03-30-2021, 18:58 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Mexico
Member: 527046 Status: Offline Thanks Meter: 97 | smart card configuration mismatch CM2MT2 closed while trying EMI config to read info. === DongleManager [Infinity] v1.81 [30/03/2021 11:56:04] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00047873FF021982 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): 467F7873 Firmware version: 0145.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0145 => Activations: - 00: Infinity-Box/Dongle [CM2] v0145 - 03: Infinity [BEST] v0122 - 07: #7 => Options: - Infinity-Box/Dongle [CM2] - Infinity [BEST2] - Infinity SM |
The Following User Says Thank You to hyber_99 For This Useful Post: |
03-30-2021, 21:36 | #3 (permalink) | |
Reboot PC Update dongle firmware after that Before run Infinity exe delete fault.bin file from CM2 folder (if any) | |
04-01-2021, 11:58 | #4 (permalink) |
Junior Member Join Date: Dec 2017
Member: 2793330 Status: Offline Sonork: family Thanks Meter: 0 | === DongleManager [Infinity] v1.80 [4/1/2021 15:19:55] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: GsmEasy S-Reader 0 HWID: 00001CF121F34082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 32EA1CF1 Firmware version: 0147.02 === Process started: 4/1/2021 15:19:56 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
04-01-2021, 13:34 | #5 (permalink) | |
1. Read NOTE - https://www.infinity-box.com/support/?s=2 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. 3. Update dongle with Infinity DongleManager.exe 4. Delete fault.bin file (if you have it in CM2 folder) 5. Run Infinity exe | |
04-01-2021, 16:20 | #6 (permalink) |
Junior Member Join Date: May 2006 Location: egypt- cairo
Member: 282037 Status: Offline Thanks Meter: 3 | good team please Dongle identification data damaged Dongle identification data damaged. Dongle identification data damaged Dongle identification data damaged my dongle not work please helpe me === DongleManager [Infinity] v1.81 [01/04/2021 16:23:03] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000053121344082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): FD140531 Firmware version: 0147.02 === Process started: 01/04/2021 16:23:04 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 Last edited by YellowBoss; 04-01-2021 at 21:31. |
04-01-2021, 19:31 | #7 (permalink) | |
Member: 282037 Status: Offline Thanks Meter: 3 | thank you good team my dongle go back successfully thank you good team my dongle go back successfully Quote:
The Following User Says Thank You to saidport For This Useful Post: |
04-03-2021, 06:02 | #8 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2781767 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.81 [4/3/2021 12:40:52] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0001397F1F444082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): E898397F Firmware version: 0147.02 === Process started: 4/3/2021 12:40:53 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
04-03-2021, 11:42 | #9 (permalink) | |
04-05-2021, 17:39 | #10 (permalink) |
Freak Poster Join Date: Mar 2018 Location: Karachi Pakistan Age: 30
Member: 2824001 Status: Offline Thanks Meter: 110 | i use my dongle on secondary laptop and then it is not working as showing "Smarcard M === DongleManager [Infinity] v1.80 [05/04/2021 21:33:57] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000354D176D4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 6F1D354D Firmware version: 0147.02 === Process started: 05/04/2021 21:33:59 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2" === DongleManager [Infinity] v1.80 [05/04/2021 21:40:33] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000354D176D4082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 6F1D354D Firmware version: 0147.02 Box/Dongle misconfiguration Diagnostic code: 62 "UK Edition" status: Off Last launched Application: 0030 v.0147 => Activations: - 00: Infinity-Box/Dongle v0147 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM Activation #0: Infinity-Box/Dongle [CM2]; S/N: 6F1D354D; Firmware Version: 0147; Registered: 28-May-2018; Expired: 11-May-2022; Support: Active i have not found any "fualt.bin" file in my any PC CM2 installation directory. Last edited by Jameel91; 04-05-2021 at 17:48. |
04-05-2021, 18:29 | #11 (permalink) | |
Please upload file fault.bin to mega.nz and post link here. File is at /InfinityBox/CM2MT2/ or /InfinityBox/CM2SP2/ or /InfinityBox/BEST/ folder I suggest you restore file from recycle bin | |
04-06-2021, 09:59 | #14 (permalink) | |
Please do as per this instruction step 7. now https://forum.gsmhosting.com/vbb/f29...t-run-2855041/ | |
04-06-2021, 10:20 | #15 (permalink) | |
Member: 2824001 Status: Offline Thanks Meter: 110 | Quote: https://mega.nz/file/WuIxRYrJ#7IF_FB...oWv9ddjNaxa3GM | |
The Following User Says Thank You to Jameel91 For This Useful Post: |
