12-26-2010, 15:00 | #7531 (permalink) |
No Life Poster Join Date: Jun 2005 Location: rawalpindi,pakistan.
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | module v3.41 Action: reset settings ("format ffs") Model: LG-KG200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:9241:A2E8 status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7330SA00-001-R1D Version: EP1 60 byte(s) read imei: 35282701599202 connection Ok building list... done items to clear: 204 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 177 of 204 building list... done items remains: 0 Finished, time used: 2 min 41 sec Remove/Install battery now ! |
12-26-2010, 15:01 | #7532 (permalink) |
Freak Poster Join Date: Sep 2010 Location: searching Age: 39
Member: 1404229 Status: Offline Sonork: 100.1612419 Thanks Meter: 44 | COM6 [VCP4] selected module v3.70 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:AE03:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.9C152 524.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_96593190].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 9C152524 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 90315996 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17D provider: 708X-2ATLES1 customization: CN17DW92 customization: XN17DW92 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17DW92 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17DW92 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703534952 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_9C152524_96593190_20 101212-120502.B0X.bin Finished, time used: 4 min 10 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-26-2010, 15:01 | #7533 (permalink) |
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | COM13 [VCP17] selected module v3.41 Device: Alcatel-600X, 600A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9403:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F40CF 596.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: F40CF596 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2AVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35765602098523 flash: 98000300000001:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600X,600A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__system_log_F40CF596_C4B7397C_2010 0622-184120.B0X.bin Finished, time used: 3 min 53 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On |
12-26-2010, 15:03 | #7534 (permalink) |
Member: 1404229 Status: Offline Sonork: 100.1612419 Thanks Meter: 44 | COM8 [VCP13] selected module v3.70 Device: LG-KG200 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:AB412BC status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7T-7330-BFRA-6-061110.BIN project-id: 7T-7330-BFRA-6-061110, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: LG-KG200_ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7T-7330-BFRA-6-061110__ffs... file saved: C:\Program Files\InfinityBox\MModule\LG-KG200_ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7T-7330-BFRA-6-061110__ffs_20101211-195444.A3E.bin flash: 98004900000002:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:29EA0000000000 Finalization Done Finished, time used: 1 min 35 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-26-2010, 15:04 | #7535 (permalink) |
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | [Infinity Box] MModule v3.41 smart-card: connected S/N: 153E:0116 Wait... Device: LG-KP199 Done COM3 ready Action: "repair imei" Model: LG-KP199 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 353133023521422 imei write method: mode-1 new imei-1: 350215656565629 verification Ok Finished, time used: 10 sec Remove/Install battery now ! |
12-26-2010, 15:06 | #7536 (permalink) |
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | COM21 [VCP3] selected module v3.41 Device: Alcatel-303X, 303A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9B48:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.FD6E6 B92.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_6483DA11].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: FD6E6B92 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, 11DA8364 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 16G provider: 303X-2BSFFR1 customization: CI16CQ11 customization: XI16CQ11 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI16CQ11 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35861002219463 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-303X,303A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__system_log_FD6E6B92_6483DA11_2010 0929-030032.B0X.bin Finished, time used: 2 min 58 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-26-2010, 15:06 | #7537 (permalink) |
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | COM3 [VCP0] selected module v3.41 Action: read unlock codes unlock method: read codes Model: LG-KP199 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:42BD:A2D8 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7339RU00-001-R1B Version: EP2_HW 44 byte(s) read imei: 35313302093373 connection Ok 157 byte(s) read 166 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 5432 Finished, time used: 13 sec Remove/Install battery now ! |
