04-16-2011, 07:01 | #391 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Cebu, Philippines
Member: 15652 Status: Offline Thanks Meter: 344 | Quote:
04-16-2011, 10:00 | #393 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | does anyone know how to run 2 instances of OCL on the same system? i have 1 5970 and one 6990. they do not work toghether. atom said something about using the -d parameter to specify the GPU. but i cannot find the right command line to identify the gpu-s of 5970/6990 also he said something about using --session parameter |
04-16-2011, 10:37 | #394 (permalink) | |
Junior Member Join Date: Jul 2005 Age: 43
Member: 163464 Status: Offline Thanks Meter: 3 | Quote:
Run new: 60%->100% oclHashcat-lite32 50CF0948C7AB0BA7B71338A1BD6FA7E965DB7AFA:003593390 375283400 -1 00010203040506070809 -2 06070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n --hex-charset --hex-salt --output-format=1 --output-file=359339037528345_COD.txt or Resume task: oclHashcat-lite32 --restore 50CF0948C7AB0BA7B71338A1BD6FA7E965DB7AFA:003593390 375283400 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n --hex-charset --hex-salt --output-format=1 --output-file=359339037528345_COD.txt Last edited by tangliem; 04-16-2011 at 10:43. | |
04-16-2011, 13:44 | #395 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: AnyClient Age: 44
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | Quote:
Code: oclHashcat-lite64 50CF0948C7AB0BA7B71338A1BD6FA7E965DB7AFA:003593390 375283400 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --pw-skip=65000000000 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=359339037528345_COD.txt | |
The Following User Says Thank You to hoang For This Useful Post: |
04-16-2011, 13:55 | #396 (permalink) | |
-d --gpu-devices=0,1 -d --gpu-devices=2,3 | |
04-16-2011, 16:27 | #399 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Portugal Age: 41
Member: 241933 Status: Offline Thanks Meter: 77 | Quote:
Have u done Overclock?? if yes reduce a little more 10 or 20 Mhz Update to oclHashcat v0.03 have some bugs fixed And i recomended restart ur pc | |
04-16-2011, 16:32 | #400 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
it was 725 clock.. i did it 800 clock.. and gpu temp is 70-71 max.. it is now %23.. my hash is 3200m... if i use v0.03 can i resume it or restart it again..? | |
04-16-2011, 16:47 | #403 (permalink) | |
yes but u will need create other bat that start at 23% if u want put here ur hash and imei and i will create for u. About OC its ok on 800 but if u try see movies or surf on sites like youtube ccc crash to avoid damage ur graffic card . So i dont recommend while pc is in BF , see movies or large pictures | |
04-16-2011, 17:31 | #404 (permalink) | |
to which line..? oclHashcat-lite32 B49C5CB8E9EE6765C0F61C9F18135AAD6B67A5F8:003593570 3xxxxxx00 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=35935703xxxxxx_COD.txt | |
04-16-2011, 17:46 | #405 (permalink) |
No Life Poster Join Date: Sep 2006 Location: 102 quy nhơn BĐ Age: 14
Member: 347720 Status: Offline Sonork: xxx Thanks Meter: 204 | oclHashcat-lite32 B49C5CB8E9EE6765C0F61C9F18135AAD6B67A5F8:003593570 3xxxxxx00 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --pw-skip=23000000000 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=35935703xxxxxx_COD.txt |
The Following User Says Thank You to freedomqn For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
