Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1517 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2240574 Status: Offline Thanks Meter: 0 | plz help infinity DongleManager [Infinity] v1.80 [2020-11-05 13:26:25] === Box/Dongle type selected: [BEST] Card-Reader: USB Smart Card Reader 0 HWID: 0007938920881292 === Process started: 2020-11-05 13:26:25 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to |
![]() | #1518 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 59,777 | Quote:
![]() | #1519 (permalink) | |
- Connect dongle/box to PC - Run DongleManager.exe - https://www.infinity-box.com/support/?r=5 - Make "Read Serial Number (S/N)" DO NOT send screenshot/video but copy/paste text from software window ! | |
![]() | #1520 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2805649 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.80 [11/27/2020 10:46:05] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00014220162D4082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 82154220 Firmware version: 0146.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0146 => Activations: - 00: Infinity-Box/Dongle v0146 - 03: [BEST] v0122 - 0E: #14 => Options: - Infinity-Box/Dongle - Infinity BEST2 - hua |
![]() | #1521 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks Meter: 19,175 | Quote:
![]() | #1522 (permalink) |
Junior Member Join Date: Nov 2017 Location: Lahore, Pakistan
Member: 2783921 Status: Offline Thanks Meter: 0 | Hi, Respected infinity team, I need your help for the following error. I got in cm2 opening. [ Smart-Card misconfiguration! Contact to support] And one more error on dongle manager. "=== DongleManager [Infinity] v1.80 [29/11/2020 22:55:51] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0109666524881292 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): D1046665 Firmware version: 0146.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0030 v.0146 => Activations: - 00: Infinity-Box/Dongle v0146 => Options: - Infinity-Box/Dongle" Kindly sir help me in this problem my device is blocked from two days. please help me in this problem. Thanks in advance to Infinity Team. Last edited by ZAMAN 143; 11-29-2020 at 19:30. |
![]() | #1523 (permalink) | |
Read NOTE here - https://www.infinity-box.com/support/?s=2 Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. Next steps: - Delete fault.bin file from software folder (if you have it there) - Run DongleManager - Update Dongle firmware | |
![]() | #1524 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2414357 Status: Offline Thanks Meter: 0 | Box/Dongle misconfiguration === DongleManager [Infinity] v1.80 [27/12/2020 22:15:29] === Searching... Card-Reader: FT SCR2000 0 HWID: 0003956115BF1292 Box/Dongle found: [BEST] Serial No (S/N): D0A99561 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0030 v.0146 => Activations: - 00: Infinity-Box/Dongle v0146 - 03: [BEST] v0122 - 07: #7 => Options: - Infinity BEST - Infinity BEST2 - Infinity SM |
![]() | #1525 (permalink) | |
![]() | #1526 (permalink) | ||
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2014
Member: 2138570 Status: Offline Sonork: 100.1611495 Thanks Meter: 299 | please infinity team need your kind help my dongle is giving (misconfiguration errors) here is seriar info Quote:
and here is update logs Quote:
![]() | #1529 (permalink) |
Junior Member ![]() Join Date: May 2008 Location: palestine Age: 33
Member: 780975 Status: Offline Sonork: bulbul Thanks Meter: 2 | i try to update in another computer also not working then i found i shoud remove samsungfrp2020 and i try to update after reboot the computer === DongleManager [Infinity] v1.80 [2021-01-19 14:19:51] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00027C8E00001942 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): AB6F7C8E Firmware version: 0145.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0145 => Activations: - 00: Infinity-Box/Dongle v0145 - 03: [BEST] v0122 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM === DongleManager [Infinity] v1.80 [2021-01-19 14:19:59] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00027C8E00001942 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): AB6F7C8E Firmware version: 0145.02 === Process started: 2021-01-19 14:20:02 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
![]() | #1530 (permalink) | |
Please make step-by-step: - reboot PC - update dongle with DongleManager - delete fault.bin file (if any) | |
