Hardware Equipments for GSM All about Hardware Instruments and equipments like Soldering Stations, Hardware Tools, Oscilloscopes , Frequency Counters ..ext. |
View Poll Results: we must have an oscilloscope to repair hardware | |||
yes | 1,117 | 72.39% | |
no | 437 | 28.32% | |
Multiple Choice Poll. Voters: 1543. You may not vote on this poll |
12-05-2008, 09:51 | #62 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Lithuania
Member: 378743 Status: Offline Thanks Meter: 21 | Yes It's a good to have all equipment like oscilloscopes,spectrum analyzers,GSM testers.But i cannot imagine phone repair,which cost 50..100EU and equipment,which cost thousand's of EU or more,needed qualification and time spend on this.Cause in most cases ,when this equipment is needed,phone are after water or mechanical damage,which will lead to unrepairable situation. So,to repair 2..3 phone from 10,it's time wasting. I agree with those- is needed good brain,expirience,multimeter,ServiceManual,good resolder tools and sometimes easy oscilloscope. br |
12-05-2008, 11:23 | #63 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | These photos show exactly that. Oscilloscope makes you "look" proffesional, and means you can charge more money to run a repair course. But really, it is useful? Personally, I dont think so. I use oscilloscope in other areas, when designing circuits or creating test procedures. Also I have repaired many many phones since < 2001. Guess how many times I used oscilloscope on GSM board? none. Your phone is dead? -> connnect on flasher and see error messages. Your phone has no signal? -> do manual network search, is problem Tx or Rx? Of course, we know the charge ways, signal ways, keypad ways from simply looking at the circuit board and using 10 years built knowledge working with these devices! This method is fully tested in a repair centre, there is NO REAL NEED for 'scope! |
The Following 3 Users Say Thank You to Dave.W For This Useful Post: |
12-05-2008, 12:05 | #64 (permalink) | |
Product Manager Join Date: Sep 2003 Location: Indonesia Age: 45
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,155 | Quote:
sorry sir,,, im really like this thread cause we can talk each other and hope can be good study about what we discuss here.... I use osciloscope not only to make me look profesional.... but I use it cause i need it.... i have 2 osciloscope and i use it every day specially for Signal and Dead phone..... Why i use it???? cause we know that all of voltage and data at a phone can be measured.... so if we wanna know an IC is bad or good we have to know that the out put of the IC is correct.... for example, For Dead Phone in WD2 like 6600, with 1st boot error message at Flasher Box Like UFS, we must measure some indicator that can make our Phone to be 1st boot OK What is that???? The conditions to make 1st ok when flashing is : Vio = 1,8 Volt Vcorea = 1,5 volt Vana = 2,8 Volt Vr3 = 2,8 Volt PURX = 1,8Volt Sleepx = 1,8 Volt Sleep Clock = 32,768 Mhz Rf Clock = 26 Mhz If all condition above normal our phone must be 1st ok, if still error the problm must be at CPU In Signal Problem, Im very depended with oscilocope.... Why??? cause in signal problem many indicator that cant measured with Multi tester, but must with osciloscope like : Rx i / q from Rf Ic to UEM RF Bus data from CPU to RF ic Control VCO from Rf Ic to VCO, etc if one of this not normal, our phone must be NO RX.... How we can see that indicator with multi tester??? how we can analysis a damaged without this measurement???? thats why i use osciloscope... cause its very important to make me sure about a fungtion of some ic... to know its damaged or not... Not For High Cost, Not For Look Profesional... but to make me easy in working.... Sorry... just for share... and i hope we can support each other... regards | |
The Following 11 Users Say Thank You to Rizal Arsyad Dini For This Useful Post: |
12-05-2008, 18:12 | #66 (permalink) |
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,155 | if we have signal problem, we must make sure aboutn what is is broken... causen signal problem specially RX Problem can be cause by many componen faults.. like RF IC, VCO, CPU, UEM, and Oscilator 26Mhz.... how we know that that ic is damaged?????? of course by make a measurement.... what tool that we use to make it sure??? one of this, and i think the accurate tools is osciloscope and frequensy counter... with this tool and reading schematic.. we will know the broken component... regards |