12-26-2010, 15:07 | #7538 (permalink) |
Member: 1404229 Status: Offline Sonork: 100.1612419 Thanks Meter: 44 | COM8 [VCP4] selected module v3.70 Action: read unlock codes unlock method: read codes Model: LG-KP199 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:73D3:5D3E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Version: 1.0 Version: 7S7339SA00-002-R1C Version: EP2_HW 44 byte(s) read imei: 35313302352175 connection Ok 157 byte(s) read 166 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 5774584 Finished, time used: 12 sec Remove/Install battery now ! |
12-26-2010, 15:08 | #7539 (permalink) |
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | COM3 [VCP2] selected module v3.41 Action: read unlock codes Model: Motorola-WX180 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:69C8:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: MAUI.08A.W08.36.SP1.V28.F1 Version: JRD23_NEP_08A_HW 80 byte(s) read imei: 35668103503025 connection Ok 193 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 Finished, time used: 39 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! |
12-26-2010, 15:08 | #7540 (permalink) |
Member: 1404229 Status: Offline Sonork: 100.1612419 Thanks Meter: 44 | COM8 [VCP4] selected module v3.70 Action: "user code" unlock method: smart fast Model: LG-KP199 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:73D3:5D3E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7339SA00-002-R1C Version: EP2_HW 44 byte(s) read imei: 35313302352175 connection Ok 157 byte(s) read reading data... building new data... writing data... user code set to: 0000 Finished, time used: 16 sec Remove/Install battery now ! |
12-26-2010, 15:09 | #7541 (permalink) |
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | COM3 [VCP2] selected module v3.41 Action: reset settings ("format ffs") Model: Motorola-WX180 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:69C8:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: MAUI.08A.W08.36.SP1.V28.F1 Version: JRD23_NEP_08A_HW 80 byte(s) read imei: 35668103503025 connection Ok building list... done items to clear: 108 items cleared: 108 of 108 building list... done items remains: 0 Finished, time used: 28 sec Remove/Install battery now ! |
12-26-2010, 15:11 | #7542 (permalink) |
Member: 1404229 Status: Offline Sonork: 100.1612419 Thanks Meter: 44 | OM6 [VCP2] selected module v3.70 Action: "sp-unlock" unlock method: smart fast Model: ZTE-X991 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Version: 1.0 Version: X991_V1_Z2_FRES_D1EF114 Version: ZTEMT35_09A_GEMINI_HW 86 byte(s) read imei: 35294504155555 connection Ok 192 byte(s) read reading data... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... reading data #2... verification Ok done Finished, time used: 18 sec Remove/Install battery now ! |
12-26-2010, 15:12 | #7543 (permalink) |
Member: 1404229 Status: Offline Sonork: 100.1612419 Thanks Meter: 44 | COM5 [Serial2] selected module v3.70 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35424903297787 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
12-26-2010, 15:12 | #7544 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | Success dead repair Code: COM17 [VCP1] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8981:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 20.10.2010): MT226_AB_PCB01_GPRS_MT6223P_S00.B_ST7669V_V1_3.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: MT226_AB_PCB01_GPRS_MT6223P_S00.B_ST7669V_V1_3.BIN project-id: MT226_AB.B.ST7669V.V1.3, 00000000 code offset: 00000000 ffs offset/size [01]: 00E80000/00180000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E80000 standard ffs/eeprom offset confirmed: 00E80000 detecting ffs/eeprom size... ffs/eeprom size: 00180000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E80000-00FFFFFF firmware area: 00000000-00E7FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MT226_AB_PCB01_GPRS_MT6223P_S00.B_ST7669V_V1_3__ffs... file saved: C:\Users\AlaM\Desktop\MT226_AB_PCB01_GPRS_MT6223P_S00.B_ST7669V_V1_3__ffs_20101125-113330.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:29EA0000000000 Finalization Done Finished, time used: 3 min 20 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-26-2010, 15:13 | #7545 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | Imei repair success Code: COM32 [VCP0] selected module v3.25 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 357385011336355 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4203:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: R206AN_ZB_N100_F15_V05_091217 Version: RONCENT25_GEMINI_08B_HW detecting structure #2... 1 2 3 5 7 8 9 11 13warning: wrong packet cs done 80 byte(s) read imei: FFFFFFFFFFFFFF connection Ok detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read verification... verification done: 35738501133635 Finished, time used: 21 sec Remove/Install battery now ! |
