Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 10-03-2012, 15:42   #556 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by ahmedksal View Post
Hi,
box was okay before this update. See attached and have a nice day.
Yes and you paste me service tag- did you try make box wizard after paste?
Old 10-07-2012, 05:04   #557 (permalink)
Member: 1195192
Thanks Meter: 26
Box is Not IN Needed Mod
HI,
Please help check,
Cyclone Box Service Tag: B314876DBEC9BA77F7323FCA1832C7D4
tia,
Old 10-07-2012, 11:28   #558 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by 4khmer.com View Post
HI,
Please help check,
tia,
Try update now box via wizard.
The Following User Says Thank You to kaisak For This Useful Post:
Old 10-10-2012, 19:48   #559 (permalink)
Member: 4755
Thanks Meter: 6
Dear kaisak, please help!
Box Serial Number: C000188C
Yesterday:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.713
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
2009, wk19
Initializing security card...
Card Serial Number: D3000129
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5,14v PASSED
MCU Voltage 3,30v PASSED
Core Voltage 1,78v PASSED
VBAT Voltage 0,01v PASSED
VBAT Voltage 5,10v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 5,06v PASSED
Box VPP disabled
VPP Voltage 0,07v PASSED
External Box VPP Enabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 3.1023GB
Avaiable Virtual Memory: 1.781GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Today:
Initialization has failed -> No connection was established, or box is not in needed mode
Box Wizard will registry again my box, but it finished all time with error.
Box activated at: 2009-09-02.
Old 10-11-2012, 15:42   #560 (permalink)
Crash2's Avatar
Member: 5525
Thanks Meter: 36
Help Box Firmware empty after UPDATE
Cyclone Box Service Tag: 30C062CDDCF5E4F96963676A5C15ADF3
Old 10-11-2012, 19:32   #561 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Your box is ready for update pls use box wizard.
Old 10-11-2012, 19:34   #562 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Yesterday:
Initializing box...
2009, wk19
Card is activated
Box is activated
Box VPP disabled
Box VPP disabled
Box VPP disabled
Today:
Hello Your box is ready for update Regards
Old 10-11-2012, 20:04   #563 (permalink)
Member: 4755
Thanks Meter: 6
Box Maintenance procedure started at 9:03:22 PM
Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support
Service Tag: 3D4CA9030101000073528BF901800000
Connecting to Cyclone Server
Cyclone Server (2.0.0.54), Cyclone Box Team 2008-2012 - Ready.
========= Box Info =========
Cyclone Server Send Command Error -> Code: 500, Given ServiceTag was not found in database
Box Maintenance Error -> Server command send error
Old 10-12-2012, 06:49   #564 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
mmhhh.. looks like this box needs to be solved via remote support: contact me or kaisak in private to make some check on it via teamviewer
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 10-16-2012, 12:46   #565 (permalink)
Member: 4755
Thanks Meter: 6
Dear Alex!
Any news from my problem?
Old 10-16-2012, 15:24   #566 (permalink)
mayank.gupta's Avatar
Member: 966792
Sonork: 100.1602610
Thanks Meter: 199
Initializing box...
CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe)
Box Firmware Version Read Failed -> No answer from CBUS
Box serial number :CYA18359
Old 10-16-2012, 15:47   #567 (permalink)
Member: 966792
Sonork: 100.1602610
Thanks Meter: 199
AND SAME PROBLUM PL HELP
http://forum.gsmhosting.com/vbb/atta...0&d=1349267107
Old 10-16-2012, 21:17   #568 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Initializing box...
CYA This is not serial number, paste service tag pls.
Old 10-16-2012, 21:17   #569 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Pls paste service tag, we will help You urgent.
Old 10-17-2012, 09:56   #570 (permalink)
Member: 966792
Sonork: 100.1602610
Thanks Meter: 199
how to find service tag pl help
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
Box is not in needed mode [SOLVED] renren Cyclonebox 2 01-19-2010 22:38
::solve:: box is not in needed mode mr khalid Cyclonebox 6 09-15-2009 08:36
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.31339 seconds with 10 queries