12-05-2008, 18:54 | #67 (permalink) | |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76257 Status: Offline Thanks Meter: 77 | Quote:
oscilloscopes are good for repairing vcrs ,cd players and cordless phones and ofcourse televisions because of big and many pcbs bieng installed in 1 device thus making it difficult for fault finding and thats where these oscilloscopes are usefull and frequency counters come in handy for cordless phone repair ,so all in all oscilloscopes are not that usefull for gsm phone repair as most of the phones these days have 1 to 3 main chips installed on a single pcb thus making it easy to find the fault on much lesser covered area with components ,and mostly faults are due to broken or dry connections ,and instead of having an oscilloscope as must device , one should invest in a very good rework station with preheaters and digital temp controls and a high quality tipped ,soldering iron for precise soldering --no offence or criticism to anybody its just my experiance and opinion --regards @ all==b.r.=cpukiller Last edited by CPUKILLER; 12-05-2008 at 19:04. | |
The Following 3 Users Say Thank You to CPUKILLER For This Useful Post: |
12-05-2008, 19:20 | #69 (permalink) |
Member: 378743 Status: Offline Thanks Meter: 21 | @ ichal_spy In theory ,You're absolutely right But practically,today's parts are very good quality,and pcb place are too small to measure signals (or impossible).SEMC even SM are impossible to find.And phones will do not become HW broken without serious reason In 99% chances of RF problems are mechanical pcb/parts damage (ceramical RX/TX switches,broken bga balls under RF and CPU interfaces...etc) Sometimes,here are TX PA burn out. But i remember 3310 phones,in TX 90% case -it were mechanical PA damage (with ceramic pad).In RX case -broken ceramic switch after fall. I've repaired a lot.Just 1 phone from 10..20 were needed scope So,good knowledge and experience may replace expensive equipment. I don't saying,that i do not use scope br |
12-05-2008, 19:34 | #70 (permalink) |
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,155 | Not only teory sir.. i have told u that I use it Everyday... and when i training some technician... i always told them to use osciloscope... Oh godness.... I use this tools since 2004 until today... So.. Not only in theory..... So whay this picture including in Nokia Schematic if not for measurement??? they make us easy with that picture... but up to u all... i just try to share here.... and i hope we can be better than now... regards |
The Following User Says Thank You to Rizal Arsyad Dini For This Useful Post: |
12-05-2008, 20:15 | #72 (permalink) |
Member: 378743 Status: Offline Thanks Meter: 21 | Ok,but how many phones comes with such faults in %?Lets say,some phase or frequency errors,for example.I remember some early Samsung's R210 in this case.People with experience knows about what I'm talking. And how much cost entry level spectrum analyzer?I mean very professional repair level.Now compare with some 6030 phone,which cost now ~20EU,cause not everybody walks with N95 or N85.Lets look at 5310 board RF part for example.How chips are arranged.-most no discret components here,only bga's I in the near future i see only bga's in the phones, sealed with epoxy I wanna just say this:doesn't matter equipment You have use-they main goal are HOW do you use it and what are final result. br |
The Following 2 Users Say Thank You to medis For This Useful Post: |
12-05-2008, 20:55 | #73 (permalink) |
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,155 | you're right... exacly i use osciloscope only for Nokia, i can download this schematic easly.... and i just ue it for dead phone and signal problem.. br |
12-06-2008, 09:55 | #75 (permalink) |
Freak Poster Join Date: Feb 2008 Location: B O G R A
Member: 713887 Status: Offline Sonork: 100.1613421 Thanks Meter: 37 | oscilloscope is the important device for gsm fault finding........... but its too expansive for general technician |
The Following User Says Thank You to sp@cific For This Useful Post: |
Which is the best gsm field to Work??? | sallu | GSM Programming & Reverse Engineering | 8 | 03-22-2007 07:14 |
what is the best route to buying cdma equipment | jesto80 | Various CDMA/TDMA Cell Phones | 1 | 03-13-2007 04:01 |
HackGSM web site updated. Jouin Us for the best GSM equipment and price for it! | hackgsm.net | Main Sales Section | 0 | 03-27-2005 11:59 |
All the best GSM Hardware devices! | stargsm | Main Sales Section | 0 | 03-11-2003 19:53 |
