04-17-2011, 02:36 | #422 (permalink) |
Freak Poster Join Date: Aug 2006 Location: kegalle,sri lanka
Member: 336943 Status: Offline Sonork: 1597228 Thanks Meter: 80 | Log2cod & oclhashcat log2cod & oclhashcat see the speed deferent oclhashcat 1000000000/1796.3=556699.88s 556699.88/60 =9278.33 mins 9278.33/60 =154.6 hours log 2cod 72.7 x 10000=727000s 727000/60 =12116.66 min 12116.66/60 =201.9 hours 201.9-154.6=47.3 hours 47.3/201.9 x100=23.4% OCLHASHCAT 23% FASTER |
04-17-2011, 08:28 | #424 (permalink) | |
No Life Poster Join Date: Aug 2002 Location: Romania Buzau Age: 54
Member: 14468 Status: Offline Thanks Meter: 50 | Quote:
-d 0 give me error best regards vali | |
04-17-2011, 13:37 | #426 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hi.. correct me pls if i wrong... when i start to cmd file 0.03 version it not create rsm file for resuming... is this bug or sth wrong with me..? |
04-17-2011, 14:10 | #427 (permalink) |
No Life Poster Join Date: Mar 2002 Location: AnyClient Age: 44
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | Remember that if restore file was created from 0.02 version, when resume with 0.03, need open restore file and edit the path, or simpy copy to 0.02 folder! |
04-17-2011, 15:02 | #429 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 192302 Status: Offline Sonork: 100.1606958 Thanks Meter: 62 | i have probleme pc with hd single 5970 2gb memory cpu phenome 1 windows 7 arium 64 bit catalyst 11.3 installed sdk 2.4 instaled when i try to bruteforce nothing what is the probleme please !!!! |
04-17-2011, 15:04 | #430 (permalink) | |
Freak Poster Join Date: Sep 2008 Location: Bucharest, Romania Age: 39
Member: 857353 Status: Offline Thanks Meter: 14 | Quote:
try log2cod, it's a good software for brute forcing SHA-1, every time gives you the code and in good time, don't waste time... | |
The Following User Says Thank You to nunu.gabriel For This Useful Post: |
04-17-2011, 15:07 | #431 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,119 | Quote:
Post here Command Line you used to Brute Force... Post screenshot,,, Atleast give us some clue what is it you are dealing with. | |
04-17-2011, 15:12 | #433 (permalink) |
Member: 192302 Status: Offline Sonork: 100.1606958 Thanks Meter: 62 | oclHashcat-lite64 43903AB2887C950394EADBC46830E1BA5059BE85:003553910 426269700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 800 --hex-charset --hex-salt --output-format=1 --output-file=355391042626972_COD.txt |
04-17-2011, 15:13 | #434 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,119 | log2cod is just some shell front end program... The real BF software under it is ighashgpu... Use the ighashgpu BAT files generated by ATF Software when you "Decrypt PM 120 HASHES" Download ighashgpu here: http://golubev.com/files/ighashgpu_v0.80.16.1.zip Just put your ighashgpu BAT files generated by ATF Software inside same directoty as you ighashgpu... Then doube click the batch file. Thats all... |
04-17-2011, 15:18 | #435 (permalink) | |
yes, I know that ighashgpu is behind, but it'a a very good shell. I OC the graphic cards, I had errors, blue screens and every time gave me the code. I wonder if oclhashlite will give me the code after errors, blue screens, restarts, etc... | |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
