Old 11-09-2021, 14:47   #76 (permalink)
Member: 148515
Thanks Meter: 19,537
Originally Posted by shahnazari View Post
hi i have this problem with my dongle
i cant update it.
=== DongleManager [Infinity] v1.88 [11/9/2021 11:21:50 AM] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 00003BF721F34082
Box/Dongle found: Infinity-Box/Dongle [CM2]
Reading...
Serial No (S/N): 30F03BF7
Firmware version: 0150.02
=== Started: 11/9/2021 11:21:52 AM ===
Connecting to server...
Connection successfully established
Checking DongleManager version...
DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer: [0031] Dongle identification data damaged.
Write to https://www.infinity-box.com/support/?r=2
Do you want to report an issue to Support?
No
Username: 0030F03BF7
==> Scan c:\InfinityBox for report.log
==> Scan c:\Program Files for report.log
Found files: 0
==> Scan c:\InfinityBox for *.ibin.log
==> Scan c:\Program Files for *.ibin.log
Found files: 0
==> Scan c:\InfinityBox for fault.bin
==> Scan c:\Program Files for fault.bin
Found files: 0
No reports found
Dear Sir,
Please tell me, do you have flexihub and other usb sharing tools finally uninstalled?
Yes or No?
Old 11-10-2021, 15:16   #77 (permalink)
Member: 2788489
Sonork: 1000000.1000
Thanks Meter: 36
Username: 00F87C39CC
==> Scan D: for report.log
Found files: 0
==> Scan D: for *.ibin.log
Found files: 0
==> Scan D: for fault.bin
Found files: 1
Upload: c:\InfinityBox\CM2MT2\fault.bin
Delete: c:\InfinityBox\CM2MT2\fault.bin
You can contact to support with this reference: Ticket-ID:1636553720.816~00F87C39CC~fault.bin;
Answer is here https://forum.infinity-box.com//viewtopic.php?p=4997
Old 11-10-2021, 16:19   #78 (permalink)
Member: 759026
Thanks Meter: 27
Dear Sir,
Yes or No?
this dongle is for one of my friend.maybe he didnt tell me the truth or he doesnt know that cant install usb sharing beside of infinty product. if he uninstalled and never install again the problem is solved?
or it have another problem?
Old 11-11-2021, 23:45   #79 (permalink)
Member: 1043909
Thanks Meter: 60,993
Dear Sir,
Yes, in most cases there is a solution.
But you give us no answers and no information yet.
We have asked simple question about installed flexihub. If you do not have answer now please ask your friend and after that we will try to find a soluton for you.
Old 11-11-2021, 23:46   #80 (permalink)
Member: 1043909
Found files: 0
Found files: 0
Found files: 1
Very good!
Please click to link and you will see a solution.
Is it solved now or do you have any problem?
Old 11-12-2021, 23:08   #81 (permalink)
Member: 1881848
Thanks Meter: 7
Diagnostic code: 66
Уже два дня мучаеюсь.
Read SN
=== DongleManager [Infinity] v1.88 [13.11.2021 3:04:55] ===
Searching...
HWID: 000055111BE14082
Serial No (S/N): F0775511
Box/Dongle misconfiguration
Diagnostic code: 66
"UK Edition" status: Off
Last launched Application: 0032 v.0150
=> Activations:
- 00: Infinity-Box/Dongle [CM2] v0150
=> Options:
- Infinity-Box/Dongle [CM2]
Updade Firmvare
=== DongleManager [Infinity] v1.88 [13.11.2021 3:06:01] ===
Box/Dongle type selected: Infinity-Box/Dongle [CM2]
Reading...
=== Started: 13.11.2021 3:06:02 ===
Diagnostic code: 66
Username: 00F0775511
==> Scan c:\Program Files (x86) for report.log
Found files: 0
==> Scan c:\Program Files (x86) for *.ibin.log
Found files: 0
==> Scan c:\Program Files (x86) for fault.bin
Found files: 0
No reports found
Old 11-12-2021, 23:22   #82 (permalink)
Member: 1881848
Thanks Meter: 7
On this OS, nor when Flexihub type programs are not installed
Old 11-13-2021, 06:24   #83 (permalink)
Member: 2450214
Thanks Meter: 106
cm2sp2 close everytime i try to perform an operation and cm2mt2 stuck at brom init no matter which mtk i connect.
i even intall a fresh windows 11 and its the same.
i had usb redirect and flexi hub on it but i removed them both and still the same.
no fault bin in the folders
Old 11-13-2021, 06:48   #84 (permalink)
Member: 2067643
Sonork: 1611265
Thanks Meter: 476
just change cm2sp2 and cm2mtk2 instal location
working fine
Old 11-13-2021, 08:53   #85 (permalink)
Member: 1043909
After you killed dongle with usb sharing it's not important what PC to use. Once killed it become killed.
1. Read this https://infinity-box.com/legal/eula/
2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software
3. Reboot PC
Make the next steps ONLY after uninstall usb sharing tool otherwise YOU MAY DAMAGE your dongle!
4. Update dongle firmware with Infinity DongleManager
Old 11-13-2021, 08:55   #86 (permalink)
Member: 1043909
You still have sharing drivers installed at your PC.
make this https://forum.gsmhosting.com/vbb/f29...e-exe-2975194/
Old 11-15-2021, 12:57   #87 (permalink)
Member: 759026
Thanks Meter: 27
Originally Posted by YellowBoss View Post
Dear Sir,
hi dear. yes unfortunately he had installed flexihub now i said to him unninstall it and install new windows os .now what he has to do?dongle get fixed?
Old 11-15-2021, 15:07   #88 (permalink)
Member: 1043909
3. Reboot PC
Old 11-15-2021, 20:41   #89 (permalink)
Member: 759026
Thanks Meter: 27
3. Reboot PC
yes i have read the rules althogh that know most of them.i tell my friend to read it too and obey them.thanks for your support and answer.i try to update with new os and tell the result.
Old 11-18-2021, 05:55   #90 (permalink)
Member: 2611962
Please help me to fix this issue
"Box/Dongle misconfiguration"
=== DongleManager [Infinity] v1.88 [18.11.2021 8:43:07] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 00011C8913114082
Serial No (S/N): 99301C89
Firmware version: 0138.02
Diagnostic code: 5A
Last launched Application: 0034 v.0138
=> Activations:
- 00: Infinity-Box/Dongle [CM2] v0138
- 07: #7
Diagnostic key: 7F9CE45B57E9BDF0
=> Options:
- Infinity SM
Page generated in 0.27755 seconds with 9 queries
