Old 04-21-2009, 13:33   #811 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,466
Originally Posted by panipat View Post
1110 auto charging what pro
brother,
reball or change uem
Old 04-21-2009, 13:36   #812 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
i have a 6280 and 6300 in same problem
insert sim card i change sim ic and also make jumper but same
any oone have any solution plz share
thanx this problam power ic ik
Old 04-21-2009, 13:38   #813 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
reball or change uem not slove other
Old 04-21-2009, 13:41   #814 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
ok bhai *** buy yyyyyyyyyyyyyy
Old 04-21-2009, 23:43   #815 (permalink)
Member: 221803
Thanks Meter: 18
pleas help me i have problem N70 when I Full charge battery can use 4 or 5 hour battery empty i try to change a lot battery still same problem one more my nokia 6680 don't save battery i charge over night don't sow full battery i have change thavo and retu
still same problem please help me mr SHIJILFONOTLY
Old 04-22-2009, 01:45   #816 (permalink)
Member: 771642
Sonork: aanshu55
Thanks Meter: 28
Originally Posted by shinod View Post
change betty ic 100% testes solution for lcd light in 6120
if it is same problem u can change l2304 it will 10000% work
Old 04-22-2009, 08:09   #817 (permalink)
Member: 351924
@G i l l a n i
check this picture
very simple to find this
Old 04-22-2009, 08:16   #818 (permalink)
Member: 351924
brother,carefully read my post 6280 or 6300 solution allready posted
auto charging not solved change UEM?
did u change this?
i think ur aim is with out charging solved this problem
Old 04-22-2009, 10:18   #819 (permalink)
Member: 221803
Thanks Meter: 18
mr Aanshu55
i have change L2304 but slov problem
Old 04-22-2009, 12:10   #820 (permalink)
G i l l a n i's Avatar
Member: 248178
Sonork: 100.1579207
Thanks Meter: 323
hi
i have 7210c in mic problem plz give me solution
thanx
Old 04-22-2009, 18:50   #821 (permalink)
Member: 1015819
my 5610 camera is going on standby mode wat to do
Old 04-23-2009, 06:39   #822 (permalink)
Member: 351924
Originally Posted by G i l l a n i View Post
hi
thanx
brother,210c same 5310xpress music pcb
change mic and fixed with copper wire.never to fix hot gun becoz over temp damaged mic
post result
Old 04-23-2009, 06:43   #823 (permalink)
Member: 351924
brother,this solution allready posted
u must used search button befor posting
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 04-23-2009, 07:28   #824 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
nokia 3500 contact ;flashing in ok 07.00 version ;but security test and simlock test failed pls............ help............
Old 04-23-2009, 07:35   #825 (permalink)
Member: 351924
bro,u have bb5 king?
just repair security area then unlock it
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.21370 seconds with 10 queries
