Old 08-25-2020, 12:25   #1501 (permalink)
Member: 1043909
Thanks Meter: 60,926
Originally Posted by farukbiswas View Post
i dont have fault.bin file
Hello,
You have created many threads with the same question.
Please advice what thread should we use for answers ?
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 08-25-2020, 12:41   #1502 (permalink)
Member: 2254630
Thanks Meter: 2
Originally Posted by InfinitySupport View Post
You had the same issue about month ago.
Now make this:
STEP 1: go to folder C:\InfinityBox\CM2MT2\ or C:\InfinityBox\CM2SP2\
STEP 2: find file fault.bin
STEP 3: upload file to https://mega.nz/ and post link here
file fault.bin=https://mega.nz/file/y0JX0SYT#vR_UcjD_3SUNLN0tizgoI49FVtU2blSd3s49WVpmU JE
Old 08-25-2020, 12:57   #1503 (permalink)
Member: 1043909
Should we answer in this thread or in your other thread ?
Please advice
Old 09-28-2020, 08:15   #1504 (permalink)
alorpothe's Avatar
Member: 2235775
Thanks Meter: 351
My dongle is not working:
Fault File:
https://drive.google.com/file/d/1LfE...ew?usp=sharing
=== DongleManager [Infinity] v1.80 [9/28/2020 13:14:08] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 010385681C6A1292
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): D0358568
Firmware version: 0145.02
=== Process started: 9/28/2020 13:14:10 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Write to https://www.infinity-box.com/support/?r=2
Old 09-28-2020, 08:39   #1505 (permalink)
Member: 148515
Thanks Meter: 19,534
Fault File:
Searching...
Reading...
pls do not use camtasiastudio at the same time with Infinty software
now update dongle with DongleManager
then delete fault.bin file
then run Infinity software
Old 10-19-2020, 16:30   #1506 (permalink)
alorpothe's Avatar
Member: 2235775
Thanks Meter: 351
=== DongleManager [Infinity] v1.80 [10/19/2020 21:30:26] ===
Box/Dongle type selected: Infinity-Box/Dongle
Reading...
=== Process started: 10/19/2020 21:30:27 ===
Fault file
Old 10-19-2020, 18:27   #1507 (permalink)
Member: 1043909
Reading...
Fault file
Old 11-02-2020, 13:08   #1508 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
I am facing dongle misconfiguration problem.
not found fault.bin
=== DongleManager [Infinity] v1.80 [11/2/2020 17:34:23] ===
Searching...
Card-Reader: USB Smart Card Reader 0
HWID: 0003697600001942
Box/Dongle found: CDMA-Tool
Serial No (S/N): 103C6976
Firmware version: 0122.02
Box/Dongle misconfiguration
Diagnostic code: 70
"UK Edition" status: Off
Last launched Application: 0030 v.0145
=> Activations:
- 00: Infinity-Box/Dongle v0145
- 01: CDMA-Tool v0122
- 06: #6
- 07: #7
=> Options:
- Infinity CDMA
- Infinity SM
- spt
Need help?
Old 11-02-2020, 14:04   #1509 (permalink)
Member: 1043909
not found fault.bin
Need help?
Hello,
Probably there is a software conflict with the next application(s):
C:\program files (x86)\intel\bluetooth\devmonsrv.exe
C:\program files (x86)\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe
C:\program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe
C:\program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe
C:\program files\via xhci uasp utility\usb3monitor.exe
What to do:
1. Delete or rename files (see above)
2. Reboot PC
3. Delete fault.bn file
4. Update dongle firmware with DongleManager now
5. Run Infinity software.
Old 11-02-2020, 18:57   #1510 (permalink)
Member: 637795
Thanks Meter: 2
help dongle misconfiguration
=== DongleManager [Infinity] v1.80 [11/2/2020 17:53:07] ===
Searching...
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 0000D71900001942
Serial No (S/N): 78D4D719
Diagnostic code: 62
=> Activations:
- 07: #7
=> Options:
- Infinity-Box/Dongle
- Infinity SM
Old 11-02-2020, 21:48   #1511 (permalink)
Member: 1043909
Searching...
Diagnostic code: 62
=> Activations:
- 07: #7
=> Options:
- Infinity SM
Hello,
Why do you use debugger and other crack tools with Infinity software ?
Old 11-02-2020, 21:54   #1512 (permalink)
Member: 637795
Thanks Meter: 2
no please no crack softwares. i have added link to fault.bin file. the box was working correctly and i have active support. i just plugged it into my laptop to service an itel p15 phone and it would not open the software. i tired to update and i got that error here is link to fault.bin https://mega.nz/file/6k4mEIbY#A8R1YN...eyqRix7RztctLA
Old 11-02-2020, 22:17   #1513 (permalink)
Member: 1043909
It was a conflict with "visual studio debugger etw". Do not use it at the same time with Infinity.
Update dongle firmware now
now you can run Infinity software
Old 11-02-2020, 22:26   #1514 (permalink)
Member: 637795
Thanks Meter: 2
thanks i had visual studio open i was working on a project.
Old 11-03-2020, 00:14   #1515 (permalink)
Member: 1043909
As soon as your project will be finished you are welcome to contact us, probably we can cooperate regarding software sales.
Page generated in 0.32177 seconds with 9 queries
