unlock I9505 support or no? help [Solved] Welcome to Octoplus/Octopus Box Samsung software version 1.5.7 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM103 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM103 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM103 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: |
You have not connected the phone correctly. Phone's info should be read fully and correctly. To connect GT-I9505, perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Also, look here: http://forum.gsmhosting.com/vbb/f684...8/#post9859847, http://forum.gsmhosting.com/vbb/f684...6/#post9860927, http://forum.gsmhosting.com/vbb/f684...2/#post9804911, http://forum.gsmhosting.com/vbb/f684...ml#post9736060, http://forum.gsmhosting.com/vbb/f684...6/#post9726100, http://forum.gsmhosting.com/vbb/f684.../#post10346328. |
have participated step but still not clear why the log Platform: Samsung Android Selected port: COM103 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: |
maybe you should try to check your Device manager... ADB driver problem i think, just like i encounter before... |
Also, try to connect GT-I9505 phone via UART cable you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options->About Device. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[4]DM over UART" value. 13. Restart phone. 14. Press "Read Info" in software. |
Welcome to Octoplus/Octopus Box Samsung software version 1.5.8 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM111 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Nov 27 2013 Firmware released time: 23:02:06 Phone IMEI: 359921-05-xxxxxxxxx SW version: M9615A-CEFWTAZM-4.0.17125 Unlocking phone... Creating NVM backup Reading NVM done! Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed usb debuging is on but unlock not succes |
http://i366.photobucket.com/albums/o...ps8a033019.jpg http://i366.photobucket.com/albums/o...ps761fafe5.jpg still the same Platform: Samsung Android Selected port: COM111 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Nov 01 2013 Firmware compiled time: 11:00:00 Firmware released date: Nov 27 2013 Firmware released time: 23:02:06 Phone IMEI: 359921-05-xxxxxxxx SW version: M9615A-CEFWTAZM-4.0.17125 Unlocking phone... Creating NVM backup Reading NVM done! Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed |
Try to use another root Software/exploit and then repeat the operation again. |
