 2004 Location: 0xDEADBEEF Age: 42
Member: 71246 Status: Offline Thanks Meter: 40 | Just discovered a little "trick" that made oclHahscat-lite more stable and gpu usage to constant 99% when I use the PC for other tasks just add into command line this parameter: start /AFFINITY 1 oclHashcat-lite.................. For example : Code: start /AFFINITY 1 oclhashcat-lite32 21B1E417AF2DE6496772BCC2FE33D2593A9BB7A0:003515230478373400 -m 101 --hex-salt --hex-charset -n 800 --gpu-loops=1024 --output-format=1 --pw-min=15 --pw-max=15 -1 00010203040506070809 ?1?1?1?1?1?1?1?1?1?1?100060006 Test it and post results,also please tell what kind of CPU you are using... BR,RaNdy |
The Following 3 Users Say Thank You to randy_d4 For This Useful Post: |
04-16-2011, 22:32 | #414 (permalink) |
No Life Poster Join Date: Aug 2005 Location: AM
Member: 171307 Status: Offline Thanks Meter: 140 | What about PC with 2x HD6990 4gb CPU intel i7 950 Motherboard Intel X58 SLi crossfire ready RAM 3x2GB Power Thermaltake 1200w --------------- is such a pc going to show good performance with LBF |
04-16-2011, 23:37 | #416 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | i did it this way: oclHashcat-lite64 3FA6180C11A2F755629D571A28F438868FE7632E:003533910 4996xxxx00 -1 00010203040506070809 -2 00010203 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 --pw-min=15 --pw-max=15 --pw-skip=12000000000 -n 160 -d -- gpu-devices=0,1 --hex-charset --hex-salt --output-format=1 --output-file=3533910499xxxxxx_COD.txt also tried with: -- gpu-devices=1,4 -- gpu-devices=0,3 and so on. seems that the command line is not ok. |
04-16-2011, 23:47 | #417 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Portugal Age: 41
Member: 241933 Status: Offline Thanks Meter: 77 | Quote:
then calculate at 75% with card 5970 ( 75% because this card is 2x more fast than 4870x2) exemple for 5970: oclHashcat-lite32 B49C5CB8E9EE6765C0F61C9F18135AAD6B67A5F8:003593570 390484100 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --pw-skip=00000000000 -n 160 -d --gpu-devices=2,3 --hex-charset --hex-salt --output-format=1 --output-file=359357039048419_COD.txt now put 25% to other grafic 4870x2 , exemple: oclHashcat-lite32 B49C5CB8E9EE6765C0F61C9F18135AAD6B67A5F8:003593570 390484100 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --pw-skip=75000000000 -n 160 -d --gpu-devices=0,1 --hex-charset --hex-salt --output-format=1 --output-file=359357039048419_COD.txt Now u have both cards on full speed I think i explain me well !! | |
04-16-2011, 23:54 | #418 (permalink) |
Member: 14279 Status: Offline Thanks Meter: 35 | Hi i am trying to mix one 5970 and one 6990 there is no difference between my command line and yours as far as i can see. the command line does not work. |
04-17-2011, 00:27 | #419 (permalink) | |
Member: 71246 Status: Offline Thanks Meter: 40 | Quote:
like this: Code: oclHashcat-lite64 3FA6180C11A2F755629D571A28F438868FE7632E:0035339104996xxxx00 -1 00010203040506070809 -2 00010203 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 --pw-min=15 --pw-max=15 --pw-skip=12000000000 -n 160 -- gpu-devices=0,1 --hex-charset --hex-salt --output-format=1 --output-file=3533910499xxxxxx_COD.txt Code: oclHashcat-lite64 3FA6180C11A2F755629D571A28F438868FE7632E:0035339104996xxxx00 -1 00010203040506070809 -2 00010203 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 --pw-min=15 --pw-max=15 --pw-skip=12000000000 -n 160 -d 0,1 --hex-charset --hex-salt --output-format=1 --output-file=3533910499xxxxxx_COD.txt BTW U can try also my "trick" for AFFINITY,put first command on first core,second one on second core.I think this will bring u stability and 99% usage on both cards..let us know the result! BR,RaNdy | |
04-17-2011, 00:55 | #420 (permalink) |
Member: 71246 Status: Offline Thanks Meter: 40 | Best way to split your job into two cards will be this: 1)let say first card is 5970,the command will be: Code: oclHashcat-lite64 3FA6180C11A2F755629D571A28F438868FE7632E:0035339104996xxxx00 -m 101 --pw-min=15 --pw-max=15 -n 160 --gpu-device=1,2 --hex-charset --hex-salt --output-format=1 --output-file=3533910499xxxxxx_COD.txt --session=3533910499xxxxxx_5970 -1 00010203040506070809 -2 0908070605 ?1?1?1?1?1?1?1?1?1?1?1?2?2?2?2 Code: oclHashcat-lite64 3FA6180C11A2F755629D571A28F438868FE7632E:0035339104996xxxx00 -m 101 --pw-min=15 --pw-max=15 -n 160 --gpu-device=3,4 --hex-charset --hex-salt --output-format=1 --output-file=3533910499xxxxxx_COD.txt --session=3533910499xxxxxx_6990 -1 00010203040506070809 -2 0403020100 ?1?1?1?1?1?1?1?1?1?1?1?2?2?2?2 for 6990 proccess: Code: oclHashcat-lite64 --restore --session=3533910499xxxxxx_6990 Code: oclHashcat-lite64 --restore --session=3533910499xxxxxx_5970 PS:U can use my examples for template,only change hash and imei and all willl be OK BR,RaNdy |
The Following User Says Thank You to randy_d4 For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
