11-09-2021, 14:47 | #76 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,537 | Quote:
Please tell me, do you have flexihub and other usb sharing tools finally uninstalled? Yes or No? | |
11-10-2021, 15:16 | #77 (permalink) |
Junior Member Join Date: Dec 2017 Location: Bangladesh
Member: 2788489 Status: Offline Sonork: 1000000.1000 Thanks Meter: 36 | Username: 00F87C39CC ==> Scan D: for report.log ==> Scan c:\InfinityBox for report.log ==> Scan c:\Program Files for report.log Found files: 0 ==> Scan D: for *.ibin.log ==> Scan c:\InfinityBox for *.ibin.log ==> Scan c:\Program Files for *.ibin.log Found files: 0 ==> Scan D: for fault.bin ==> Scan c:\InfinityBox for fault.bin ==> Scan c:\Program Files for fault.bin Found files: 1 Upload: c:\InfinityBox\CM2MT2\fault.bin Delete: c:\InfinityBox\CM2MT2\fault.bin You can contact to support with this reference: Ticket-ID:1636553720.816~00F87C39CC~fault.bin; Answer is here https://forum.infinity-box.com//viewtopic.php?p=4997 |
11-10-2021, 16:19 | #78 (permalink) | |
Junior Member Join Date: Apr 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 759026 Status: Offline Thanks Meter: 27 | Quote:
or it have another problem? | |
11-11-2021, 23:45 | #79 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,993 | Quote:
Yes, in most cases there is a solution. But you give us no answers and no information yet. We have asked simple question about installed flexihub. If you do not have answer now please ask your friend and after that we will try to find a soluton for you. | |
11-11-2021, 23:46 | #80 (permalink) | |
Please click to link and you will see a solution. Is it solved now or do you have any problem? | |
11-12-2021, 23:08 | #81 (permalink) |
Junior Member Join Date: Feb 2013 Location: Узбе&#
Member: 1881848 Status: Offline Thanks Meter: 7 | Diagnostic code: 66 Уже два дня мучаеюсь. Read SN === DongleManager [Infinity] v1.88 [13.11.2021 3:04:55] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000055111BE14082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): F0775511 Firmware version: 0150.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0032 v.0150 => Activations: - 00: Infinity-Box/Dongle [CM2] v0150 => Options: - Infinity-Box/Dongle [CM2] Updade Firmvare === DongleManager [Infinity] v1.88 [13.11.2021 3:06:01] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000055111BE14082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): F0775511 Firmware version: 0150.02 === Started: 13.11.2021 3:06:02 === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 Do you want to report an issue to Support? Box/Dongle type selected: Infinity-Box/Dongle [CM2] Box/Dongle misconfiguration Diagnostic code: 66 Username: 00F0775511 ==> Scan c:\InfinityBox for report.log ==> Scan c:\Program Files for report.log ==> Scan c:\Program Files (x86) for report.log Found files: 0 ==> Scan c:\InfinityBox for *.ibin.log ==> Scan c:\Program Files for *.ibin.log ==> Scan c:\Program Files (x86) for *.ibin.log Found files: 0 ==> Scan c:\InfinityBox for fault.bin ==> Scan c:\Program Files for fault.bin ==> Scan c:\Program Files (x86) for fault.bin Found files: 0 No reports found |
11-13-2021, 06:24 | #83 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Jamaica
Member: 2450214 Status: Offline Thanks Meter: 106 | cm2sp2 close everytime i try to perform an operation and cm2mt2 stuck at brom init no matter which mtk i connect. i even intall a fresh windows 11 and its the same. i had usb redirect and flexi hub on it but i removed them both and still the same. no fault bin in the folders |
11-13-2021, 08:53 | #85 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,993 | After you killed dongle with usb sharing it's not important what PC to use. Once killed it become killed. 1. Read this https://infinity-box.com/legal/eula/ 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software 3. Reboot PC Make the next steps ONLY after uninstall usb sharing tool otherwise YOU MAY DAMAGE your dongle! 4. Update dongle firmware with Infinity DongleManager Last edited by YellowBoss; 11-13-2021 at 14:32. |
11-13-2021, 08:55 | #86 (permalink) | |
make this https://forum.gsmhosting.com/vbb/f29...e-exe-2975194/ | |
11-15-2021, 12:57 | #87 (permalink) | |
11-15-2021, 15:07 | #88 (permalink) | |
1. Read this https://infinity-box.com/legal/eula/ 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software 3. Reboot PC Make the next steps ONLY after uninstall usb sharing tool otherwise YOU MAY DAMAGE your dongle! 4. Update dongle firmware with Infinity DongleManager | |
11-15-2021, 20:41 | #89 (permalink) | |
11-18-2021, 05:55 | #90 (permalink) | |
Junior Member Join Date: Aug 2016
Member: 2611962 Status: Offline Thanks Meter: 1 | Please help me to fix this issue "Box/Dongle misconfiguration" Quote:
