Old 09-17-2008, 13:26   #31 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
Originally Posted by rashad-a View Post
6234 nokia 1st problem memory card not accepte i heat memory card ic after chek .. display wight screen phone is ok i have change 2 display ic but same problem please help urgent.....
brother remove 2 MMC realted ESD filter then check
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-18-2008, 10:29   #32 (permalink)
Member: 662585
Thanks Meter: 52
2600c keypad problem select exit up down bottens i have change key pad ic but same problem ?
The Following User Says Thank You to rashad-a For This Useful Post:
Old 09-18-2008, 11:10   #33 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
did you change keypad??????also check connector.
The Following User Says Thank You to pupaji For This Useful Post:
Old 09-18-2008, 15:00   #34 (permalink)
Member: 351924
brother check or chnage keypad connector or keypad unit
same problem again?change keypad ic
post result
Old 09-19-2008, 07:55   #35 (permalink)
Member: 538525
Thanks Meter: 13
Originally Posted by SHIJILFONOTLY View Post
NOKIA 6230,6230i NETWORK PROBLEM UPDATED
6230,6230i NONET WORK FOUND PROBLEM SOLVED CHANGING THIS CAPACITOR
THIS LAST MONTH AM SOLVED ABOVE 35 HANDSETS
REGARDS,
NOKIA.REPAIR.MASTERS TEAM
hi 6230i NO NET WORK FOUND PROBLEM help me
The Following 2 Users Say Thank You to riyaz5016 For This Useful Post:
Old 09-19-2008, 10:45   #36 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
Is the set says no network found within a short time ?
or
only after a long duration search ?
these two symptoms have to be treated in different ways
with in short time it says no network found , we have to
trace the beginning stages of receiving side kike antinna ,
contacts, antina switch and associated parts in RF block
if the case is said as in the later one
we had to suspect the demodulation section or decoding procedure, or any
corruption in operating system may also result in network related errors
so just do self test in either jaf or ufs
u can understand situation better
anyway try and stay tuned with this thread
regards,
NEIL
The Following User Says Thank You to neilthirumuttam For This Useful Post:
Old 09-19-2008, 12:28   #37 (permalink)
broken_rules's Avatar
Member: 698819
Thanks Meter: 122
Sir,
ihv a N70 Rcvd White light ..( incoming Outgoing working ),,,
then i applied low heat on Display crystal ic..& after that Set Is dead..So Sir plzz help me
The Following User Says Thank You to broken_rules For This Useful Post:
Old 09-19-2008, 13:15   #38 (permalink)
Member: 351924
Originally Posted by broken_rules View Post
Sir,
brother,both display emi heated?
right emi inside on/off ways
pls insert charger this time phone light trun on
sure that ic damaged
u must change display EMI(2Nos)
post result
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-20-2008, 09:03   #39 (permalink)
Member: 201084
Thanks Meter: 7
Nokia 7610 keypad LED off. Any solution?
Old 09-20-2008, 13:12   #40 (permalink)
Member: 351924
Originally Posted by gsm_research View Post
nokia 7610 keypad led off. Any solution?
bro,display light okey?
Problem only keypad?
Old 09-23-2008, 19:01   #41 (permalink)
Member: 787399
Thanks Meter: 9
dear brother 1110i power off after 5 second of switch on ,i have flashed with jaf with latest version software but no result ,please
help me
Old 09-24-2008, 05:16   #42 (permalink)
Member: 351924
help me
bro,u mean after 5 second phone restarted or trun off?
Old 09-24-2008, 07:54   #43 (permalink)
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
Local mode problem & test mode problem, some general facts
What is local mode?
Local mode is triggered either by a service battery / jig from Nokia being used to power the phone,
A faulty battery, a faulty phone or the phone has got "liquid ingress” also indicate local mode in display
See this picture
s in the above picture when BSI is grounded with a resistor of
5.1k to 7k1 and insert battery, nokia sets displays local/test mode on screen
By this way we can trigger the set in to local mode and software operation through USB
Local mode is triggered for reading & writing phone pm area (EEPROM),
File system formatting etc.
What is test mode?
Test mode is for doing file system removing like full factory defaults
Also can do pm area re-writing and for unlocking the phone
Some phones displays either of these modes directly when battery is inserted to the phone
and we gets in this condition for repairing
This may be either by a faulty battery or damaged hardware in the handset.
We can assume this is a BSI related fault
TEST THE PHONE WITH A WORKING BATTERY
Now what is BSI?
BSI, the thermistor used to sense the battery temperature and shut down the charger
Their is an internal circuit from power IC to BSI lead of battery
this circuit manages charging mechanism and battery sensing.
Faulty parts in this BSI circuit may lead to the local/test mode
Or finally we have to suspect power ic
Here NOKIA 1200 schematic is used to illustrate BSI way and possible reasons for this fault.
he blue colored parts are related to the BSI function .we have to trace from battery connector, capacitors, and then other parts. These parts can be identified by reading the higher level schematic of the phone. By following this logic you may be able to trace local mode in any nokia phone
with regards,
NEIL
nokia repair master team
The Following 13 Users Say Thank You to neilthirumuttam For This Useful Post:
Old 09-24-2008, 10:13   #44 (permalink)
Member: 787399
Thanks Meter: 9
brother after 5 second phone turh off
The Following User Says Thank You to ashokkumohanty For This Useful Post:
Old 09-24-2008, 10:18   #45 (permalink)
Member: 351924
Brother try to full erase flash memory then flash lastest version with pm
same problem again open handset then clean and wash PCB
this cause mainly UEM or RPL problem
post result
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.28920 seconds with 10 queries
