03-11-2011, 20:49 | #137 (permalink) |
Insane Poster Join Date: Dec 2007 Location: NIGERIA
Member: 645502 Status: Offline Sonork: 645502 Thanks Meter: 13 | pls i need help with my box the information below is my box Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.57, (Mar 10 2011 12:45:53, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 wk9 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0003C41 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 / 2010, wk01 Initializing security card... Card Serial Number: DB00015D Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.91v PASSED MCU Voltage 3.31v PASSED Core Voltage 1.76v PASSED VBAT Voltage 0.01v PASSED Box Selftests Failed -> VBAT Supply Voltage test failed, 0.01v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work |
05-08-2011, 07:24 | #139 (permalink) |
No Life Poster Join Date: May 2007 Location: india
Member: 500302 Status: Offline Thanks Meter: 157 | sir. how to solve this problem Started box selftests procedure Box Selftests Failed -> USB Supply Voltage test failed, 0.01v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work http://forum.gsmhosting.com/vbb/f528...solve-1259887/ |
05-18-2011, 13:26 | #141 (permalink) |
Crazy Poster Join Date: Jul 2008
Member: 819708 Status: Offline Thanks Meter: 5 | Started box selftests procedure USB Voltage 5.07v PASSED MCU Voltage 3.31v PASSED Core Voltage 1.81v PASSED VBAT Voltage 3.15v PASSED Box Selftests Failed -> VBAT Supply Voltage test failed, 3.00v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work I can't Read info,Flashing and Unlock the phones. How can i solved that problem? |
05-18-2011, 19:05 | #142 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Quote:
BR | |
05-20-2011, 11:47 | #146 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Seems you dont want to read or you dont understand what you read Who told you that changing LM3940 will solve " VBAT Supply " problem... If you bothered to read, as i told yo before, you will find, in post #25, that the LM3940 Has NOTHING to do with VBAT... so please READ AGAIN ALL posts. BR |
12-10-2011, 02:39 | #147 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 888099 Status: Offline Thanks Meter: 33 | Hello Team what about this issue Code: Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.82, (Nov 12 2011 09:45:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00038C1 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40 Initializing security card... Card Serial Number: DD0002A1 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure Box Selftests Failed -> USB Supply Voltage test failed, 4.45v is out of valid range Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Credits Left: 100 Avaiable Physical Memory: 2.321GB Avaiable Virtual Memory: 1.400GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Last edited by ptt; 12-10-2011 at 16:24. Reason: Add Code tag - Change font size, nobody is blind here |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
just got box, dont know what to do | masterunlocking | VygisToolbox | 2 | 11-11-2007 17:36 |
6280 flashing failed! what to do? | rakhpai | Universalbox | 2 | 08-10-2006 18:33 |
