01-08-2017, 14:14 | #601 (permalink) |
Junior Member Join Date: Jun 2013 Location: Russia, Crimea, Simferopol Age: 35
Member: 1965594 Status: Offline Thanks Meter: 4 | Logs second computer: ==== [07.01.2017 16:27:56] ==== DongleManager [Infinity-Box] v1.67 [07.01.2017 16:27:58] PC HWID: 9A26768081107DE16CA6F33E3A0E8676 Scanning... Card-Reader: FT SCR2000 0 HWID: 01048084147D1292 Box/Dongle is not found ==== [07.01.2017 16:28:04] ==== Scanning... HWID: 01048084147D1292 Select Box/Dongle Type: instead of Autodetect Box/Dongle type selected: [BEST] HWID: 01048084147D1292 Box/Dongle type selected: [BEST] ---------- Process started: 07.01.2017 16:28:21 ---------- DongleManager [Infinity-Box] v1.67 [07.01.2017 16:28:21] PC HWID: 9A26768081107DE16CA6F33E3A0E8676 Card-Reader: FT SCR2000 0 HWID: 01048084147D1292 Type: [BEST] S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
01-08-2017, 14:31 | #602 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware now ONLY ONE TIME | |
01-08-2017, 14:50 | #603 (permalink) |
Junior Member Join Date: Jul 2008
Member: 820264 Status: Offline Thanks Meter: 1 | Box/Dongle type selected: [BEST] ---------- Process started: 1/8/2017 7:09:10 PM ---------- DongleManager [Infinity-Box] v1.67 [1/8/2017 7:09:10 PM] PC HWID: 9B153AC47A21F08CD519456A8EE555F9 Card-Reader: FT SCR2000 0 HWID: 01048D8C20281292 Type: [BEST] S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
01-08-2017, 15:23 | #604 (permalink) | |
You have made many dongle update tries today and server locked your account for 24 hours due to security reason. Please wait 24 hours and contact to support with problem details | |
01-09-2017, 16:29 | #605 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2664523 Status: Offline Thanks Meter: 0 | Box/Dongle type selected: [BEST] Box/Dongle found: [BEST] ---------- Process started: 09-01-2017 06:20:35 ã ---------- DongleManager [Infinity-Box] v1.67 [09-01-2017 06:20:35 ã] PC HWID: DDEFF6BCD2442E6FCAB7A1C9702A0C0E Card-Reader: FT SCR2000 1 HWID: 0100696B10321292 Type: [BEST] S/N: 5AA5696B Version: 0118.08 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
01-09-2017, 22:20 | #606 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Quote:
To avoid software conflicts in future please do not use "Realterm" at the same time with Infinity software. What to do now: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. - Install latest Infinity software updates - Run DongleManager.exe - Update Dongle firmware now ONLY ONE TIME | |
01-10-2017, 07:22 | #607 (permalink) | |
Insane Poster Join Date: Apr 2008
Member: 745485 Status: Offline Sonork: sam Thanks Meter: 7 | Quote:
MXK Dongle the log is below ==== [1/10/2017 9:03:43 AM] ==== Infinity-Box CardID v1.06 [email protected] Database: ./FSCard.ini Card-Reader: USB CCID Smart Card Reader 0 ATR: 3B7D95000080318065B0831148C883009000 Historical ATR bytes: 0080318065B0831148C8830090 Card Manager: A000000018434D00 SerialNumber: 00089362 ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 3158 Serial Number: 00089362 Batch Identifier: 1820 Module Fabricator: 1292 Module Packaging Date: 4113 IC Card Manufacturer: 2003 IC Em******* Date: 4113 Pre Personalizer: 2004 Pre Personalization Date: 4113 Pre Personalization Equipment Identifier: 00000014 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 0008936218201292 GP Version: 2.1.1 SCP Version: 1, Option: 5 -------------------------------------------------- Z3X Box the log -------------------------------------------------- Database: ./FSCard.ini Card-Reader: FT SCR2000 0 ATR: 3B7D95000080318065B0831148C883009000 Historical ATR bytes: 0080318065B0831148C8830090 Card Manager: A000000018434D00 SerialNumber: 0008705B ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 3158 Serial Number: 0008705B Batch Identifier: 2028 Module Fabricator: 1292 Module Packaging Date: 3268 IC Card Manufacturer: 2003 IC Em******* Date: 3268 Pre Personalizer: 2004 Pre Personalization Date: 3268 Pre Personalization Equipment Identifier: 00000044 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 0008705B20281292 GP Version: SCP Version: 0, Option: 0 ------------------------------------------------- Best Dongle log ------------------------------------------------- Database: ./FSCard.ini Card-Reader: FT SCR2000 0 ATR: 3B7D95000080318065B0831148C883009000 Historical ATR bytes: 0080318065B0831148C8830090 Card Manager: A000000018434D00 SerialNumber: 00089362 ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 3158 Serial Number: 00089362 Batch Identifier: 1820 Module Fabricator: 1292 Module Packaging Date: 4113 IC Card Manufacturer: 2003 IC Em******* Date: 4113 Pre Personalizer: 2004 Pre Personalization Date: 4113 Pre Personalization Equipment Identifier: 00000014 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 0008936218201292 GP Version: 2.1.1 SCP Version: 1, Option: 5 | |
01-11-2017, 10:12 | #609 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 589869 Status: Offline Sonork: 100.1593501 Thanks Meter: 552 | Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 1/11/2017 3:08:40 PM ---------- DongleManager [Infinity-Box] v1.67 [1/11/2017 3:08:40 PM] PC HWID: 7F5EECE0E9848946CAF9C2BAAA036611 Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 010390671C6A1292 Type: Main Infinity-Box/Dongle S/N: D5D29067 Version: 0134.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 dongle is blocked |
01-11-2017, 11:48 | #610 (permalink) | |
Insane Poster Join Date: Feb 2008
Member: 704199 Status: Offline Thanks Meter: 15 | same problem.. Quote:
same problem with my infinity best dongle.. dongle is blocked.. please solution.. | |
01-11-2017, 13:11 | #611 (permalink) | |
Member: 704199 Status: Offline Thanks Meter: 15 | Quote:
DongleManager [Infinity-Box] v1.67 [1/11/2017 5:24:44 PM] PC HWID: D351C519E614492256368E16E0BDFD1D Card-Reader: FT SCR2000 0 HWID: 01027B8B20281292 Type: [BEST] S/N: E7ED7B8B Version: 0122.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 | |
01-11-2017, 15:09 | #612 (permalink) |
Insane Poster Join Date: Jan 2007 Location: gujrat
Member: 441844 Status: Offline Thanks Meter: 7 | DongleManager [Infinity-Box] v1.67 [1/11/2017 7:38:27 PM] PC HWID: CC049F9A7D6E411694E0E29E5B0FC00B Scanning... Box/Dongle found: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00046B6018201292 Box/Dongle Serial No (S/N): A21F6B60 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 30 "UK edition" status: Off Last launched Application: 0030 v.0223 => Activations: - 03: [BEST] v.0122 => Online Service Account: http://www.infinity-box.com/service - Username: 03A21F6B60 - Password: CAHKbecw Diagnostic Key: 7FA0C809136D4277 what to do now |
01-12-2017, 00:37 | #613 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,989 | Quote:
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software. What to do now: - Install latest Infinity software updates - Run DongleManager.exe - Update Dongle firmware now ONLY ONE TIME | |
01-12-2017, 00:38 | #614 (permalink) | |
01-12-2017, 00:39 | #615 (permalink) | |
