11-26-2021, 13:12 | #106 (permalink) |
Insane Poster Join Date: Sep 2012 Location: Ukraine
Member: 1817812 Status: Offline Sonork: 100.1621578 Thanks Meter: 4 | Code: === DongleManager [Infinity] v1.88 [2021-11-26 14:11:36] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: FT SCR2000 0 HWID: 0104965808B51292 === Started: 2021-11-26 14:11:38 === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
11-26-2021, 14:09 | #107 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Now make this: 1. Install REQUIRED Card-Reader Drivers - https://infinity-box.com/support/?r=6 - Drivers: CardReader_Fetian_FT2K.7z - Instruction: How_to_update_FT_SCR2000_CardReader_drivers.pdf Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Update dongle with Infinity DongleManager | |
11-27-2021, 07:37 | #109 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1093509 Status: Offline Thanks Meter: 5 | Cm2 miss configuration error Searching... Box/Dongle misconfiguration Diagnostic code: 70 Username: 00104C12A3 ==> Scan C:\Users\Allah\Downloads\Compressed\DongleManager for report.log ==> Scan c:\InfinityBox for report.log ==> Scan c:\Program Files for report.log ==> Scan d:\Program Files for report.log ==> Scan c:\Program Files (x86) for report.log Found files: 0 ==> Scan C:\Users\Allah\Downloads\Compressed\DongleManager for *.ibin.log ==> Scan c:\InfinityBox for *.ibin.log ==> Scan c:\Program Files for *.ibin.log ==> Scan d:\Program Files for *.ibin.log ==> Scan c:\Program Files (x86) for *.ibin.log Found files: 0 ==> Scan C:\Users\Allah\Downloads\Compressed\DongleManager for fault.bin ==> Scan c:\InfinityBox for fault.bin ==> Scan c:\Program Files for fault.bin ==> Scan d:\Program Files for fault.bin ==> Scan c:\Program Files (x86) for fault.bin Found files: 0 No reports found |
11-27-2021, 08:10 | #110 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Bangladesh
Member: 1437757 Status: Offline Sonork: 100.1584492 Thanks Meter: 301 | Quote:
dear inifinity team, I always respect you because with your support we are able to work today. I just want to say that I did not use any crack tool. I work with Visual Studio and have other flash tools installed on my PC like chimera, UMT etc. | |
11-27-2021, 13:48 | #111 (permalink) | |
1. Reboot PC 2. Update dongle firmware with Infinity DongleManager You should always close drivers installer completely and reboot PC before run Infinity software | |
11-27-2021, 13:51 | #112 (permalink) | |
You can try to update dongle firmware now but as I tld earlier - you do not provide required information so I can not be sure in result. If you are lucky your dongle may be fixed but absolutelly no guarantee. You can try. | |
11-28-2021, 12:49 | #113 (permalink) | |
Thank you very much Infinity Team, My dongle problem has been solved. Thank you again for your support. | |
12-01-2021, 13:05 | #114 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | = DongleManager [Infinity] v1.88 [12/1/2021 1:29:36 AM] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000308421F34082 Box/Dongle found: Infinity-Box/Dongle [CM2] Serial No (S/N): 4D983084 Firmware version: 0150.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0032 v.0150 => Activations: - 00: Infinity-Box/Dongle [CM2] v0150 => Options: - Infinity-Box/Dongle [CM2] Friend Dongle Blocked! Due to USB redirector was opened! |
12-01-2021, 22:06 | #115 (permalink) | |
1. Read this https://infinity-box.com/legal/eula/ 2. Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software 3. Reboot PC Make the next steps ONLY after uninstall usb sharing tool otherwise YOU MAY DAMAGE your dongle! 4. Update dongle firmware with Infinity DongleManager | |
12-03-2021, 13:19 | #116 (permalink) |
Junior Member Join Date: May 2011
Member: 1579259 Status: Offline Thanks Meter: 4 | cm2 update problem === DongleManager [Infinity] v1.88 [12/3/2021 5:15:16 PM] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000B5E77D314082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): DB11B5E7 Firmware version: 0150.02 === Started: 12/3/2021 5:15:18 PM === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0006] Your account is temporary suspended. See more in log file Write to https://www.infinity-box.com/support/?r=2 |
12-03-2021, 13:33 | #117 (permalink) | |
After that update dongle ONLY ONCE! If you will attack server many times YOU may kill your smart-card | |
12-04-2021, 07:48 | #118 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | === DongleManager [Infinity] v1.88 [12/4/2021 10:46:17 AM] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: FT SCR2000 0 HWID: 000109B77CEC4082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): D88609B7 Firmware version: 0150.02 === Started: 12/4/2021 10:46:20 AM === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0006] Your account is temporary suspended. See more in log file Write to https://www.infinity-box.com/support/?r=2 one of my friend get this error i changed smart card reader also but still same any solution sir |
12-04-2021, 11:45 | #119 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1495229 Status: Offline Thanks Meter: 0 | my infinity dongle refuses to update in a year === DongleManager [Infinity] v1.88 [04/12/2021 11:10:53] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 1 HWID: 0001C2E8FF021982 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 091CC2E8 Firmware version: 0146.02 === Started: 04/12/2021 11:10:56 === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0006] Your account is temporary suspended. See more in log file Write to my infinty account isn't expired yet by the way |
12-04-2021, 12:18 | #120 (permalink) | |
