10-10-2012, 19:48 | #559 (permalink) |
Major Poster Join Date: May 2001 Location: Budapest, Hungary Age: 58
Member: 4755 Status: Offline Thanks Meter: 6 | Dear kaisak, please help! Box Serial Number: C000188C Yesterday: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.713 Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000188C 2009, wk19 Initializing security card... Card Serial Number: D3000129 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,14v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,78v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,10v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,07v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.781GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Today: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.713 Establishing Connection with Box in Main Mode... Initialization has failed -> No connection was established, or box is not in needed mode Box Wizard will registry again my box, but it finished all time with error. Box activated at: 2009-09-02. |
10-11-2012, 19:34 | #562 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Quote:
10-11-2012, 20:04 | #563 (permalink) |
Member: 4755 Status: Offline Thanks Meter: 6 | Box Maintenance procedure started at 9:03:22 PM Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: 3D4CA9030101000073528BF901800000 Connecting to Cyclone Server Cyclone Server (2.0.0.54), Cyclone Box Team 2008-2012 - Ready. ========= Box Info ========= Cyclone Server Send Command Error -> Code: 500, Given ServiceTag was not found in database Box Maintenance Error -> Server command send error |
10-12-2012, 06:49 | #564 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
mmhhh.. looks like this box needs to be solved via remote support: contact me or kaisak in private to make some check on it via teamviewer BR Alex | |
The Following User Says Thank You to moulnisky For This Useful Post: |
10-16-2012, 15:24 | #566 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 966792 Status: Offline Sonork: 100.1602610 Thanks Meter: 199 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Box Firmware Version Read Failed -> No answer from CBUS Initialization has failed -> No connection was established, or box is not in needed mode Box serial number :CYA18359 |
10-16-2012, 21:17 | #568 (permalink) | |
problem with my cyclone box.box is not in needed mode | samih127 | Cyclonebox | 18 | 06-12-2010 06:05 |
Box is not in needed mode [SOLVED] | renren | Cyclonebox | 2 | 01-19-2010 22:38 |
::solve:: box is not in needed mode | mr khalid | Cyclonebox | 6 | 09-15-2009 08:36 |
Cyclone team (not connected) box is not in needed mode | tims | Cyclonebox | 17 | 06-29-2009 03:54 |
Box is not in needed mode. | masterunlock | Cyclonebox | 5 | 03-24-2009 16:44 |
